Latest post Sat, Mar 11 2006 10:58 PM by Effect-if. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Mar 10 2006 5:47 PM
    • Alex83
    • Joined on Thu, Mar 9 2006
    • Posts 8
    • Points 120
    Crying [:'(] Open an Avid Xpress project with Avid Liquid
    I have a project created in Avid Xpress Pro.
    Is there a mode to import this project in Avid Liquid?
    Help me!
    Thanks to all.
  • Fri, Mar 10 2006 6:12 PM In reply to
    • editzz01
    • Joined on Wed, Nov 23 2005
    • Montreal
    • Posts 770
    • Points 9,225
    Re: Open an Avid Xpress project with Avid Liquid
    Export from Xpress as ALE, import as ALE into Liquid....should work...that said, I'm not in front of Liquid at the moment, am at my Liquid Blue station and this has this function....I am thinking that Liquid also does.
    Mark
    Work system Symphony Nitris classic 3.5.1 Vista business 64 12GB ram 10 TB Avid media drive Home system Media Coposer 3.5.1 Dual 3.2 Xeon 2.0MB... [view my complete system specs]
  • Fri, Mar 10 2006 6:49 PM In reply to
    • renniedj
    • Tampa Fl
    • Posts 241
    • Points 3,045
    yes AL can import an ALE
    Two Machines For SD - Gateway 3.4 P4 HT, 1 Gig RAM, PCIe ATI X700 Pro, Audigy 2ZS, 250 Gg System Drive, 200 Gig Video drive, a 320 G-Tech Raid 0 Dive... [view my complete system specs]
    For SD - Gateway 3.4 P4 HT, 1 Gig RAM, PCIe ATI X1050 Pro, Audigy 2ZS, 250 Gg System Drive, 800 Gig Video drive. For HDV a Dell XPS 400 with 3.2 Ghz Dual Core Pentium D, 2 Gigs of RAM, 2 300 Gig video drives, 250 Gig system drive, ATI X1800XT PCIe X16.
  • Fri, Mar 10 2006 7:51 PM In reply to
    • Alex83
    • Posts 8
    • Points 120
    My Avid Xpress Pro HD 5.0 not allowed to export a project as ALE but only a sequence.
    If I try to save my sequence as ALE the icon doesn't appear in the selected folder.
    I can save a project only as AFE.
    Can I export and import an OMFI file?
  • Fri, Mar 10 2006 8:59 PM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,482
    • Points 17,515
    With Liquid, at this moment, you can only export OMFI files.
    Media Composer 8.9.3 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red 5... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Fri, Mar 10 2006 9:05 PM In reply to
    • Alex83
    • Posts 8
    • Points 120
    How can i import a project if Xpress not allow to export an ALE?
  • Fri, Mar 10 2006 9:46 PM In reply to
    • Sylvain P
    • Posts 1,482
    • Points 17,515
    I tried it by clicking on the sequence folder or on a clip in a bin, it exported the ALE file. But I cannot read it in Liquid. I get a "track header error" or a missing media clip.
    I also tried to export an EDL, but I also get missing media clips.
    The long way is to export every clips or the sequence to a DV AVI file that Liquid can read. But you'll loose your sequence.
    I hope that Avid will make it easier to exchange projects in the next version of Liquid.
    Sylvain Primeau
    primeaumedias.com
  • Fri, Mar 10 2006 10:05 PM In reply to
    • Alex83
    • Posts 8
    • Points 120
    Can I import an XML file?
  • Sat, Mar 11 2006 8:24 AM In reply to
    • Sylvain P
    • Posts 1,482
    • Points 17,515
    You are supposed to be able to import XML files in Liquid, but I have not been able to do that for now.
    I can import and export clips from Liquid in ALE and XML, but not from Xpress Pro.
    When you have Liquid installed on the same system, you can export from XPro using a Pinnacle codec. You have several PCLE codecs that you can choose. You have 2YUV that is uncompressed, DVDCPro50, etc.
    Sylvain Primeau
    primeaumedias.com
  • Sat, Mar 11 2006 9:27 AM In reply to
    • Alex83
    • Posts 8
    • Points 120
    But is there a format that allowed me to export and import the informations about the sequence (cut, effects ecc.)? If I import the sequence then I'll can be a batch capture and work in AL.
    What kind of information does EDL format save?
  • Sat, Mar 11 2006 8:59 PM In reply to
    • bruise
    • Posts 128
    • Points 1,640
    an EDL is only supposed to be for an offline type edit - so cuts, maybe simple transitions. not effects etc.
    out of pure curiosity - why do you want to do this?
    XP Pro SP2 Intel P4 2.8 GHz 2.79 Gh 2Gb RAM AOC LM720/LM720A (monitor) on Matrox Parahelia 128Mb (machine not connected to the internet, has... [view my complete system specs]
  • Sat, Mar 11 2006 10:58 PM In reply to
    • Effect-if
    • Perth, Western Australia
    • Posts 132
    • Points 1,720
    Hi Alex
    Are you trying to export to project only or the project with media?
    Using ALE it will only export the project settings (sequence info, clips mark in & outs etc...) there will be no media with the file, but from this you can batch digitize the clips into AL to rebuild the project.
    How to export the Xpress Pro project using Avid Log Exchange:
    Go to Windows Start Menu / Avid / Avid Log Exchange from there open the Xpress Pro project and then open each of the "Bins" you want to convert to ALE files, save as .ale files then import into a project in AL.
    I wish AL would import OMFI files it would make this process a lot easier, how about including it into future releases of AL. Because AL has more FX power than most editing apps out there, or just so we can bring in Full and M&E OMFI mixes from ProTools or similar audio apps.
    Maybe in 7.5 or 8
    Cheers
    Brian
    WIndows XP Pro SP2, P4 3.4, ASUS P4C800E Deluxe MOBO, Gigabyte 256 R96XT, 2 Gig of Ram. Decklink Extreme Liquid Pro 6.1 After Effect 6.5 Combustion... [view my complete system specs]
    I can't remember a day where I didn't enjoy editing. Windows XP Pro SP2, P4 3.4, ASUS P4C800E Deluxe MOBO, Gigabyte 256 R96XT, 2 Gig of Ram. 2 x 200gig Sata, 2 x 250gig IDE. Decklink Extreme Liquid Pro 7.1 After Effect 6.5 Combustion 3
