Hi - I am using Avid MC 6.5.2 on an Imac and have discovered that if you want to advance or retard in the source monitor using the numeric keypad, the Avid crashes. It only crashes on the source monitor side and we have tested this on two different Avids (both 6.5.2) and both crash. Also it dosent crash when filler is loaded into source monitor rather than media.
Sea....
there were a few issues fixed in 6.5.3 - so I recommend you upgrade. You can snag it off the DL center.
I'm having the same issue on V7.0.3 running on windows 7, except both the source and record side will crash the system if I enter a value using the keypad. ie: 123+(enter) will crash the system. Anyone else?
No problem on my system but no Mojo DX here. I'm running software only.
Does it happen without the DX? Does this happen if you make a new project? Does it happen if you make a new user profile?
Scott
I tried different projects and user profiles and am still having the same problem, and its driving me mad! Has anyone found a solution?
