Latest post Wed, Apr 16 2014 10:01 PM by robg. 2 replies.
  • Wed, Jan 8 2014 4:35 PM
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
    • Avid Developer Moderator
      Avid Employee
    Tutorial: Calling Into Interplay Production WS from .NET Clients
    Greetings,
    I got a couple of requests recently for Visual Basic or C# sample code for calling into Interplay Production Web Services.
    Here's what a Search() call looks like in VB
    Imports InterplayWSClientTest.InterplayWS
    Module Module1
        Sub Main()
            Console.WriteLine("Interplay WS Test")
            Dim port As New AssetsPortTypeClient()
            Dim creds As New UserCredentialsType()
            creds.Username = "username"
            creds.Password = "password"
            Dim param As New SearchType()
            param.InterplayPathURI = "interplay://WGC/Projects/rob's project/rob's project Bin/"
            param.SearchGroup = New SearchGroupType()
            param.SearchGroup.[Operator] = "AND"
            param.SearchGroup.AttributeCondition = New AttributeConditionType(0) {}
            param.SearchGroup.AttributeCondition(0) = New AttributeConditionType()
            param.SearchGroup.AttributeCondition(0).Condition = "EQUALS"
            param.SearchGroup.AttributeCondition(0).Attribute = New AttributeType()
            param.SearchGroup.AttributeCondition(0).Attribute.Name = "Type"
            param.SearchGroup.AttributeCondition(0).Attribute.Group = "SYSTEM"
            param.SearchGroup.AttributeCondition(0).Attribute.Value = "masterclip"
            Dim response As SearchResponseType = port.Search(creds, param)
            If response.Results.Length > 0 Then
                For Each ad As AssetDescriptionType In response.Results
                    Console.WriteLine(ad.InterplayURI)
                    For Each att As AttributeType In ad.Attributes
                        Console.WriteLine(att.Group + "." + att.Name + " = " + att.Value)
                    Next
                    Console.WriteLine()
                Next
            Else
                Console.WriteLine("No records found")
            End If
            Console.ReadLine()
        End Sub
    End Module
    Here's the same logic in C#
    using System;
    using InterplayWSClientTest.InterplayWS;
    namespace InterplayWSCSharpTest
        class Program
            static void Main(string[] args)
                Console.WriteLine("Interplay WS Test");
                AssetsPortTypeClient port = new AssetsPortTypeClient();
                UserCredentialsType creds = new UserCredentialsType();
                creds.Username = "username";
                creds.Password = "password";
                SearchType param = new SearchType();
                param.InterplayPathURI = "interplay://WGC/Projects/rob's project/rob's project Bin/";
                param.SearchGroup = new SearchGroupType();
                param.SearchGroup.Operator = "AND";
                param.SearchGroup.AttributeCondition = new AttributeConditionType[1];
                param.SearchGroup.AttributeCondition[0] = new AttributeConditionType();
                param.SearchGroup.AttributeCondition[0].Condition = "EQUALS";
                param.SearchGroup.AttributeCondition[0].Attribute = new AttributeType();
                param.SearchGroup.AttributeCondition[0].Attribute.Name = "Type";
                param.SearchGroup.AttributeCondition[0].Attribute.Group = "SYSTEM";
                param.SearchGroup.AttributeCondition[0].Attribute.Value = "masterclip";
                SearchRequest request = new SearchRequest();
                request.UserCredentials = creds;
                request.Search = param;
                SearchResponseType response = port.Search(creds, param);
                if (response.Results.Length > 0)
                    foreach (AssetDescriptionType ad in response.Results)
                        Console.WriteLine(ad.InterplayURI);
                        foreach (AttributeType att in ad.Attributes)
                            Console.WriteLine(att.Group + "." + att.Name + " = " + att.Value);
                        Console.WriteLine();
                else
                    Console.WriteLine("No records found");
                Console.ReadLine();
    Note that you will have to do these things to get this running at your site:
    1. Use Visual Studio to create a console project called InterplayWSClientTest
    2. Copy in the source (into Module1.vb for Visual Basic or Program.cs for C#)
    3. In the project, use Configure Service Reference to point to your Interplay Production WS system
    4. Change the username and password in the code to valid credentials
    5. Change the Interplay Path to a folder in your Interplay that has some master clips
    If anyone would like the project/solution files, please request it in a reply to this post, noting the language and Visual Studio version, and I'll upload it to this thread. Cheers, - Rob
  • Tue, Apr 15 2014 8:28 PM In reply to
    • xudon
    • Joined on Tue, Apr 15 2014
    • Posts 14
    • Points 180
    Re: Tutorial: Calling Into Interplay Production WS from .NET Clients
    Hi, robg
    Thanks for the post! I'm new to dotnet web services. Could you tell me how to code in vb.net for infrastructure services so I can get configuration or version info back? I tried different syntax and none of them works.
    Thank you very much for the help!
    Don
  • Wed, Apr 16 2014 10:01 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
      Avid Employee
    Don,
    I was able to get this working with the following setup:
    1. Launch Visual Studio (I'm using VS2010)
    2. Create a new Project: Visual Basic, Console Application, call it VSBasicTest
    3. Right Click on Project in the Solution Explorer, and Choose Add Service Reference
    4. Paste in the Infrastructure URL i.e. http://<servername>/services/Assets?wsdl
    5. Use the Namespace InterplayAssets, click OK
    And using the following code:
    Imports VSBasicTest.InterplayAssets
    Module Module1
        Sub Main()
            Dim port As New InfrastructurePortTypeClient
            Dim getVersion As New GetVersionInformationType
            getVersion.WorkgroupURI = "interplay://WGC"
            Dim response As GetVersionInformationResponseType = port.GetVersionInformation(creds, getVersion)
            Dim sInfo As String = response.InterplayWebServicesVersion.ToString()
            Console.WriteLine(sInfo)
        End Sub
    End Module
    Results:
      Interplay WS Test
      3.0.5.0
    Hope this helps,
    - Rob
