Latest post Thu, May 9 2013 4:55 PM by Larry Rubin. 4 replies.
  • Thu, May 9 2013 10:37 AM
    • hazzabazza
    • Joined on Thu, May 9 2013
    • Posts 1
    • Points 35
    Avid Play Back
    System:
    http://www.msi.com/product/nb/GX740.html
    OS Windows 7 (But can right click avid and make it run under any previous OS inluding it SP)
    64 bit
    Hi all,
    I get a message saying "Your video card either does not support playback or it needs more memory"
    Is it really because of my Graphics card? or can I install a driver?, A codec problem? or any other way for the system to playback video? Please help.
    Note:
    The software runs fine and I can even hear audio.
    I have the latest quicktime (Not Pro)
    Thanks!
  • Thu, May 9 2013 10:56 AM In reply to
    Re: Avid Play Back
    hazzabazza:
    Well, we can't advise you if we don't know what graphics card you have, or anything else about your system other than "OS Windows 7". Specifically, that needs to be "W7 Professional 64". Please take the time to fill out your system specifications. Click on your name, then "edit my profile", then "profile options" to get to the appropriate text field. Your specs will then be a permanent part of every post you make.
  • Thu, May 9 2013 10:57 AM In reply to
    Re: Avid Play Back
    Moving this to the Media Composer PC Forum.
  • Thu, May 9 2013 3:19 PM In reply to
    Re: Avid Play Back
    Also, check your computer specs against the Media Composer system requirements and version matrix.
  • Thu, May 9 2013 4:55 PM In reply to
    Re: Avid Play Back
    Please DO NOT create any duplicate threads for this issue and please follow my instructions from my two previous posts. We need that information to help you further. Also, be advised that the Vista OS is NOT QUALIFIED for version 6.
