Latest post Sat, Jun 27 2015 9:52 PM by moviejulie. 14 replies.
Page 1 of 1 (15 items)
  • Fri, Sep 27 2013 1:05 AM
    • CrystalRC
    • Joined on Fri, Sep 27 2013
    • Posts 9
    • Points 65
    Avid 7 Multigroup Error: "MonPane::SetComposition():...."
    Hello Avid world!
    Project details: iMac, Avid 7, 8GB RAM, MXF clips from a Sony F55 AMA'd using the Sony XDCAM plugin v. 3.11, transcoded to 14:1, project is 23.98... (am I leaving anything out?)
    I was multigrouping 2 video tracks w/ audio stems as I have done on MC 5 & 6 every week for years. Last night was my first time multigrouping in MC7. I was in 1080, AMA'd clips, set tape names, fliped back to NTSC to transcode, sunc the master timeline, did my add edits, made sub clips w/ Aux24 time code. Once sub clips were done I always sort the bin by Name/Tape/Aux24 in that order, highlight all aud & vid subclips, then hit multigroup. Multigroup'd by Aux24. A few dozen groups plus the multigroup showed up. When I double clicked on the multigroup to load it into the source monitor I got this error:
    MonPane::SetComposition(): Internal error occurred trying to load composition into the monitor. See the console for more information.
    When I went to the console for more information, it listed all my subclips and... I hate to say this but I won't be able to tell you further details until about 8:45pm when I'm back in front of the system. I'll update this post with that information as soon as I can.
    This error did NOT occurr when I multigrouped just one group of clips at a time (2 video + 1 audio clip). However, when I load that group into the source monitor I can only see one of the cameras playing at a time. When I pause it splits back into the two banks.
    I was horrified to discover an error that wasn't showing up on Google or in a forum. Please help if you can!
    Also, please let me know if I can clarify any details (again, I'll update the rest of the console info later tonight.) Thank you thank you thank you.
  • Sat, Sep 28 2013 4:18 AM In reply to
    • CrystalRC
    • Posts 9
    • Points 65
    Re: Avid 7 Multigroup Error: "MonPane::SetComposition():...."
    UPDATE:
    Looked at the console. It's ridiculosuly long so I chopped it up into three sections of information it is providing and cut off the ends of long lists. In the first section there are different frame rates listed but I checked the fps column when I AMA linked and only transcoded footage listed as 23.98. No idea why it's listing different frame rates in the first section.
    FIRST SECTION OF CONSOLE:
    'AComposition'; GlobalOffset 0; len 85866, 23.976 fps; 19 trks, TGM_NORMAL; {MT_LOGICAL, AC_GROUP}, "MultiGroup.01",
    AAFmobID 060a2b340101010101010f0013-000000-52465280b1b6000f-060e2b347f7f-2a80, OMFmobID 42.1380340352.1028534
    ! Track 0 { TT_TIMECODE, 1}; cc 0, csc 0
    ! 'ATimecodeClip'; GlobalOffset 0; len 85866, 23.976 fps; startTC 01:00:00:00 (24 fps), len 00:59:37:18 (24 fps)
    ! Track 1 { TT_TIMECODE, 3}; cc 0, csc 0
    ! 'ACaptureMask'; GlobalOffset 0; len 85866, 23.976 fps; 1 trk, TGM_NORMAL; phase 0; mask(PAL_PULLDOWN_MASK) FFF7FF80 (25) del
    ! ! Track 0 { TT_TIMECODE, 3}; cc 0, csc 0
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 89444, 23.976 fps; startTC 01:00:00:00 (25 fps), len 00:59:37:19 (25 fps)
    ! Track 2 { TT_TIMECODE, 2}; cc 0, csc 0
    ! Track 3 { TT_TIMECODE, 4}; cc 0, csc 0
    ! 'ATimecodeClip'; GlobalOffset 0; len 85866, 23.976 fps; startTC 01:00:00:00 (25 fps), len 00:57:14:16 (25 fps)
    ! Track 4 { TT_TIMECODE, 5}; cc 0, csc 0
    ! 'ACaptureMask'; GlobalOffset 0; len 85866, 23.976 fps; 1 trk, TGM_NORMAL; phase 0; mask(NTSC_PULLDOWN_MASK) D8000000 (5) del
    ! ! Track 0 { TT_TIMECODE, 5}; cc 0, csc 0
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 107333, 23.976 fps; startTC 01;00;00;00 (30 fps), len 00;59;41;11 (30 fps)
    ! Track 5 { TT_TIMECODE, 6}; cc 0, csc 0
    ! ! Track 0 { TT_TIMECODE, 6}; cc 0, csc 0
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 107333, 23.976 fps; startTC 01:00:00:00 (30 fps), len 00:59:37:23 (30 fps)
    ! Track 6 { TT_TIMECODE, 7}; cc 0, csc 0
    ! 'ACaptureMask'; GlobalOffset 0; len 85866, 23.976 fps; 1 trk, TGM_NORMAL; phase 0; mask(ONE_TO_ONE_MASK) 80000000 (1) del
    ! ! Track 0 { TT_TIMECODE, 7}; cc 0, csc 0
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 85866, 23.976 fps; startTC 01:00:00:00 (30 fps), len 00:47:42:06 (30 fps)
    ! Track 7 { TT_EDGECODE, 1}; cc 0, csc 0
    ! 'AEdgecodeClip'; GlobalOffset 0; len 85866, 23.976 fps; startEC 001-0000+00 = 0 frames , len 5366+10
    ! Track 8 { TT_TIMECODE, 8}; cc 0, csc 0
    ! 'ACaptureMask'; GlobalOffset 0; len 85866, 23.976 fps; 1 trk, TGM_NORMAL; phase 0; mask(MASK_24_TO_60) A2800000 (10) del
    ! ! Track 0 { TT_TIMECODE, 8}; cc 0, csc 0
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 214666, 23.976 fps; startTC 01:00:00:00 (60 fps), len 00:59:37:23 (60 fps)
    (continues this pattern for a very long time)
    SECOND SECTION:
    ##### Clip and Source Summary for 'MultiGroup.01': (9/27/13 8:53:44 PM)
    ##### Created using: Avid Media Composer 7.0.0.765
    Group Clips were found in the selected range.
    All source clips within the Groups Clips were included in the search.
    ########## Source Clip List: ##########
    127 clips found.
    ____ INFO ____ __ TRACKS __ __ OFFLINE __ __________ CLIP NAME __________
    Subclip A1-2 121/1.sub.01
    Subclip A1-2 121/2.sub.01
    Subclip A1-2 121/3.sub.01
    Subclip A1-2 121A/2.sub.01
    Subclip A1-3 47/1.sub.01
    Subclip A1 47/2.sub.01
    Subclip A1 47/3.sub.01
    Subclip A1-2 47/4.sub.01
    (Continues listing every audio and video sub-clip from my timeline...)
    LAST SECTION:
    ########## Imported Source Info: ##########
    4 import-based sources found.
    __________ IMPORT PATH __________
    /Volumes/CRDBRD_BXR_EDITORIAL/Cardboard Boxer Audio/AUDIO_ROLL_01/13Y09M22/47BT01.WAV
    /Volumes/CRDBRD_BXR_EDITORIAL/Cardboard Boxer Audio/AUDIO_ROLL_01/13Y09M22/47BT02.WAV
    /Volumes/CRDBRD_BXR_EDITORIAL/Cardboard Boxer Audio/AUDIO_ROLL_01/13Y09M22/75AT01.WAV
    /Volumes/CRDBRD_BXR_EDITORIAL/Cardboard Boxer Audio/AUDIO_ROLL_01/13Y09M22/75AT02.WAV
    ############################## End Clip and Source Summary ##############################
    ##### Effect Summary for 'MultiGroup.01': (9/27/13 8:53:44 PM)
    No effects found in 'MultiGroup.01'.
    ############################## End Effect Summary ##############################
  • Tue, Dec 3 2013 1:58 AM In reply to
    • rkidd21
    • Joined on Tue, Dec 3 2013
    • Posts 1
    • Points 15
    Hey There,
    Did you ever come up with a solution to this problem?
  • Tue, Dec 3 2013 2:21 AM In reply to
    • CrystalRC
    • Posts 9
    • Points 65
    Nope! We had to group the whole film one mini-group at a time. It was really annoying. Any ideas? Or are you having the same problem?
  • Tue, May 13 2014 5:45 PM In reply to
    • KHerring
    • Joined on Tue, Apr 17 2012
    • Posts 9
    • Points 105
    CrystalRC:
    Same exact problem here! Console looks pretty much the same. Hoping someone has found a reason for this error?
    For now, I guess I'll start on my mini groups :/
  • Tue, May 13 2014 6:15 PM In reply to
    Not sure if you can group clips with different frame rates, and while I'm not sure what KHerring's Console says, the one from the OP does seem to show different tracks with a mix of frame rates.
  • Tue, May 13 2014 6:27 PM In reply to
    • KHerring
    • Posts 9
    • Points 105
    Kevin Klimek:
    Interesting! No, same frame rates here. Same format, unique tape names... I'm even grouping by source timecode, so there's no chance for aux TC weirdness.
    More info: Mac OS X 10.9.1, Avid MC 7.0.3, working from a 16TB GRaid drive at DNxHD 175.
  • Tue, May 13 2014 6:33 PM In reply to
    Not sure if this is an issue, but only MC 7.0.4 (released yesterday) is supported on Mavericks, and that is OS X 10.9.2.  May not be related, but until 7.0.4, no MC 7 version was tested with Mavericks.
    What does your console say?  Does it happen with all Multigroups you make or just some?
  • Tue, May 13 2014 7:41 PM In reply to
    • KHerring
    • Posts 9
    • Points 105
    Kevin Klimek:
    When we bought Avid, 7.0.3 had been approved on OS X 10.9.1 but NOT 10.9.2, so that's why we've stuck with 9.1 so far. Glad to know the updates for both are available, and I'll try upgrading both and let you know how it goes.
    Kevin Klimek:
    Just some. Last night was the first time we've gotten the error after a dozen days of multigrouping without such a message. I’ve been running some tests.
    TEST RESULTS:
    When I multigroup clips with different audio sources, only the first stack of clips is included- the multigroup ends at the first add edit in the sequence.
    Seems when I multigroup with multiple video sources, I get the same result. This does not always happen, only on specific hours of specific days. Hmm…
    The error messages are coming from a sequence with multiple audio AND video clips. I'm going to copy paste the entire console for the sake of research (by the way, it reads like I have different frame rates, but I absolutely do not):
    'AComposition'; GlobalOffset 0; len 5472, 23.976 fps; 19 trks, TGM_NORMAL; {MT_LOGICAL, AC_GROUP}, "MultiGroup.03",
    AAFmobID 060a2b340101010101010f0013-000000-53727381ddd10078-060e2b347f7f-2a80, OMFmobID 42.1400009601.7921105
    ! 'ATimecodeClip'; GlobalOffset 0; len 5472, 23.976 fps; startTC 01:00:00:00 (24 fps), len 00:03:48:00 (24 fps)
    ! 'ACaptureMask'; GlobalOffset 0; len 5472, 23.976 fps; 1 trk, TGM_NORMAL; phase 0; mask(PAL_PULLDOWN_MASK) FFF7FF80 (25) del
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 5700, 23.976 fps; startTC 01:00:00:00 (25 fps), len 00:03:48:00 (25 fps)
    ! 'ATimecodeClip'; GlobalOffset 0; len 5472, 23.976 fps; startTC 01:00:00:00 (25 fps), len 00:03:38:22 (25 fps)
    ! 'ACaptureMask'; GlobalOffset 0; len 5472, 23.976 fps; 1 trk, TGM_NORMAL; phase 0; mask(NTSC_PULLDOWN_MASK) D8000000 (5) del
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 6840, 23.976 fps; startTC 01;00;00;00 (30 fps), len 00;03;48;06 (30 fps)
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 6840, 23.976 fps; startTC 01:00:00:00 (30 fps), len 00:03:48:00 (30 fps)
    ! 'ACaptureMask'; GlobalOffset 0; len 5472, 23.976 fps; 1 trk, TGM_NORMAL; phase 0; mask(ONE_TO_ONE_MASK) 80000000 (1) del
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 5472, 23.976 fps; startTC 01:00:00:00 (30 fps), len 00:03:02:12 (30 fps)
    ! 'AEdgecodeClip'; GlobalOffset 0; len 5472, 23.976 fps; startEC 001-0000+00 = 0 frames , len 342+00
    ! 'ACaptureMask'; GlobalOffset 0; len 5472, 23.976 fps; 1 trk, TGM_NORMAL; phase 0; mask(MASK_24_TO_60) A2800000 (10) del
    ! ! 'ATimecodeClip'; GlobalOffset 0; len 13680, 23.976 fps; startTC 01:00:00:00 (60 fps), len 00:03:48:00 (60 fps)
    ! Track 9 { TT_PICTURE, 1}; cc 0, csc 0
    ! 'ASequence'; GlobalOffset 0; len 5472, 23.976 fps; 8 subComponents
    ! : 'ASelector'; GlobalOffset 0; len 2840, 23.976 fps; 3 trks, TGM_NORMAL; selected 0
    ! : ! Track 0 { TT_PICTURE, 0}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_PICTURE, 1},
    ! : ! AAFmobID 060a2b340101010101010f0013-000000-53727381dd4e0078-060e2b347f7f-2a80, OMFmobID 42.1400009601.7920974
    ! : ! Track 1 { TT_PICTURE, 0}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_PICTURE, 2},
    ! : ! Track 2 { TT_PICTURE, 0}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_PICTURE, 3},
    ! : 'ASelector'; GlobalOffset 2840; len 12, 23.976 fps; 3 trks, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_PICTURE, 1},
    ! : ! AAFmobID 060a2b340101010101010f0013-000000-53727381dd660078-060e2b347f7f-2a80, OMFmobID 42.1400009601.7920998
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_PICTURE, 2},
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_PICTURE, 3},
    ! : 'ASelector'; GlobalOffset 2852; len 8, 23.976 fps; 2 trks, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 2852; len 8, 23.976 fps, pos 0, track { TT_PICTURE, 1},
    ! : ! AAFmobID 060a2b340101010101010f0013-000000-53727381dd7c0078-060e2b347f7f-2a80, OMFmobID 42.1400009601.7921020
    ! : ! 'ASourceClip'; GlobalOffset 2852; len 8, 23.976 fps, pos 0, track { TT_PICTURE, 2},
    ! : 'ASourceClip'; GlobalOffset 2860; len 44, 23.976 fps, pos 45492, track { TT_PICTURE, 1},
    ! : AAFmobID 060a2b340101010101010f0013-000000-5372732881370077-060e2b347f7f-2a80, OMFmobID 42.1400009512.7831863
    ! : 'AFillerClip'; GlobalOffset 2904; len 772, 23.976 fps
    ! : 'ASelector'; GlobalOffset 3676; len 52, 23.976 fps; 1 trk, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_PICTURE, 1},
    ! : ! AAFmobID 060a2b340101010101010f0013-000000-53727381dd910078-060e2b347f7f-2a80, OMFmobID 42.1400009601.7921041
    ! : 'ASelector'; GlobalOffset 3728; len 96, 23.976 fps; 2 trks, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_PICTURE, 1},
    ! : ! AAFmobID 060a2b340101010101010f0013-000000-53727381dda70078-060e2b347f7f-2a80, OMFmobID 42.1400009601.7921063
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_PICTURE, 2},
    ! : 'ASelector'; GlobalOffset 3824; len 1648, 23.976 fps; 3 trks, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_PICTURE, 1},
    ! : ! AAFmobID 060a2b340101010101010f0013-000000-53727381ddbd0078-060e2b347f7f-2a80, OMFmobID 42.1400009601.7921085
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_PICTURE, 2},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_PICTURE, 3},
    ! Track 10 { TT_SOUND, 1}; cc 0, csc 0
    ! : 'ASelector'; GlobalOffset 0; len 2840, 23.976 fps; 4 trks, TGM_NORMAL; selected 0
    ! : ! Track 0 { TT_SOUND, 0}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 4},
    ! : ! Track 1 { TT_SOUND, 0}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 5},
    ! : ! Track 2 { TT_SOUND, 0}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 6},
    ! : ! Track 3 { TT_SOUND, 0}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 7},
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_SOUND, 4},
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_SOUND, 5},
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_SOUND, 6},
    ! : ! 'ASourceClip'; GlobalOffset 2852; len 8, 23.976 fps, pos 0, track { TT_SOUND, 3},
    ! : ! 'ASourceClip'; GlobalOffset 2852; len 8, 23.976 fps, pos 0, track { TT_SOUND, 4},
    ! : 'ASourceClip'; GlobalOffset 2860; len 44, 23.976 fps, pos 45492, track { TT_SOUND, 1},
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 1},
    ! : AAFmobID 060a2b340101010101010f0013-000000-5372736368420078-060e2b347f7f-2a80, OMFmobID 42.1400009571.7891010
    ! : 'ASelector'; GlobalOffset 3676; len 52, 23.976 fps; 2 trks, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 2},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 3},
    ! : 'ASelector'; GlobalOffset 3728; len 96, 23.976 fps; 3 trks, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 3},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 4},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 5},
    ! : 'ASelector'; GlobalOffset 3824; len 1648, 23.976 fps; 4 trks, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 4},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 5},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 6},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 7},
    ! Track 11 { TT_SOUND, 2}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 8},
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 9},
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 10},
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 11},
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_SOUND, 7},
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_SOUND, 8},
    ! : ! 'ASourceClip'; GlobalOffset 2840; len 12, 23.976 fps, pos 0, track { TT_SOUND, 9},
    ! : ! 'ASourceClip'; GlobalOffset 2852; len 8, 23.976 fps, pos 0, track { TT_SOUND, 5},
    ! : ! 'ASourceClip'; GlobalOffset 2852; len 8, 23.976 fps, pos 0, track { TT_SOUND, 6},
    ! : 'ASourceClip'; GlobalOffset 2860; len 44, 23.976 fps, pos 45492, track { TT_SOUND, 2},
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 2},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 4},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 5},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 6},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 7},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 8},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 8},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 9},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 10},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 11},
    ! Track 12 { TT_SOUND, 3}; cc 0, csc 0
    ! 'ASequence'; GlobalOffset 0; len 5472, 23.976 fps; 6 subComponents
    ! : 'ASelector'; GlobalOffset 0; len 2840, 23.976 fps; 1 trk, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 12},
    ! : 'AFillerClip'; GlobalOffset 2840; len 64, 23.976 fps
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 3},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 6},
    ! : 'ASelector'; GlobalOffset 3728; len 96, 23.976 fps; 1 trk, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 9},
    ! : 'ASelector'; GlobalOffset 3824; len 1648, 23.976 fps; 1 trk, TGM_NORMAL; selected 0
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 12},
    ! Track 13 { TT_SOUND, 4}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 13},
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 4},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 7},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 10},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 13},
    ! Track 14 { TT_SOUND, 5}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 14},
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 5},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 8},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 11},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 14},
    ! Track 15 { TT_SOUND, 6}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 15},
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 6},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 9},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 12},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 15},
    ! Track 16 { TT_SOUND, 7}; cc 0, csc 0
    ! : ! 'ASourceClip'; GlobalOffset 0; len 2840, 23.976 fps, pos 0, track { TT_SOUND, 16},
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 7},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 10},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 13},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 16},
    ! Track 17 { TT_SOUND, 8}; cc 0, csc 0
    ! 'ASequence'; GlobalOffset 0; len 5472, 23.976 fps; 5 subComponents
    ! : 'AFillerClip'; GlobalOffset 0; len 2904, 23.976 fps
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 8},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 11},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 14},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 17},
    ! Track 18 { TT_SOUND, 9}; cc 0, csc 0
    ! : 'ASourceClip'; GlobalOffset 2904; len 772, 23.976 fps, pos 0, track { TT_SOUND, 9},
    ! : ! 'ASourceClip'; GlobalOffset 3676; len 52, 23.976 fps, pos 0, track { TT_SOUND, 12},
    ! : ! 'ASourceClip'; GlobalOffset 3728; len 96, 23.976 fps, pos 0, track { TT_SOUND, 15},
    ! : ! 'ASourceClip'; GlobalOffset 3824; len 1648, 23.976 fps, pos 0, track { TT_SOUND, 18},
    ##### Clip and Source Summary for 'MultiGroup.03': (5/13/14 12:33:34 PM)
    ##### Created using: Avid Media Composer 7.0.3.2815
    20 clips found.
    Subclip V1 A1-2 050914 A05.new.01.sub.01
    Subclip V1 A1-2 050914 A05.new.01.sub.02
    Subclip V1 A1-2 050914 A06.new.01.sub.01
    Subclip V1 A1-2 050914 A06.new.01.sub.02
    Subclip V1 A1-2 050914 B02.new.01.sub.01
    Subclip V1 A1-2 050914 B02.new.01.sub.02
    Subclip V1 A1-2 050914 B02.new.01.sub.03
    Subclip V1 A1-2 050914 B02.new.01.sub.04
    Subclip V1 A1-2 050914 B03.new.01.sub.01
    Subclip V1 A1-2 050914 C02.new.01.sub.01
    Subclip V1 A1-2 050914 C02.new.01.sub.02
    Subclip V1 A1-2 050914 C02.new.01.sub.03
    Subclip V1 A1-2 050914 C03.new.01.sub.01
    Subclip V1 A1-2 050914 C03.new.01.sub.02
    Subclip V1 A1-2 050914 C03.new.01.sub.03
    Subclip A1-7 SHOOTDY13/03.sub.01
    Subclip A1-9 SHOOTDY13/04.sub.01
    Subclip A1-9 SHOOTDY13/04.sub.02
    Subclip A1-9 SHOOTDY13/04.sub.03
    Subclip A1-9 SHOOTDY13/04.sub.04
    ########## Tape Source Info: ##########
    4 tape-based sources found.
    __________ TAPE NAME __________ __________ PROJECT NAME __________ __________ TAPE ID __________
    14Y05M09 BP ASSIST
    14Y05M09A BP ASSIST
    14Y05M09B BP ASSIST
    14Y05M09C BP ASSIST
    No import-based sources found.
    ##### Effect Summary for 'MultiGroup.03': (5/13/14 12:33:34 PM)
    No effects found in 'MultiGroup.03'.
  • Tue, May 13 2014 8:50 PM In reply to
    Sorry...you were correct, I was thinking of a different release.  According to the Version matrix, MC v7.0.3 is indeed qualified on OS X 10.9.1.
    Let's see if anyone else here has an idea about the issue.  I admit I'm not a big user of Multigroups so I may not be of much help.
  • Thu, Jun 11 2015 5:57 PM In reply to
    Hey guys --
    I had this same issue this morning, figured it out.
    Select all your subclips, right click, goto 'source settings...', then remove any LUT that may have been applied, if you apply a lut (intentionally or not) it does something that the grouping really doesn't like
    On newer versions of AVID, the error won't pop up, it will open the multigroup.01 but only play the first subgroup pairing.
    Hope this helps.
  • Tue, Jun 16 2015 8:41 PM In reply to
    I am having this same exact error except my footage does not have any luts applied at all.
    Error reads: AVID MONPANE::SETCOMPOSITION(): INTERNAL ERROR OCCURRED TRYING TO LOAD COMPOSITION INTO THE MONITOR.
    AVID: 8.3.1
    OSX: 10.9.5
    Has anyone else found a solution to this issue? I need to get this solved ASAP.
  • Tue, Jun 16 2015 8:53 PM In reply to
    kristenselph:
    AVID: 8.3.1
    OSX: 10.9.5
    Have you selected your subclips, right clicked, and checked 'source settings...' ?
  • Thu, Jun 25 2015 4:40 PM In reply to
    • CrystalRC
    • Posts 9
    • Points 65
    Thanks! I am a bad AE because I too figured it out but I forgot to post an update. So thank you thank you!
  • Sat, Jun 27 2015 9:52 PM In reply to
    So i've been having this same problem and also the other flavor of this problem when the multigroup will only contain the first subgroup.  I've been working in MC 8.3.1 on 10.10.2
    I've found a crazy handwaving workaround. I'm not sure why this fixes it, but it does.
    In your group, try to figure out which camera is causing the multigroup to fail. For me, it's been one of the Go Pros being used on our shoot. Usually, the "bad" camera will be one of the first clips on your timeline. Once you've figured out which one is causing the problem, trim that camera clip back so it won't be in the first subgroup created.  Again, with my problem, I'll trim the problematic Go Pro clip back a second or two, so that the first subgroup will only have A or B cam.  Create the subclips and multigroup as normal, and the multigroup will work properly now.
    I've got to think it's got to be some weird bug in Avid, because if you look at all the subgroups created for these problem multigroups, those look OK. Before I came upon my work around, I was just giving the editors the subgroups whenever I ran into this.
