Latest post Wed, Nov 11 2015 9:21 PM by Isaac T.. 28 replies.
Page 1 of 2 (29 items) 1 2 Next >
  • Fri, Nov 1 2013 9:20 AM
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    MDV still rules, also on the Mac side
    From time to time it shows up different workflows for how to use MDV on Mac, some of them including external applications and customized workflows.
    As I have upgraded a drive to Maverick now I wanted to find out if my old workflow was broke but it still works good.
    So, from your windows emulator, you need to have one as MDV is a windows application and I use Parallels as emulator, just open up MDV and then manually drag all the individual mxf folders into that upper left field, cmd - a will select all in the browser so you dont need to select all the folders individually, then, if you have more drives for Avid media storage just repeat that workflow until you have it all loaded into that upper left window.
    Now just press scan and make your adjustments.
    Tomas
  • Mon, Mar 31 2014 6:37 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 746
    • Points 8,805
    Re: MDV still rules, also on the Mac side
    (Looking for the MDV on OS X post? Click here:
    http://community.avid.com/forums/t/135540.aspx)
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
  • Sun, Aug 24 2014 9:17 PM In reply to
    Wine will not run on Mavericks :-(
  • Mon, Aug 25 2014 6:51 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Ghoulardi57:
    As I wrote in my initial post
    Now on 10.9.4 using Parallels 9 and Windows 8.1 and MDV works like a charm with the workflow described in that initial post.
    Tomas
  • Mon, Aug 25 2014 10:34 AM In reply to
    I can't help at a little chuckle when I see Mac users runining windows on their Mac to achieve the functionality they need.
    No idea what Parallels costs but Windows 8.1 isn't a cheap solution just to run that one app
  • Mon, Aug 25 2014 10:41 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    The Windows install disc is used on my Pc station Pat so no cost for that one and activating the license was no problem.
    Parallels about 100 bucks or something and MDV is free.
    I guess and hope that you get a better company income per hour than that.
    Tomas
  • Mon, Aug 25 2014 11:19 AM In reply to
    Pretty sure your not allowed to install another version of Windows 8.1 on another system. It may activate but that doesn't mean your not in breach of the license agreement.
    Wiindows OS normally sells as an OEM for installing only on the hardware it's shipped with and is bundled in at a reduced cost. A full retail costs more and even then normally only allows one installation.
  • Wed, Aug 27 2014 2:45 PM In reply to
    • Isaac T.
    • Posts 746
    • Points 8,805
    Ghoulardi57:
    Sure it does! Get it here:
    http://winebottler.kronenberg.org
    Then follow the directions above.
  • Wed, Aug 27 2014 3:06 PM In reply to
    • Isaac T.
    • Posts 746
    • Points 8,805
    Pat Horridge:
    Agreed.
    Not startin' another episode of Grown Men Fighting on the Internet, but after you set up Wine, MDV's easy to use. I even made aliases to the EXE's and put them in a stack!
    One click and I'm off! Wine launches in the background and everything. And it works in Mavericks. (As of this writing, 10.9.2.)
  • Mon, Apr 20 2015 4:53 PM In reply to
    • Isaac T.
    • Posts 746
    • Points 8,805
    Confirmed - using MDV with Winebottler works in Yosemite (10.10.2).
    Revised instructions above ⤴️:
    http://community.avid.com/forums/p/123607/724961.aspx#724961
  • Sat, Sep 5 2015 10:21 PM In reply to
    • F J L Inc
    • Joined on Wed, Oct 17 2012
    • Posts 20
    • Points 335
  • Sun, Sep 6 2015 7:44 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    As being the Op of this thread, this was what I wrote in my opening up post
    Tomas
  • Sun, Sep 6 2015 9:45 PM In reply to
    • F J L Inc
    • Posts 20
    • Points 335
    Thanks for the reply, mjoinarn. I figured it out.
  • Mon, Sep 7 2015 8:57 AM In reply to
    Its really frustrating that Media Composers Media Tool doens't include some of the basic functionality needed by users.
    To have to run an OS emulator on a MAc to do Avid media management is a sign of just how important an overhaul of Media management is needed.
  • Mon, Sep 7 2015 12:15 PM In reply to
    • F J L Inc
    • Posts 20
    • Points 335
    It really is, Pat. It is amazing that such a versatile program as Avid does not include such a baisc tool for media management as MDV.
