Latest post Tue, Apr 9 2019 3:21 PM by Jeroen van Eekeres. 28 replies.
Page 1 of 2 (29 items) 1 2 Next >
  • Thu, Sep 12 2013 11:24 AM
    Exception: Structured Exception, ExceptionCode: 3221225477, ExceptionString: Access_Violation
    I'm receiving this message upon loading Media Composer 7.0.2 via Editshare. When I load it from the desktop icon it works fine, however via Editshare when it gets to 'Initializing Import/Export' the error appears. I can only click ok & it dumps me back to the desktop. This has only occured since I upgraded to 7.0.2 this morning. I have uninstalled/reinstalled Editshare to no avail, unistalled/reinstalled MC 7.0.2, and even downgraded again to 7, all with no success. The message still appears.
    Anyone have any thoughts?
    Stephen
    MC 7.0.2/7 | Win 7 Pro SP1 64bit | HP Elitebook 8770w, i7-3610QM 2.3Ghz, 16GB RAM, Nvidia Quadro K4000M [view my complete system specs]
  • Fri, Oct 31 2014 5:47 PM In reply to
    Re: Exception: Structured Exception, ExceptionCode: 3221225477, ExceptionString: Access_Violation
    I am getting the same error using the latest verion of Media Composer 8
    Lenovo Thinkpad W530 24GB QUADRO 2000 Symphony 8.3 win 7 64bit pro & Toshiba Portage Laptop i5 8gig ram. Media Composer 8.3 [view my complete system specs]
  • Tue, Nov 18 2014 5:49 PM In reply to
    • A
    • Toronto
    • Posts 56
    • Points 770
    I too am getting the ExceptionString Access_Violation.  But it occurs each time I come out trim mode and hit play.  As you can imagine, it's a frustrating issue:
    Exception: Structured Exception, ExceptionCode: 3221225477, ExceptionString:ACCESS_VIOLATION, FaultAddress:0X0000000140AD7B7B, MiniDumpFileName:39ddcfe1-d7f8-477e-87b6-9a4518988fbc6.dmp
    I did a database rebuild as well as rebuilding my keyboard settings from scratch and that didn't solve the issue.  Any other suggestions on how to correct this problem would be great!
    Cheers,
    -Richard
    Currently Running:
    Avid Media Composer / Symphony 8.1 with Nitrox DX
    HP Z800, Intel(R) Xeon(R) CPU X5650 X 2.67 GHz 2.66 GHz, 24 GB of RAM, Windows 7, Terrablock Stoage
    HP Z420 Workstation | Intel Xeon CPU E5-1620 @ 3.60 GHZ 3.60 GHz | 32 Gigs of RAM | NVIDIA® Quadro® K2000 | Windows 10 Pro 64 Bit | Blackmagic Design... [view my complete system specs]
  • Wed, Jan 28 2015 8:57 AM In reply to
    • juako
    • Joined on Fri, Sep 15 2006
    • Posts 59
    • Points 740
    Here same error!!! Any solution??????
  • Thu, Jan 29 2015 11:36 AM In reply to
    • Konrad
    • Joined on Fri, Apr 11 2014
    • Szumowski
    • Posts 8
    • Points 100
    I have the same problem,
    clean Avid Mc 7.0.3 on fresh Windws 7 (system buildup after bluescrren) I can't import or export files, having the same Acces Violation
    6x i7 4770k with MC 8.2 BM Decklink Extreeme, Avid Symphony/DS on XW8200, 2x MC 5.5.3 on XW8400 with A Adrenaline DNxCel, Avid Unity 16TB [view my complete system specs]
  • Thu, Jun 4 2015 11:39 AM In reply to
    • JackMole
    • Joined on Thu, Jun 4 2015
    • Posts 1
    • Points 15
    Also have the same error.
    MC 7.0.4.1 via Editshare- no one seems to have answers?
  • Mon, Feb 22 2016 2:01 PM In reply to
    • brawur
    • Emden
    • Posts 44
    • Points 535
    I am having the same problem now with MC 8.5
    MC with Symphony Option on Windows 10, on dual Intel E5 2670, EVGA SR-X with 32 GB RAM G.Skill, Quadro K-5000 4 x 2TB Videoraid, System on SSD, Render... [view my complete system specs]
    Dual Opteron 275, NVidia Quaddro FX3700, 4GB, Windows 7
  • Thu, Sep 1 2016 1:18 AM In reply to
    • Jurtly
    • Joined on Thu, Sep 1 2016
    • Posts 1
    • Points 15
    Did anyone ever get an answer?! I am having the same issue for AVID NEWSCUTTER NITRIX DX.
  • Tue, Sep 6 2016 4:21 PM In reply to
    • brawur
    • Emden
    • Posts 44
    • Points 535
    I got this advice from Avid Support.
    It might be that the site settings are corrupt. Try resetting these:
    C:\Users\Public\Public Documents\Avid Media Composer\Settings (rename the folder to something else like 'Settings1' and then restart the Media Composer)
    And it worked for me.
  • Mon, Jan 16 2017 11:17 AM In reply to
    • Nic.G.
    • Joined on Wed, Sep 29 2010
    • Posts 3
    • Points 35
    I've just installed 8.7 and can't do anything without this error message coming up. Renaming the Settings folder seems to have worked for now though as a fresh one was created.
  • Thu, Mar 16 2017 12:26 PM In reply to
    • brawur
    • Emden
    • Posts 44
    • Points 535
    Meanwhile deleting the "Settings"-Folder does not help anymore.
    But I found out, that the problem is only occouring if my Panasonic P2 AMA Plugin ist installed.
    It is the latest Version 4.7 of the Plugin for MC 8.4,3 an above.
    So maybe the real problem is somwhere within the plugin.
    I would be interested, if you are running this combination without any problems.
  • Thu, Jul 20 2017 2:39 PM In reply to
    I have the same problem. Nothing seems to help.
    MB: ASUS P6TD Deluxe, ATX, Intel X58, QPI 6.4GT/s, Intel LGA1366, 6xDDR3 1600MHz, PCI-E V2.0, On-board Soundkarte. CP: Intel Core i7 920 (2.66 GHz) Quad... [view my complete system specs]
  • Mon, Jan 29 2018 6:27 PM In reply to
    • Melissa
    • Joined on Wed, Apr 12 2017
    • New York
    • Posts 6
    • Points 130
    I am having this same issue on multiple machines (we're on an ISIS network, sharing projects).
    One editor got this error when he hit play on the timeline, clicked out of the error and was able to continue working fine.
    I got this error when creating a new project. I clicked out of it and the project creation settings let me progress. However, I recived the error again 3 times while opening this new project before it finally dismissed.
    We recently updated to 8.8.5
    Anyone learn what is causing this error?
    Z820, 32GB RAM, Windows 7 ISIS 5500 and Interplay Environment [view my complete system specs]
  • Mon, Jan 29 2018 8:13 PM In reply to
    • Posts 10,204
    • Points 218,090
    Melissa
    Can you shed light on what media you are using ( format and kind ) and what comuters and OS?
    Any crash logs generated?
  • Mon, Jan 29 2018 8:39 PM In reply to
    • Melissa
    • New York
    • Posts 6
    • Points 130
    Hi Marianna,
    We are running MC 8.8.5 on Windows 7 on Z820s. All our media is transcoded (from multiple formats) to DNX 220x MXF in-program.
    I did generate a crash log after I recieved the error while trying to create/open a new project, but I can't make any sense of it.
    Here's a download link to that crash report:
    https://we.tl/H0cdWcAPdm
