Latest post Fri, May 17 2013 12:52 PM by mjolnarn. 8 replies.
Page 1 of 1 (9 items)
  • Wed, May 15 2013 7:28 PM
    • lcizatt
    • Joined on Wed, Jun 9 2010
    • Posts 104
    • Points 1,575
    60i vs 60p and MC 6.0.3
    Hi everyone,
    Just bought the Sony HDR PJ790V camcorder. Will be headed off to Supai Arizona next week and am wondering if I should record in 60i or 60p considering I will be importing into MC 6.0.3. I think 60p would be the best choice but I've read it's a pain to get it into MC. I could sure use some professional opinions at this point since I don't have time to experiment. Any tips would be appreciated.
    Layne
    Asus P6T Deluxe V2, Core i7 920, 12G Ram, GeForce GTX 260, Win7 Pro 64 bit. Media Composer 6.0.3 [view my complete system specs]
  • Thu, May 16 2013 9:43 AM In reply to
    • udosauer
    • Hamburg, Germany
    • Posts 448
    • Points 5,255
    Re: 60i vs 60p and MC 6.0.3
    Hello Layne,
    MC does not support 1920x1080@60p. So i would stick to 60i, or use another editing software.
    You also could transcode the 60p --> 60i with 3rd party software (ffmbc, squeeze, etc.)
    Udo
    2x HP Z800 with Mojo DX and MC7.0 | 1x HP Z800 with Nitris DX and MC7.0+SYM-Option | 1x Unity MEFC5 [view my complete system specs]
  • Thu, May 16 2013 2:13 PM In reply to
    • lcizatt
    • Posts 104
    • Points 1,575
    udosauer:
    Wow! That's weird.
    So I'll stick with 60i but I suppose a follow-on question is what about the future? If, perchance, MC does decide to support 60p, is 60p footage better ultimately than 60i? Seems that progressive would give better slow motion than interlaced. If interlaced is so good, why move to progressive?
  • Fri, May 17 2013 7:48 AM In reply to
    • udosauer
    • Hamburg, Germany
    • Posts 448
    • Points 5,255
    I don't know if 1080p60 will get a worldwide broadcast standard, right now it's not.
    And interlaced video will hopefully die with 4k.
  • Fri, May 17 2013 10:03 AM In reply to
    • dvandy
    • Posts 54
    • Points 725
    And 50p(or60p) in MC7?
    www-liquiduser.de
  • Fri, May 17 2013 11:18 AM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    Stick to 60i
    Be careful and test  take longer than 15 min if you transcode the 60p --> 60i with 3rd party software (ffmbc, squeeze, etc.) Take longer than say 15 min may be truncated du to spanned files on memory card.
    13 edit stations Educational MC 6.5.2 in use, MC 6.5.3 under reliability test, MC 7 under consideration workflow test, dongles with troubles, AVID ISIS... [view my complete system specs]
  • Fri, May 17 2013 11:27 AM In reply to
    • dvandy
    • Posts 54
    • Points 725
    every transcode is a lost on quality special from p to i or i to p
    so nativ 50p is what i need. Every NLE i know can do this
    www-liquiduser.de
  • Fri, May 17 2013 12:11 PM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    It came as a big surprise to us that MC 6.5.2 do not import, transcode or AMA 1080p50. While FCP and Premiere Pro do.
    Converting 1080p50>1080i50 using 3part proved to be trouble as well.
  • Fri, May 17 2013 12:52 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,344
    • Points 159,265
    Allan:
    6,5 and the Avid J2k codec supports 1080 50p, Squeeze can convert to that codec and is included for free with the 64 bits Avid
    Allan:
    After having imported that media into Avid using the command " ignore qtrate " conversion to 1080 50i works well using Avid itself.
    Tomas
