Latest post Thu, Apr 14 2016 7:34 PM by robg. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Feb 20 2014 4:44 PM
    • QPH
    • Joined on Fri, Jan 31 2014
    • Posts 6
    • Points 80
    WS Connection sub-sequence problem (iNews WS v1.3.0)
    Hello,
    I have a problem to use the iNEWS WS (v 1.3.0) because I can't stay logged on my sub sequence of calls...
    1] I'm connecting with systemClient.Connect()
    2] I'm connected if I look the systemClient.IsConnected() result
    But I don't find the way to link the others operations (for example SetCurrentQueue) with the primary session...
    Any help in v1.3 or code example (C or C#)?
    Adrien
  • Thu, Feb 20 2014 4:52 PM In reply to
    • fiatala
    • Joined on Fri, Jun 7 2013
    • Posts 16
    • Points 165
    Re: WS Connection sub-sequence problem (iNews WS v1.3.0)
    The three endpoints require three clients sharing the same connection. Here's a C# sample using a CookieContainer.
                INEWSSystem systemClient = new INEWSSystem();
                INEWSQueue queueClient = new INEWSQueue();
                INEWSStory storyClient = new INEWSStory();
                System.Net.CookieContainer sessionCookie = new System.Net.CookieContainer();
                systemClient.CookieContainer = sessionCookie;
                queueClient.CookieContainer = sessionCookie;
                storyClient.CookieContainer = sessionCookie;
                systemClient.Url = "http://news-web01:8080/inewswebservice/services/inewssystem";
                queueClient.Url = "http://news-web01:8080/inewswebservice/services/inewsqueue";
                storyClient.Url = "http://news-web01:8080/inewswebservice/services/inewsstory";
    Use systemClient.IsConnected() and queueClient.SetCurrenQueue().
  • Thu, Feb 20 2014 5:01 PM In reply to
    • QPH
    • Posts 6
    • Points 80
    In fact I have the same documentation, but when I load the WSDL of my 2 services :
    - SYSTEM
    - QUEUE
    I create instances like that :
                NEWSSystemPortTypeClient systemClient = new NEWSSystemPortTypeClient();
                NEWSQueuePortTypeClient queueClient = new NEWSQueuePortTypeClient();
    I don't have the property called "CookieContainer" to link the Cookie Session...
    Do you have an idea?
    thanks!
  • Thu, Feb 20 2014 5:12 PM In reply to
    • fiatala
    • Posts 16
    • Points 165
    The CookieContainer is a C# helper to share the single Tomcat session across three clients. It is required. You need to create it after client initialization.
    How did you generate the proxies (NEWSSystemPortTypeClient)? Each IDE does it slightly differently. I believe I generated mine with VS2010. Make sure you're using the soap1.1 workflows. Soap 1.2 / WCF IDE workflows will not work.
  • Thu, Feb 20 2014 5:19 PM In reply to
    • QPH
    • Posts 6
    • Points 80
    Thanks a lot fiatala!!
    I used the IDE (VS2013) with the SOAP1.2 (Services References) instead of Web References...
    Now, I have the "cookieContainer" property on my Class :)
    Have a good day =P
    Adrien
  • Thu, Feb 20 2014 5:25 PM In reply to
    • fiatala
    • Posts 16
    • Points 165
    Excellent. I'll see if I can clarify the instructions in the SDK/change notes.
    v1.3 is fairly old. v1.6 is out and available from the latest iNEWS installation media. v1.6 is still soap1.1, but it has several bug fixes over 1.3 and a few additional APIs.
  • Thu, Apr 14 2016 7:34 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
    • Avid Developer Moderator
      Avid Employee
    FYI: Here is what a complete C# program looks like calling into iNEWS System services:
    using System;
    using iNEWS_WS_Test.INEWS_System;
    namespace iNEWS_WS_Test
        class Program
            static void Main(string[] args)
                ConnectType connection = new ConnectType();
                connection.Username = "user01";
                connection.Password = "B4mzG2bS";
                connection.Servername = "iNEWS";
                ConnectResponseType connectResponse = systemClient.Connect(connection);
                GetFolderChildrenType getFolderChildren = new GetFolderChildrenType();
                getFolderChildren.FolderFullName = ".";
                GetFolderChildrenResponseType getFolderChildrenResponse = systemClient.GetFolderChildren(getFolderChildren);
                for (int i=0; i<getFolderChildrenResponse.Children.Length; i++)
                    Console.WriteLine(getFolderChildrenResponse.Children.Name + " " + getFolderChildrenResponse.Children.Type);
