Latest post Sun, Dec 8 2013 12:58 AM by LoneStarHawkeye. 4 replies.
  • Sat, Dec 7 2013 7:59 AM
    5.5.1 MC will not load
    I have OS 10.6.8 and I cannot for the life of me get my MC 5.5.1 to load on my system. It just tells me this below...
    "AvidMediaComposer cannot be opened because of a problem.
    Check with the developer to make sure AvidMediaComposer works with this version of Mac OS x. You may need to reinstall the application. Be sure to install any available updates for the application and Mac OS X"
    I haven't used my system in maybe a month as I've been out of the country, but it worked before I left and I haven't updated anything on it so I'm wondering what might be going on all of a sudden.
    I know I could just uninstall and reinstall, but I don't want to mess with the hassel without at least asking the board a question.
    Hopefully someone has an answer for me.
    Thanks in advance.
    Mark
    Mac Pro 2009 Nehalem Eight Core 2.93 GHz * Media Composer 8.6.1 * Pro Tools 10.3.10 [view my complete system specs]
  • Sat, Dec 7 2013 8:38 AM In reply to
    Re: 5.5.1 MC will not load
    I looked at the comments section of the error I posted above and for some reason it isn't even recognizing a version of my media composer. If I use the uninstall feature in finder, will that unistall everything so I don't have to root around for it? Then just bust back out my discs and reinstall?
    Again thanks for any help in advance.
    Process:         AvidMediaComposer [1330]
    Path:            /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Identifier:      com.avid.mediacomposer
    Version:         ??? (???)
    Code Type:       X86 (Native)
    Parent Process:  launchd [107]
    Date/Time:       2013-12-07 00:36:00.272 -0800
    OS Version:      Mac OS X 10.6.8 (10K549)
    Report Version:  6
    Interval Since Last Report:          3199 sec
    Crashes Since Last Report:           11
    Per-App Crashes Since Last Report:   11
    Anonymous UUID:                      30AD9364-17A1-4C20-B0D3-F497BE71E5CD
    Exception Type:  EXC_BREAKPOINT (SIGTRAP)
    Exception Codes: 0x0000000000000002, 0x0000000000000000
    Crashed Thread:  0
    Dyld Error Message:
      Library not loaded: /Library/Frameworks/AvidCoreServices.framework/Versions/A/AvidCoreServices
      Referenced from: /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
      Reason: image not found
    Binary Images:
    0x8fe00000 - 0x8fe4163b  dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
    Model: MacPro4,1, BootROM MP41.0081.B07, 8 processors, Quad-Core Intel Xeon, 2.93 GHz, 8 GB, SMC 1.39f5
    Graphics: NVIDIA GeForce GT 120, NVIDIA GeForce GT 120, PCIe, 512 MB
    Memory Module: global_name
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.10.131.42.4)
    Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
    Network Service: AirPort, AirPort, en2
    PCI Card: NVIDIA GeForce GT 120, sppci_displaycontroller, Slot-1
    Serial ATA Device: HL-DT-ST DVD-RW GH41N
    Serial ATA Device: OWC Mercury Electra 3G SSD, 111.79 GB
    USB Device: Rikiki USB 3, 0x059f  (LaCie), 0x1057, 0xfa400000 / 2
    USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd300000 / 2
    USB Device: iLok, 0x088e, 0x5036, 0xfd340000 / 4
    USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0xfd330000 / 3
    USB Device: Kensington Expert Mouse, 0x047d  (Kensington), 0x1020, 0xfd333000 / 6
    USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0220, 0xfd332000 / 5
    USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000 / 2
    USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0x5a110000 / 5
    FireWire Device: OEM ATA Device 00, G-TECH, Up to 800 Mb/sec
    FireWire Device: My Passport 071D, WD, Up to 800 Mb/sec
    FireWire Device: built-in_hub, Up to 800 Mb/sec
    FireWire Device: Mbox Pro, Avid, Up to 400 Mb/sec
  • Sat, Dec 7 2013 1:18 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,162
    • Points 23,190
    Well it looks like something has gotten corrupt I would try the re install first are you hearing any disc noise
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Sat, Dec 7 2013 4:42 PM In reply to
    Hello there Tom, thanks for the reply.
    I don't hear any disc noise, but they are SSD with programs only so I don't know if there is a tell tale sign or etc if the drive is going crazy. All the other programs seem to work though so I would hope not.
    Do you perhaps know if I can deauthorize the program on Avid's website? I'm not sure how to deauthorize without being able to open the program itself.
    Thanks in advance,
    Mark
  • Sun, Dec 8 2013 12:58 AM In reply to
    Uninstalling did make Media Composer work so that's nice.
    However, when I went to look for posts on here about deauthorizing and etc people said that even if you forget, just uninstalling it will deauthorize it based on the MC that I had... not the case at all as not it says "node locked" which defeats the point. After trying to register MC again it tells me that it is already activated.
    This is crap as I work during the week during their "hours" for my ASC and when I get home to my system they are closed and they are not open on the weekend and now I'm stuck waiting on their response to my submission which who knows when on earthy they'll get to that. If the support code I have it 200 I can only imagine what crazy cost the 24/7 is.
    Done venting. Thanks for the suggestion above as it did work in getting it to finally open.
    Mark
