Latest post Thu, Mar 23 2006 7:08 PM by epolito. 9 replies.
Page 1 of 1 (10 items)
  • Sun, Mar 12 2006 6:52 AM
    • gringojack
    • Joined on Sun, Mar 12 2006
    • TOULON FRANCE
    • Posts 2
    • Points 55
    Angry [:@] Avid free DV doesn't work at all
    I installed AVID Free DV, I keyed the 2 numbers in, I rebooted
    At start up, I get a large white window that says "unregistered product", and a small dialog box says: ADM_DSOUND_MIXER_OPEN_ERROR
    The 2 keyed in numbers look like this:  (Serial number) AvidFreeDV-AA05 and (Authorization code) XXXX-XXXX-XXXX-XXXX-XXXX
    Downloaded file name is: AvidFreeDV_1.6.1.zip
    I have:
    Realtek ALC 882
    Nvidia ge force 6600
    DirectX 9.0 C
    my system is WIN XP SP2 CPU 2 x 2.8Ghz RAM 1Go HDD 250Go
    I installed, reinstalled and reinstalled....... it happens the same thing all the time. This is discouraging for someone interested!
    Let's see it an other way: Is my system OK to get AvidFreeDv at work? if not, I'll aim towards an other application (it works perfectly well with Adobe Premiere Elements 2)
    Someone can help? Thank you
    RAM 1Go CPU 2 x 2,8GHz Audio Realtek WIN XP SP2 HDD 250Go HDD 150Go HDD 080Go [view my complete system specs]
    Thank you see you later!
  • Sun, Mar 12 2006 9:07 AM In reply to
    • davekop
    • Joined on Thu, Mar 9 2006
    • Tel Aviv
    • Posts 5
    • Points 55
    Sad [:(] Re: Avid free DV doesn't work at all
    Hey there Gringo Jack, I am in the same boat I believe. Although I seem to have got the application up and running it does not seem to capture. One thing I did find out was that one has to unplug any webcams and microphones you have connected, even if they are not running. I have to say that these glitches are also discouraging me from pursuing this too far.
    Dave Copeland
    Avid Free DV, Win XP, Intel Pentium 4, 1.70GHz, 256RAM, Creative audio PCI, NVIDIA GeForce FX 5700. Two hard drives (120 and 40 GB) [view my complete system specs]
  • Sun, Mar 12 2006 10:52 AM In reply to
    • gringojack
    • TOULON FRANCE
    • Posts 2
    • Points 55
    No [N] Re: Avid free DV doesn't work at all
    hi davekop
    I discourage! Something must go wrong in that stuff. Perhaps the downloaded version is not OK for the serial numbers notified. Someone from AVID should tell us what to do in that case. Did I  do anything wrong way? Is my system not good enough? Am I too stupid to play with that piece of software? Did I forget to read one page or a paragraph(!)?
    Thank you AVIDPEOPLE for not letting us in this situation!
  • Sun, Mar 12 2006 3:53 PM In reply to
    • camoscato
    • Posts 6,079
    • Points 72,940
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Hi guys,
    Here's a post dealing with the dsound error you're getting:
    http://www.avid.com/exchange/forums/27329/ShowPost.aspx
    Avid is very specific about what components will work with their software.  Take a look at the system requirements for Free DV and see how your systems compare:
    http://www.avid.com/freedv/sysRequire.asp
    While you're there, click on the requirements for Xpress DV, as they're very similar.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Mon, Mar 20 2006 2:48 PM In reply to
    • elcue
    • Joined on Mon, Mar 20 2006
    • Texas
    • Posts 2
    • Points 30
    Angry [:@] Re: Avid free DV doesn't work at all
    Just letting you know  the problem still exists  . I just downloaded AVID free DV on 03/19/06 and it says I am not registered  and get the same ADM_DSOUND_MIXER_OPEN_ERROR message .
     The program just closes with no hint of how to correct problem .
        ELCUE
    Motherboard ASUS P5WD2-E Premium Windows XP PRO. Pentium 4- 3.4 GHZ RAM 1GB PC2-4200 DDR2 533 PNY PCI EXPRESS PROFESSIONAL VIDEO EDITION FX 540... [view my complete system specs]
  • Mon, Mar 20 2006 3:15 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 4,279
    • Points 48,025
    • BlogAuthor
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Dell Precision 650, 3.06 Ghz, 2 SCSI drives, 600 GB LaCie D2, 3 GB Ram, Nvidia FX500 Suite 1. Avid Media Composer v4.0, Avid Studio Toolkit v 5.7, Pro... [view my complete system specs]
  • Tue, Mar 21 2006 12:32 AM In reply to
    • chalk-x
    • Joined on Thu, Feb 9 2006
    • Shreveport Louisiana
    • Posts 17
    • Points 195
    Hmm [^o)] Re: Avid free DV doesn't work at all
    I could not make AvidFreeDV work with my on-board RealTek audio system.  I installed a Soundblaster Audigy card, and AvidFreeDV has worked flawlessly ever since.  Your error message looks very similar to what I was getting.  Maybe your present sound system is incompatible?
    Good luck...Chalk-X
    ECS 945P-A motherboard with Pentium D 820 dual core processor, 2gb dual channel ram, GeForce 6600LE video card, SoundBlaster Audigy sound card, Adaptec... [view my complete system specs]
    It's all about knowing where to put the "X"...
  • Tue, Mar 21 2006 12:35 AM In reply to
    • xyedit
    • Boston, MA
    • Posts 2,119
    • Points 26,975
    That's basically what the link that Adman posted is saying.
    Dell PWS360 P4 2.4GHz 1.5GB RAM 80GB system drive 500GB internal SATA2 media drive >1TB... [view my complete system specs]
    Kenton VanNatten (will edit for money)
  • Wed, Mar 22 2006 10:51 PM In reply to
    • elcue
    • Texas
    • Posts 2
    • Points 30
     I had the same problem .      ( ERROR )  ADM_DSOUND_MIXER_OPEN_ERROR
             I found an OLDER Sound Blaster Live  audio card  in my no longer used pile . I found the drivers for XP at the Creative Lab website . Installed the card and drivers only .
             Clicked on AVID  and it opened up properly .
      My onboard sound is Realtec also and it on an ASUS P5WD2 -E  Premium  Motherboard . It works great  but not compatible with AVID free DV .
             If  I want to  use on board sound for surround sound system , I just on boot up reenable it  . Then if going to use Avid I disable on board sound on boot up .   Hope this helped .
        Edward L.
  • Thu, Mar 23 2006 7:08 PM In reply to
    • epolito
    • Posts 4
    • Points 20
    Realtek audio cards will not work with any avid product. Unfortunately there is no other remedy other than upgrading audio hardware to a compatible one i.e. creative labs
    Music, TV, Computing [view my complete system specs]
    Authorized Adrenaline system specs: HP Workstation xw8200 - Xeon CPU 3.40 Ghz - 3 Gb RAM Nvidia Quadro FX1400 Media COmposer Adrenaline HD v2.2.9 Windows XP Pro SP2
