Latest post Fri, Jan 11 2013 5:29 AM by Dmitry Larionov. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Dec 16 2012 7:03 PM
    Timecode issue at 23.976 proj
    Hi everyone! I'm having a timecode issue with my project. I have a bunch of RED Epic 5k files which I transcoded to Quicktime ProRes LT 720p/23.976 with TC burn-ins.  Everything runs smooth except one thing: at frame 500th (plus-minus couple of frames) MC holds a frame for one frame (essentially giving me two identical frames in Source Monitor window), then runs to the end on clip with 1 frame later than TC in original frame.  Basically it looks like MC inserts one extra frame at frame 500th.  Quicktimes are AMA-linked. I'd prefer to keep them AMA, because i have like 120GB of them.  Timecode readings above the composer window are correct thought.  Please help!
    MacPro 3,1 2008: 8 core, 16GB RAM, nVidia Quadro FX 4800, Media Composer 8.4 [view my complete system specs]
  • Sun, Dec 16 2012 7:08 PM In reply to
    Re: Timecode issue at 23.976 proj
    You should really stay away from 720 for things like this. And for editing in MC it is just as fast - and much more solid - to have RedCine-X create 1080p DNxHD MXF media. No need to import nor AMA-link after that.
    Are you in a 23.976 project?
    What does the FPS column in the bin say? If you splice such a shot into the timeline, does it ger a green dot effect automatically? That would indicate a framerate difference.
    If you check the QT file in QT player, is the same repeated frame visible there?
  • Sun, Dec 16 2012 7:19 PM In reply to
    Thanks for reply Job!
    Why is 720 is not a good choice? I thought it is a good trade off between file size and pic quality. Whats wrong with 720?
    Also, DP and Director both wanted to see dailies, thats why ProRes seemed to be a good choice. They have FCP7 and editing supposed to be on MC.
    Both Premiere Pro and FCP7 see those files without problems.
  • Sun, Dec 16 2012 7:29 PM In reply to
    First of all, the 720 format does not come with 24TC, since it is a 25/30 format. 720p23.976 is a fabricated format that carries 23.976p inside a 60i stream.
    In 1920x1080p, Avid has DNxHD36 which looks way better than the data rate suggests.
    On any job that takes more than a day or two, I'd stay away from AMA. It'll slow your system down. Avid native MXF media is far more solid.
    But the main Q: is the repeated frame in QT player as well? What's the framerate MC detects? Any green dots?
  • Sun, Dec 16 2012 7:50 PM In reply to
    Oh, didnt know this about 720! THANKS A TON! Will stay away from it if possile. QT player diplays it correctly, no duplicated frames. MC sees it as 23.976 no issues also (except duplicated frame, only one frame). Just checked on second machine (MC 6.5.0)--same thing. Duplicated frame and TC off 1frame after frame 500.
    No green dots on timeline.
    One thing that bogs me: why 500 frames? Whats so magical in it?
  • Sun, Dec 16 2012 9:11 PM In reply to
    Are you on 6.5.0.1 or on the original 6.5.0?
  • Sun, Dec 16 2012 10:11 PM In reply to
    6.5.0.1   But I have tested it on 6.5.0 and have same issues.
  • Sun, Dec 16 2012 10:51 PM In reply to
    I've just transcoded to DNxHD MXF 720p 23.976 and MXF 1080p 23.976 -- they don't have such problem.
    Looks like it was a ProRes import/AMA-linking problem.
  • Sun, Dec 16 2012 11:53 PM In reply to
    Just double cheched -- MXF works like charm! Thanks you!!
  • Thu, Jan 10 2013 11:59 PM In reply to
    • kojo
    • Joined on Mon, Jun 2 2008
    • Posts 4
    • Points 50
    @Dmitry ~
    I've recently run into a similar issue - a duplicate frame about 500 frames into my timeline.
    Can you share what OS X version you were using when you had this issue?
    Thanks!
  • Fri, Jan 11 2013 5:29 AM In reply to
    @Kojo
    10.8.2, MacBook Air 11", AvidMC 6.5.2
