Latest post Thu, Jul 3 2014 8:12 AM by Az Kola. 7 replies.
  • Wed, Nov 6 2013 2:15 PM
    • Az Kola
    • Joined on Wed, Nov 16 2011
    • London, UK
    • Posts 275
    • Points 3,260
    Media Composer 7.0.2 Assertion failed
    Using MC 7.0.2, HP420 PC, Decklink Video Card
    I am getting the following error:
    "Assertion failed: 0<slot && slot <mNumSamps File:..\..\src|RequestList.cpp, Line: 1068"
    Anyone has an idea what this could be caused by please? It is happening very often while working on sequence.
    Any suggestion would be welcome at this point as I need to get it fixed.
    Thanks in advance.
    http://www.flickr.com/photos/azemkola [view my complete system specs]
  • Wed, Nov 6 2013 4:46 PM In reply to
    • Posts 9,687
    • Points 211,425
    Re: Media Composer 7.0.2 Assertion failed
    Az
    The error is really generic as you can see by the # of articles in the Knowledge Base on this.
    http://www.avid.com/US/search?q=Assertion%20failed&site=kbase&filter=0
    Could you be a little more specific on what you are doing when it happens and what the timeline is made up of ( SD/HD ).  If you open an older project or a new one and perform the same actions does it fail?  that might indicate you have suspect or corrupt media.
    Just guessing though.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Nov 7 2013 1:41 PM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    Thanks for getting back Marianna,
    Normally it happens when scrubbing on sequence or preview window.
    The media is all DNxHD 36. I have tried opening this on MC 6.0.4 and seems to be working which made me think that iit might have something to do with MC 7.0.2
    I will try and re-index the media meanwhile.
    thanks
  • Fri, Dec 13 2013 4:42 PM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    Does anyone understand what this is all about? It is happening after I switch between the Media Composer and Desktop or other applications. Which then seems to be producing the Assetion error.
    The Sequences are HD, I have create a New Project and same issue. I have also re-created the database files. All media is at DNxHD36.
    ERROR: VDM3BOBVideoOut::Cleanup() - BOB has not displayed frame after 2000 ms! (enabled = true)
    Monitor Exception:
  • Fri, Dec 13 2013 5:29 PM In reply to
    • SchnittKontor_HH
    • Joined on Thu, Mar 30 2006
    • Europe - Germany - Hamburg
    • Posts 89
    • Points 1,015
    Hi, same error on HP Z820 + Decklink
    http://community.avid.com/forums/t/119798.aspx
    MC /w. Sym 8.9 | AVID Artist | DNxIO | Transport | HP Z820 GEN 1 /Sandy-Bridge, 2x Xeon E5-2687W v1 8-Core 3.1 GHz, 32GB RAM, GUI: Quadro K4200, GPU: 1x... [view my complete system specs]
  • Fri, Dec 13 2013 5:52 PM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    Thank you, I will report back with solution once I get to the bottom of this.
  • Mon, Apr 28 2014 9:05 AM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    Nothing has been fixed for this yet. Blackmagic doesn't seem to have a solution and I have also tried installing the latest drivers too since last time.
    I am still trying to get Blackmagic to investigate the issue but looks like a replacement of differrent video card might be the solution to this.
    Will update any information I get about this.
  • Thu, Jul 3 2014 8:12 AM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    Just a quick update on this. I had to exchange the video card for a new one and that seems to have solved the issue.
