Latest post Mon, Aug 5 2013 4:31 PM by Carlos Sardá. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Jul 31 2013 7:13 AM
    • Ian Nicholson
    • Joined on Mon, Aug 9 2010
    • Sydney, Australia
    • Posts 65
    • Points 965
    MC7 - Monitors turn green!
    Hi!
    I've been cutting on MC7 all day and finally went to playback by project.
    Half way through, the timeline monitor began flickering in a bright, baize green, before going solid, upon which, MC7 hung. Windows 8 reported the program had stopped responding, etc...
    Restarting Avid, it started to do it again!
    Any ideas?!
    It's been playing fine all day, and no other Windows applications appear affected.
    MC 8.5.0 on Intel i7 3770K 3.8GHz, Gigabyte GA-Z77X-D3H, nVidia GTX670 2GB, 16GB RAM, 2 x 128GB SSD, 13TB disk, 2 x HP 2711x 27" LED monitors, Windows... [view my complete system specs]
    Filed under: , ,
  • Wed, Jul 31 2013 7:31 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,305
    Re: MC7 - Monitors turn green!
    Ian, you are of course aware of that you are using an uncertified videocard, my guess is that this is the place to start troubleshooting.
    And, of course, " have worked earlier "  is no warranty that it should continue to do that
    Tomas
  • Wed, Jul 31 2013 11:09 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,294
    • Points 53,120
    More revelant, it is likely you should return the CPU to its normal clocking. An overclocked CPU will cause problems like this.
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Wed, Jul 31 2013 12:31 PM In reply to
    • Posts 9,199
    • Points 205,330
    TVJohn:
    +1
    Regards
    Douglas
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Mon, Aug 5 2013 2:19 PM In reply to
    • Ian Nicholson
    • Sydney, Australia
    • Posts 65
    • Points 965
    Hi All,
    Ok, so I restored my PC to default clock settings, but I still get the monitors turning green, closely followed by a hanging of Avid MC7.
    I am finding MC7 to be terribly unstable and buggy. If, for example, I go to Help->Read me, I get a browser window that opens and cannot be closed, which renders the rest of Avid unresponsive and I have to use Windows Task Manager to stop the task.
    Worse, is that there is some strange corruption of my projects. Recent changes to a sequence are being replace by (it seems) a recently-created sequence. That's scary.
    Very frustrated with all this. I had MC5.5 before and while it had its foibles, it was certainly a lot more reliable than MC7 is turning out to be.
    It really bugs me when a maker of professional software leaves quality control to the customer base.
    This green screen issue should NOT, in the 21st century, be a product of overclock issues or memory card and/or drivers.
    Come on Avid, sort these things out!
  • Mon, Aug 5 2013 2:31 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,305
    mjolnarn:
    Quoting myself once more
    Tomas
  • Mon, Aug 5 2013 2:52 PM In reply to
    Also, have you checked to be sure that you are running the proper versions of Quicktime and video drivers?
  • Mon, Aug 5 2013 3:45 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,328
    • Points 16,310
    The videocard is uncertified but frankly, that one should work okay.
    Nvidia cards are pretty notorious for heat failures though, and being in a metal box with an overclocked processor is a good recipe for that.  I would give the card a physical inspection and see if anything looks damaged.
  • Mon, Aug 5 2013 4:31 PM In reply to
    .- You CPU is overclocked, that can also cause stability issues.
    Don't know if your GPU also is
    The GeForce, although not supported, should work fine.
    A green display (specially with scattered pixels) usually means too much GPU overclock or a Bad video card.
    Lenovo E32 ThinkStation Intel Xeon E3-1245,16GB RAM, Nvidia Quadro 600 (1 GB), Windows 10 Pro x64 (up to date) USB 3.0, Lite-On SSD 256GB System Drive... [view my complete system specs]
    Remembering my friend Larry Rubin
