Latest post Fri, Oct 11 2013 11:56 AM by Guy Ducker. 3 replies.
  • Wed, Mar 20 2013 5:35 AM
    • Sean
    • Los Angeles
    • Posts 13
    • Points 135
    Unable to create an audio mix down
    I had 3 reels hang up while trying to create a simple stereo mixdown of 16 tracks that were approximately 16 minutes each.  I was able to mixdown up to 8 tracks at a time or I could split the sequence in half and mixdown all 16 tracks at once, in 2 separate passes.  I was also able to export these same tracks as either stereo .wavs or Quicktimes.
    I repeated these exports on 3 additional Mac systems, with identical setups and results.  I was, however, able to export these sequences without issue on an MC 6.5.2 PC system.
    Any help would be greatly appreciated.
    Avid MC v 6.0.3.4, 2 x 2.66 GHz 6-Core Intel Xeon, Mac OS 10.7.2 Isis v 4.0.0.5500 [view my complete system specs]
  • Wed, Mar 20 2013 8:53 AM In reply to
    • Dr.DOG
    • Joined on Mon, Feb 26 2007
    • Praha, CZ
    • Posts 95
    • Points 1,275
    Re: Unable to create an audio mix down
    Had the same problem last summer. Looks like some AudioSuite plugins were the culprit. Now when I writing this came on my mind that just opening AudioSuite could help. Maybe.
    G5 dualcore 2.3GHz, 3.5GB RAM, OSX.4.7, Mojo SDI, MC 2.64 G3 333 MHz, 640 MB RAM, OS 8.6, MC 9000 [view my complete system specs]
     Started on MC 5.12 NuBus
  • Thu, Mar 21 2013 5:24 PM In reply to
    • Sean
    • Los Angeles
    • Posts 13
    • Points 135
    Thanks for the tip.  As a matter of course, I always have AudioSuite open, so that won't fix it.  I  have been having trouble with D-Verb and Pitch Shifts however, I wonder if they're to blame.
  • Fri, Oct 11 2013 11:56 AM In reply to
    • Guy Ducker
    • Joined on Fri, Mar 19 2010
    • Posts 19
    • Points 205
    I'm having this problem too. Did you find a solution in the end?
    Guy Ducker
    OS X 10.10.5 * MC 8.5.3 * iMac 2.8GHz Intel Core i7 * 16GB RAM * AMD Radeon HD 6770M [view my complete system specs]
