Latest post Wed, Dec 5 2012 7:16 PM by John Moore. 3 replies.
  • Tue, Dec 4 2012 7:39 PM
    Opening Symphony Seq with MC
    Our facility has multiple MC machines (all mac) connected to an ISIS 5000. We are thinking of upgrading 1 machine to Symphony. Once color correction has been done on the symphony can the sequence be opned and the color correction be viewed (Secondary, clip base and source based - read only) in MC?
    We would like to use the symphony to help our finishing process, but in case minor changes or additional exports to quicktime need to be made, it would be ideal that not to be pinned down to 1 machine.
    Thanks you All
    Brandon
  • Tue, Dec 4 2012 8:19 PM In reply to
    Re: Opening Symphony Seq with MC
    As long as all the color corrections are rendered on the Symphony, then you can open it  on the MC just fine.  If you start changing things while on MC that un-render the Symphony Color Corrrections, then you'll have unrecognized effects and will either have to remove and replace them or go back to the Symphony for adjustments and re-render.
    Follow me at www.twitter.com/redarrowryan Avid 1- z400 6-Core, with Nitris DX Symphony 6.0.3 Win 7 64 Bit [view my complete system specs]
  • Tue, Dec 4 2012 8:54 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,251
    • Points 27,805
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Media Composer can open a sequence with Symphony Relational Color Correction effects but will not be able to edit them. MC can only remove the effect.
    I don't believe they have to be rendered or anything else special done.
  • Wed, Dec 5 2012 7:16 PM In reply to
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Studio City, CA
    • Posts 394
    • Points 4,450
    In my experience for a long while, sometime around V3.5 IIRC, mc will be fine with symphony color correction, even showing the green line to indicate color correction.  The only thing that gets lost is secondary color correction.  If you rendered the clips with secondary color correction it will play fine in mc but if it's not rendered it will be just like shutting off the secondary tab.  And as has been pointed out you can't adjust many of the parameter but the master curves and some of the others can be adjusted.  I've sometimes limited the use of the symphony color corrector to just the parameters that appear in both symphony and mc to allow for mc compatibility.
    Symphony Nitris and Nitris DX 4.x and MCsoft 5.x & 5.5x, MCsoft 6, Artist Color [view my complete system specs]
    John Moore Barking Trout Productions bigfish@pacbell.net
