Latest post Fri, Nov 8 2013 12:03 AM by Mondo. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Sep 25 2013 11:33 AM
    AMA Files and the Media Database
    Simple question, where does AVID store the DB for the AMA files?
    Hoping it's not the drive with the AMA Files..
    And if so, is there any way it can be shut off so that it doesn't create a database for AMA files?
    2 x Symphony 5.5 DX (XW8600) 5 x MC5.5 , 1 Nitris DX, 3 Mojo SDI (3xXW8600 1XZ400) 2 AJA IO, 1 Matrox (3 x Z400) 1 Lanshare (4TB) 1 ISIS 5000 2 External... [view my complete system specs]
  • Wed, Sep 25 2013 9:43 PM In reply to
    Re: AMA Files and the Media Database
    If I'm understanding you correctly...
    Avid does not do the same thing with AMA-linked clips as it does with it's own MXF clips.  Avid's media is stored in said database and tracked inside, but AMA-linked clips use file path and file name to track media.  So it's not really adding assets to the database inside the Avid Media Files folder, just simply retaining the source file name and path.
  • Wed, Sep 25 2013 9:48 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,312
    • Points 40,065
    Well, I think I read some where that with MC 7, there is some type of AMA database going on now.  Not sure if that is true or what the story is.
    Jef
    Jef Huey
  • Wed, Sep 25 2013 10:00 PM In reply to
    I guess it makes sense - I know with Avid Interplay Version 3.0 their allowing AMA'ed files to be checked-in to Interplay, but I think that uses the same concept with the file path.  But where that database file itself is being retained, I do not not.  It may just be an extension into the database file with Avid Media Files folder.
    Do you know where you read / heard that?  I'd be curious to read that myself.
  • Wed, Sep 25 2013 10:33 PM In reply to
    On my Mac-based system, they are here.  Note that they are named "amaFMID.pmr" and "amaMMOB.mdb", instead of "msm..."
    (wwld)
  • Wed, Sep 25 2013 10:50 PM In reply to
    Interesting!  So it looks like you're right, it does create a separate DB file for the AMA and stores it within your local drive where the application is stored.
    I'm guessing you answered you're own questions then?
    Did you create the AAF files, or was that created by Avid (and do those names correspond with the names of your media)?  It looks like Avid just utilizing AAF matched with the DB file to track the assets.
    I wonder if you can change where that DB file is saved.
  • Thu, Sep 26 2013 11:38 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,610
    • Points 60,240
    I wonder what happens if you delete the AMA database? Can it be fully reconstituted or will you have permanent data loss. In other words, is this another folder that should be backed-up?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.11 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64 |... [view my complete system specs]
    Steve
    www.nelliedogstudios.com
  • Thu, Nov 7 2013 1:08 AM In reply to
    • Hershleder
    • Los Angeles, California, USA
    • Posts 150
    • Points 1,790
    Thanks Randy. I was trying to remember this too. Cheers!
    MacBook Pro 2.5 GHz, i7 – OS 10.10.5 – 16 GB RAM – MC version 8.6.x - Adobe CC. [view my complete system specs]
    Use your Avid super-powers for good, not evil:
    "The Avid Media Composer Cookbook"
    http://tinyurl.com/avidmc-book
  • Thu, Nov 7 2013 3:26 AM In reply to
    • bastian
    • Joined on Fri, Jan 20 2006
    • Brisbane, Australia
    • Posts 68
    • Points 860
    See this post for an interesting discussion about the AMA database
    http://community.avid.com/forums/t/123345.aspx
    Avid 1 - Lenovo D30 & Nitris DX, Win 10 Pro, MC 8.9, Asus GeForce GTX 1050Ti, 32gig ram, Proavio EB800MS 16TB array & LSI MegaRaid HBA :: Avid... [view my complete system specs]
  • Thu, Nov 7 2013 12:25 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,610
    • Points 60,240
    Great link. Sounds like the developers have a bit more work to do to round-out the AMA data management feature.
    Steve
  • Fri, Nov 8 2013 12:03 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    And this one - seems you can dlete it without any impact..
    http://community.avid.com/forums/t/123659.aspx
    John
