Latest post Fri, May 17 2013 2:38 PM by Terry Snyder. 6 replies.
Page 1 of 1 (7 items)
  • Fri, May 17 2013 10:09 AM
    • ER-EM
    • Joined on Mon, Sep 5 2011
    • Paris-France
    • Posts 45
    • Points 580
    Is there a way to refocus a blurry shot
    Hy everybody,
    I must correct a shot which is lightly blurry. For the moment I apply BCC Noise Reduction.
    I'd like to know if there's another effect that give better results.
    Many thanks in advance for your repplies.
    Richard
    Avid Symphony 6.0.3.3 - Dongle activation MacPro 2x2.93 GHz 6-Core Intel Xeon - 16Go Ram - ATI Radeon HD 5770 - 2x 4To 7200rpm in Raid 0 - Os X 10.7.5... [view my complete system specs]
  • Fri, May 17 2013 10:34 AM In reply to
    Re: Is there a way to refocus a blurry shot
    Hi Richard,
    BCC Unsharp Mask sometimes helps with slightly blurry shots.
    ciao,
    Carl
    Media Composer 2018.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Fri, May 17 2013 11:59 AM In reply to
    • bmedia
    • Princeton, NJ
    • Posts 88
    • Points 1,070
    The Avid Paint effect can also sharpen.
    HP Z220 with 3.4 GHz Intel Xeon / NVIDIA Quadro K1200 / 24GB RAM / Windows 7 / Media Composer 8.5.2 with Symphony Option | 15" MacBook Pro with 2... [view my complete system specs]
  • Fri, May 17 2013 2:02 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,328
    • Points 16,310
    ER-EM:
    Noise reduction actually softens the image, so that's probably not the way to go.  Unless it makes the difference between in-focus and out-of-focus less noticeable.
  • Fri, May 17 2013 2:04 PM In reply to
    • ER-EM
    • Paris-France
    • Posts 45
    • Points 580
    Many thanks to all !!!
    BCC Unsharp Mask works fine !!!
    Happy editing !!!
  • Fri, May 17 2013 2:08 PM In reply to
    In my experience, ot tends to work best if you sharpen just a part of the frame (e.g. a character's eyes). I often used Animatte to draw and track a shape of the sharpened part.
  • Fri, May 17 2013 2:38 PM In reply to
    I once saw an editor use a neat trick.  We had to use a critical shot that was in soft focus.   It stuck out like a sore thumb when cut in between two shots that were in sharp focus.   So the editor placed an add-edit 45-frames before the end of the previous shot, added a slight BCC blur effect, then a 90-frame dissolve centered at the cut.   The effect was to gradually blur the footage before cutting to the blurry shot.   He did the same thing to the shot following the blurry shot, adding an add-edit 45-frames into the shot, then adding the blur and dissolve.   This technique minimized the juxtaposition of the blurry shot with the sharp footage coming before and after it.   The blurry shot was still blurry but less noticable.    A neat trick...
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
