Latest post Wed, Mar 20 2013 7:14 PM by Hamada Hanoura. 2 replies.
  • Mon, Mar 4 2013 7:52 PM
    • Cecille
    • Joined on Mon, Mar 4 2013
    • Posts 0
    • Points 0
    Problems Linking to AMA Volume and Importing
    Hello,
    I am not able to link to AMA Volume or importing files. I have the right plugins and my mac is OS X 10.8.2 (12C60) which should be good enough. Really cannot figure this out. I have a midterm this week with this software and it isn't working. Anybody know a solution to this problem?
    Cecille
  • Mon, Mar 4 2013 8:20 PM In reply to
    Re: Problems Linking to AMA Volume and Importing
    Cecille:
    You should be able to use "Link to AMA volume..." and target the folder at the root level of your media drive or card. Also, depending on what format your original source is, you will need to download and install the appropriate Avid AMA plugin from here.
  • Wed, Mar 20 2013 7:14 PM In reply to
    • Hamada Hanoura
    • Joined on Tue, Apr 10 2012
    • Washington, DC
    • Posts 2
    • Points 10
    Cecille,
    I had a smiliar problem where AVID would not recognise the XDCAM Volume for AMA, but would still allow me to link to any or all the files on the xdcam. After going back & forth with SONY & AVID, it was discovered that a certain versions of Symantec security software was behind all that. When we disabled that software, AVID was linking like it was suppose to. We ended up rolling back Symantec to an earlier version. Give it a try.
    Hamada Hanoura
    Editor
    PBS Newsour
