Latest post Sun, Oct 25 2015 2:24 PM by pallen33. 37 replies.
Page 3 of 3 (38 items) < Previous 1 2 3
  • Thu, Dec 18 2014 11:47 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,235
    Re: C300 MXF & Media Composer Workflow
    Just a thought - have you considered jurt rolling back to MC 6?  If there's nothing in 8.2 that you particularly have to have, why not go with the version that works for you and update later?
    JamesMills:
    It freezes and does teh rainbow wheel of death after a few clips each time.
    FWIW most of the pro editors I knnow work with Canon, NIkon, etc., DSLR footage constantly and without issue.  The symptoms you're describing feel more like a hardware issue than a software one.  What are you using for media storage?
    Media Composer v8.9.2 | Windows 10 Professional 64-Bit | Supermicro X10DAi | Intel Xeon E5-2620 v4 Broadwell (x2) | Noctua NH-D9DX i4 (x2) | PNY GeForce... [view my complete system specs]
  • Fri, Dec 19 2014 12:19 AM In reply to
    Try copying one of the cards to the desktop and linking to it from there. We just received some drives that Avid had difficulties linking media from.
  • Fri, Dec 19 2014 12:37 AM In reply to
    Pheral - The new Avid is essential for my work with Red Dragon footage (the ability to read it AMA and, most importantly, the FrameFlex option is absolutely essential for me).
    I was originially using a 1TB Seagate USB 3 portable drive and then transferred the footage onto a Seagate 5TB USB 3 drive to see if htat would offer a solution. Unfortunately it did not.
    I just tried copying and pasting some clips to my desktop and it still crashed when i AMA's it (though it did scrub fast for a few moments before freezing up).
    Do you guys think I should try reinstalling this Avid version? Will it even let me since it's I leased it for a year merely?
    AVID 8.3.0, Macbook Pro Retina - Processor 2.6 GHz Intel Core i7, Memory 16 GB 1600 MHz DDR3, Graphics NVIDIA GeForce GT 650M 1024 MB, Software OS... [view my complete system specs]
  • Fri, Dec 19 2014 12:49 AM In reply to
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 127
    • Points 1,730
    I have a few hundreds of clips from 5d MkIII linked straight through AMA in the project I'm working on right now. It does play in real-time without much issue, but it is far less stable than, for example, MFX. If you add CC, Title, Surimpose, etc. to it, you need to render. I sometimes get dropped frames and LAG when it's mixed with C300 MXF footage on the same timeline.
    It's working fine for me because it is just 5% of my material, but if I would work on a 100% MKIII edit, I would definitely convert the clips to ProRes or DNxHD. Basic import into Avid should also work fine.
    Have you installed all the AMA Plugin from Canon website?http://usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0200321102EN.htm
    You could also try to "force" an AMA plugin from the dropdown in the AMA LINK window.
    Have you tried linking to other AMA file type, like a DNxHD for example?
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Wed, Dec 24 2014 6:44 PM In reply to
    I upgraded to 8.3 last night and voila: everything is working fine! Maybe I can suggest reinstalling everything again as that may have also solved it for me? So far so good, I'll keep you guys posted.
    Thanks, everyone
  • Thu, Aug 13 2015 9:04 PM In reply to
    That's all well and good. But where can you download the Canon plug-in??
    I can't find it anywhere!
    Dustyn
  • Wed, Aug 19 2015 3:51 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,479
    • Points 44,835
    Hi Dustyn,
    Please take a look Here.
    Dave S.
  • Sun, Oct 25 2015 2:24 PM In reply to
    • pallen33
    • Joined on Wed, Aug 18 2010
    • Wales, UK
    • Posts 11
    • Points 105
    Just to chip in on this, it's probably the fact that you've not created an extra folder layer that is the problem - I also faced this. So you need to create a new folder, and then put the 'contents' folder in this. Not intuitive, but there you go...
    Paul
    Avid Media Composer 8.3.1 HP Z420 16GB RAM Avid Certified Machine Avid Certified User [view my complete system specs]
