Hi All,
Over the last few days we've started getting this error on with new installs of MC 6.0.3.2 and 6.0.3 on systems with either 10.8.2 or 10.7.5. These installs have all occured on cleanly formated drives. I've tried multiple reinstalls and even reformating/reinstalling the OS's on the systems but keep getting this error: "AvidMediaComposer cannot be opened because of a problem"
Any suggestions?
Below is the full details from the latest avid error output:
Process: AvidMediaComposer [215]
Path: /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
Identifier: com.avid.mediacomposer
Version: 6.0.3.27470 (6.0.3)
Code Type: X86-64 (Native)
Parent Process: launchd [169]
Date/Time: 2012-12-18 17:23:31.991 -0800
OS Version: Mac OS X 10.7.5 (11G63b)
Report Version: 9
Interval Since Last Report: 4210 sec
Crashes Since Last Report: 6
Per-App Crashes Since Last Report: 4
Anonymous UUID: 7133DE0A-0711-40ED-94B0-B3EFE19CB0D8
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @executable_path/libAut.dylib
Referenced from: /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
Reason: image not found
Binary Images:
0x100000000 - 0x101267ff7 +com.avid.mediacomposer (6.0.3.27470 - 6.0.3) <660C316B-828C-7D7B-E539-257A981622EE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
0x101996000 - 0x101c5bff7 +QtCore (4.8.1 - compatibility 4.8.0) <1FACCF7D-ADE4-2453-FC4E-3C6100A2C8E8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
0x101cf9000 - 0x1026dbfe7 +QtGui (4.8.1 - compatibility 4.8.0) <30294385-FCD7-3CB2-DD61-2DDE6C387F29> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
0x102995000 - 0x1029d2fff +QtXml (4.8.1 - compatibility 4.8.0) <B3F70456-5F39-5151-6EF9-5F82FE61E81F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
0x1029ec000 - 0x102ec8ff7 +QtDesigner (4.8.1 - compatibility 4.8.0) <07435BBA-9128-0EF9-909A-AE5896BBC900> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtDesigner.framework/Versions/4/QtDesigner
0x103000000 - 0x103037ff7 +QtSql (4.8.1 - compatibility 4.8.0) <313D7724-AE08-BC0D-BE8D-9E71412BB0AB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtSql.framework/Versions/4/QtSql
0x10304e000 - 0x10318cfef +QtNetwork (4.8.1 - compatibility 4.8.0) <BA222B84-AFD7-B755-7F41-FB72E3A7F12D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork
0x1031ef000 - 0x10369efe7 +QtXmlPatterns (4.8.1 - compatibility 4.8.0) <7583784F-F7AE-785D-F4DE-054B0EEDE400> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXmlPatterns.framework/Versions/4/QtXmlPatterns
0x103822000 - 0x103868ff7 +phonon (4.4.0 - compatibility 4.4.0) <56665102-129F-02D1-EC81-8A718AE979E9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/phonon.framework/Versions/4/phonon
0x10388f000 - 0x104f90ff7 +QtWebKit (4.9.0 - compatibility 4.9.0) <A6A29ECB-286B-9413-018E-83089E8E2854> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebKit.framework/Versions/4/QtWebKit
0x105f4a000 - 0x10605afff +libicuucAvid.dylib (42.1.0 - compatibility 42.0.0) <0324B86A-D950-44DD-7FDA-698EEC316712> /Library/Application Support/Avid/libicuucAvid.dylib
0x10609e000 - 0x106201fe7 +libicui18nAvid.dylib (42.1.0 - compatibility 42.0.0) <2FE28B07-BEFC-03D0-8FF9-9A8CC94A4C39> /Library/Application Support/Avid/libicui18nAvid.dylib
0x106283000 - 0x10628bff7 +libicuioAvid.dylib (42.1.0 - compatibility 42.0.0) <5791FC99-B4E2-C343-652B-4AD06EF68F58> /Library/Application Support/Avid/libicuioAvid.dylib
0x106291000 - 0x1071d5ff7 +libicudataAvid.dylib (42.1.0 - compatibility 42.0.0) <9DC8D679-CE52-1BD9-9296-35493D3D8553> /Library/Application Support/Avid/libicudataAvid.dylib
0x1071d7000 - 0x107e3dfe7 +com.avid.UIShellQt (1.0 - 1.0) <CAAA5A65-A5E0-EE5A-FB94-F6EB7BDCE228> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/UIShellQt.framework/Versions/A/UIShellQt
0x7fff63247000 - 0x7fff6327bbaf dyld (195.6 - ???) <C58DAD8A-4B00-3676-8637-93D6FDE73147> /usr/lib/dyld
0x7fff8b3a6000 - 0x7fff8b3ecfff libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <2C442396-1006-3765-92D2-60869D4641CE> /usr/lib/libcurl.4.dylib
0x7fff90006000 - 0x7fff9003ffe7 libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <79AAEC98-1258-3DA4-B1C0-4120049D390B> /usr/lib/libssl.0.9.8.dylib
0x7fff956cb000 - 0x7fff957d7fff libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <3A8E1F89-5E26-3C8B-B538-81F5D61DBF8A> /usr/lib/libcrypto.0.9.8.dylib
Model: MacPro2,1, BootROM MP11.005C.B08, 4 processors, Dual-Core Intel Xeon, 3 GHz, 6 GB, SMC 1.7f10
Graphics: NVIDIA GeForce 7300 GT, NVIDIA GeForce 7300 GT, PCIe, 256 MB
Memory Module: DIMM Riser A/DIMM 1, 1 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x3138484631323837324A4436363742354433
Memory Module: DIMM Riser A/DIMM 2, 1 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x3138484631323837324A4436363742354433
Memory Module: DIMM Riser B/DIMM 1, 1 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x3138484631323837324A4436363742354433
Memory Module: DIMM Riser B/DIMM 2, 1 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x3138484631323837324A4436363742354433
Memory Module: DIMM Riser A/DIMM 3, 1 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x3138484631323837324A4436363742354433
Memory Module: DIMM Riser A/DIMM 4, 1 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x3138484631323837324A4436363742354433
Network Service: Ethernet 1, Ethernet, en0
Network Service: 802.11n WLAN Adapter, Ethernet, en2
PCI Card: ATTO Celerity FC-41ES, sppci_fibrechannel, Slot-4@4,4,0
PCI Card: pci15bc,105, sppci_fibrechannel, Slot-4@4,4,1
PCI Card: pcif1d0,c0fe, sppci_video, Slot-3@8,12,0
PCI Card: NVIDIA GeForce 7300 GT, sppci_displaycontroller, Slot-1
Serial ATA Device: ST3500641AS P, 500.11 GB
Parallel ATA Device: SONY DVD RW DW-D150A
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd400000 / 3
USB Device: USB Optical Mouse, 0x046d (Logitech Inc.), 0xc06c, 0xfd430000 / 5
USB Device: Apple Keyboard, apple_vendor_id, 0x024f, 0xfd420000 / 4
USB Device: 802.11n WLAN Adapter, 0x0bda (Realtek Semiconductor Corp.), 0x8176, 0xfd300000 / 2
FireWire Device: built-in_hub, 800mbit_speed
Assuming you have not tried this already, try a fresh download of 6.0.3.2, to eliminate the possibility of corruption in the download installer you are currently using. And be advised that 10.7.5 and 10.8.2 both require 6.0.3.2, not 6.0.3.
Thanks Larry. A fresh download of 6.0.3.2 didn't solve the issue. I had only tried the 6.0.3 install as an attempt to eliminate it being a bug with 6.0.3.2 (we've had other 10.7.5 machines run 6.0.3 without issue). We've seen this error now on three different machines... all machines that ran 6.0.3 perfectly fine under 10.7.4 before their drives were reformatted (we reformat producer machines when they come back in). However, this error has not affected every machine, it seems to be random. Reformatting the drives again does not clear up the issue.
Hi, I have just got this message also.
was opening fine yesterday but now MC will not open.
MC 6.5.2.1
Did you update the OS?
OS 10.9.4 is not yet qualified, but you needed to be on MC v6.5.4 for OS 10.9.2.
MC v6.5.2.x is only qualified for Lion and Mountain Lion (up to OS 10.8.2).
dklein: Thanks Larry. A fresh download of 6.0.3.2 didn't solve the issue. I had only tried the 6.0.3 install as an attempt to eliminate it being a bug with 6.0.3.2 (we've had other 10.7.5 machines run 6.0.3 without issue). We've seen this error now on three different machines... all machines that ran 6.0.3 perfectly fine under 10.7.4 before their drives were reformatted (we reformat producer machines when they come back in). However, this error has not affected every machine, it seems to be random. Reformatting the drives again does not clear up the issue.
Could it be a QT version thing? An NVidia driver version? By reformatting I take it you are reformatting the system drive and re-installing OSX then applications? Or do you just clone the system drive from a pre-installed version of OSX? If so that could be corrupt...
John
I have done the stupid thing of trying to run 6.5.4.2 on Mavericks 10.9.3. (I thought I was doing the right thing, but by the time I actually upgraded to Mavericks it had jumped up a version number and I hadn't noticed.)
Anyway - I get the same error message saying Avid can't be opened because of a problem. Won't run at all. Is that what happens to everyone else who has done the same thing? I am just suspicious that I might have a greater problem?
But if the error message I'm getting is what everyone else would get in the same situition, then fine, I will just sit tight and wait until an upgrade. This is on my home set-up by the way - not needed for real work at the moment, thank goodness!
Thanks in advance!
Are your privacy settings allowing for running All programs from all developers?
They are now, but weren't when I downloaded the latest upgrade. Would that make a difference?
Maybe just trying a fresh download/install is the way to go...
