Latest post Mon, Mar 20 2017 5:27 AM by hartfilms. 7 replies.
  • Mon, Jan 21 2013 9:06 PM
    • Alcy
    • Joined on Tue, Mar 10 2009
    • Posts 1,002
    • Points 12,975
    Failed - encoding: MPEG4IP hinter failed
    I tried to render an Avid MC6 Qt. Ref. file in Sorenson Squeeze 8.5 and everytime I do, I got this error.
    I posted this error on Sorenson site but seems no one knows. I am using Vimeo and Youtube preset and both got this same error.
    Avid MC 8.1
    Windows 8.1
    HP Z800
    Dual Intel Xeon E5530 2.4GHz
    24GB RAM
    SAS 320GB @ 15K RPM OS Hard Drive
    1TB HD and 1.5TB HD Internal
    Nvidia Quadro FX 3800
  • Mon, Jan 21 2013 9:17 PM In reply to
    Re: Failed - encoding: MPEG4IP hinter failed
    Try duplicating your sequence and making a Video mixdown. Edit that mixdown into the duplicate sequences V1 with all other video tracks active. (so you end up with a mixdown on V1 and no media on any other Video tracks.
    When exporting this duplicate time line to QT reference select the option to create an Audio Mixdown during the export.
    Then open SS 8.5 and add this new QT reference as your source.  If your timeline is more than 10 minutes I would try what I just suggested on a 30 second section of your timeline to check it all works
  • Tue, Jun 25 2013 5:39 AM In reply to
    • Bill
    • Joined on Mon, May 2 2011
    • Posts 65
    • Points 1,010
    I think this is a Sorenson/MainConcept codec issue as against an MC problem.
    I successfuly exported from MC6.5 to DNxHD 36 1080P50.
    Imported to Squeeze and applied mp4/H264 - MainConcept CUDA.
    Failed at the very end with the same error.
    It seems to happen if the video is long. This one is 50 minutes.
    Didn't happen on a short 3-5 minutes video.
    No problem encoding the very same video to VP8.
    MC 8.4, HP Z800 - X5675@3.07 GHz, RAM: 48GB, Quadro FX 3800, Dual Apple Cine HD 30" displays, 120 GB SSD system drive, RAID: 8TB 7200 RPM, Win 7/64... [view my complete system specs]
  • Wed, Jun 26 2013 2:13 AM In reply to
    • Bill
    • Posts 65
    • Points 1,010
    Additional tests:
    - In the very same Sorenson project where the ManiConcept h264 CUDA codec failed I:
    - copied the preset that failed
    - changed the codec to x264
    - added the preset to the very same movie that failed and
    - rendered it.
    No problem, worked just fine. Then I:
    - cleared the previously failed render and
    - re-rendered it
    It has failed again with the same message.
    I think this proves that the problem is with the MainConcept h264 CUDA codec.
    I have lodged a report with Sorenson.
  • Tue, Sep 10 2013 10:43 PM In reply to
    • stevehj
    • Joined on Wed, Feb 27 2008
    • Posts 20
    • Points 250
    Bill -- did you get a response from Sorenson?  I'm having the same exact issue.  Any help would be appreciated.  Thanks.
  • Fri, Sep 13 2013 4:47 AM In reply to
    • Bill
    • Posts 65
    • Points 1,010
    Sorry for the late reply, i was filming off the map.
    stevehj:
    Yes and no.
    I worked out, the compression fails if Stream-type is set to 'Streaming(hinted)'.
    It worked when i set it to Non-streaming.
    I told it to Sorenson and they reply was that they are "happy" that i found a workaround.
    Quickly I advised them that I was expecting a thankyou for carrying out free Alpha-testing for THEM to solve a bug and a report that they fixed it.
    Didn't hear from them since.
    Cheers,
    Bill
  • Fri, Oct 25 2013 3:22 PM In reply to
    • Robb Harriss
    • Joined on Sat, Feb 2 2013
    • Minnesota
    • Posts 27
    • Points 310
    Well I'm getting the same error at random here. However, I'm not coming right out of Media Composer. I have rendered master files that I'm now running through Squeeze 9 Pro. About a third of my renders (I have about 20 files in front of me) are coming up "MPEG4IP Hinter Failed." Nothing on the Sorenson threads. Yes, these are for Vimeo. I'd selected the "hinted" because, well yes, these are for streaming. Guess I'll try it with hiniting off and see what happens. I'm using x.264 instead of Main concept and running these at 15,000 Kbps for HD on a Vimeo Pro account.
    Primary: MC 8.3.1 on new Mac Pro 2013, 32 GB Ram, OS 10.9.5, Thunderbolt and misc storage. Dual Monitors (Apple 23" cinema displays). Secondary MC... [view my complete system specs]
  • Mon, Mar 20 2017 5:27 AM In reply to
    • hartfilms
    • Joined on Wed, Nov 16 2005
    • Los Angeles
    • Posts 117
    • Points 1,255
    Robb Harriss:
    ...I have rendered master files that I'm now running through Squeeze 9 Pro. About a third of my renders (I have about 20 files in front of me) are coming up "MPEG4IP Hinter Failed." Nothing on the Sorenson threads. Yes, these are for Vimeo. I'd selected the "hinted" because, well yes, these are for streaming...I'm using x.264 instead of Main concept and running these at 15,000 Kbps for HD on a Vimeo Pro account.
    Same settings as Robb, same problem. Four years and three versions later, Squeeze developers and support are just as unresponsive. However, turning off "hinting" did the trick. Whatever  that "Hinter" is, it just doesn't take the hint! Coming straight out of MC 8.6.5 Mixdown works as well as QT export. Squeeze has always given me good results when it does work.
    HP Z440 - Win 7 Pro / MC 8.6.5; Mac Pro (Early 2008) OS 10.6.8 / FCS 3; ASUS VH222H 21.5" x2 1080P LCD Monitors; Mojo SD (not connected for HD/HDV... [view my complete system specs]
    Filed under: , ,
