Latest post Wed, Jul 3 2013 10:43 PM by TrevorA. 4 replies.
  • Tue, Jul 2 2013 1:57 PM
    Broadcast Safe
    Hi all
    Quick question....does placing a color effect on the top track still clamp everything down to Broadcast safe like it used to? If not...anyone have a quick way to do that?
    TIA
    AT
  • Tue, Jul 2 2013 2:08 PM In reply to
    Re: Broadcast Safe
    Best to use the safe color limiter effect.
  • Tue, Jul 2 2013 2:18 PM In reply to
    • Ben Wilson
    • Joined on Thu, Jun 10 2010
    • Columbia, SC
    • Posts 218
    • Points 2,500
    Re: Broadcast Safe
    Just be careful of how much video you try to clip.  If levels are excessive you will have a lot of blown out hot spots on the parts of your video that get clipped.
    Several. 1x MC7.0.4 HP z800 dual XEON x5650-2.66GHz 12MB Ram Quadro FX3800 NitrisDX. 4 TB GSPEEDes storage. 2x MC 7.0.4 HP z420 MatroxLE. GSpeedQ 8TB... [view my complete system specs]
  • Wed, Jul 3 2013 10:31 AM In reply to
    • udosauer
    • Hamburg, Germany
    • Posts 448
    • Points 5,255
    Re: Broadcast Safe
    Use the safe color effect and set it to RGB 0-100%, composite can be turned off, check "422 safe"
    2x HP Z800 with Mojo DX and MC7.0 | 1x HP Z800 with Nitris DX and MC7.0+SYM-Option | 1x Unity MEFC5 [view my complete system specs]
  • Wed, Jul 3 2013 10:43 PM In reply to
    • TrevorA
    • Posts 1,123
    • Points 12,760
    Re: Broadcast Safe
    udosauer:
    It's RGB 16-235. But actually 13-238 seems to be acceptable.
    Although a colour correction with the master curve set with black at 13=13 and white at 238=238 seems to do the exact same job. And you can grade with it too (carefully). Less render, get home quicker
