Latest post Wed, Dec 12 2012 12:06 PM by Larry Rubin. 17 replies.
  • Thu, Nov 1 2012 5:09 PM
    Media Composer 6.5.0.1 PATCH NOW AVAILABLE!
    We are happy to report that Avid Media Composer 6.5.0.1 and NewsCutter 10.5.0.1 are now available for download.
    Note that this is a release in support of the new Sony XDCAM plug ins.  Avid is working on a maintenance release for later in the year.
    Where to download?
    6.5.0.1/10.5.0. 1 patch updates are available on the avid.com Download Center (login and password required) and are located in the Avid Editor Patch folder within the Product List.
    http://www.avid.com/us/support/downloads
    Who is Eligible?
    The 6.5.0.1/10.5.0.1 patch updates are free for any customers already on 6.5.x/10.5.x
    Patch Instructions:
    Please make sure that you download and read the Patch instructions document located with the 6.5.0.1/10.5.0.1 download.
    Media Composer 2018.2 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT 740M [view my complete system specs]
  • Thu, Nov 1 2012 8:32 PM In reply to
    Re: Media Composer 6.5.0.1 PATCH NOW AVAILABLE!
    XDCAM HD proxie and Batch import workfow now a pleasure to work with again! Yes
  • Fri, Nov 2 2012 7:38 AM In reply to
    • dor
    • Israel
    • Posts 595
    • Points 7,560
    With MC 6.5.0.1 and the new XDCAM AMA plugin, drawing audio waveform takes very long time..
    MC 8.8.1 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 368.22. QT.7.7.9 [view my complete system specs]
  • Fri, Nov 2 2012 3:10 PM In reply to
    • the_dark
    • Joined on Fri, Aug 17 2007
    • Posts 165
    • Points 2,240
    Bug in the Settings window: Composer Settings, Window tab. At the bottom of the window the option "Tick Marks in Position Bars" is only partially visible. It is not possible to change this option. If you deselect the option and click OK when you open the Composer Settings again the option will still be selected.
    Also, if there are supposed to be additional options selectable below this option they are completely missing. I don't know if there are or not.
    Similar issue with the Trim Settings dialog box. The Play Loop tab has the last item(?), Intermission, cut off.
    Charles
    Dell Precision T3600 Intel Quad Core Xeon E5-1607 3.06Ghz 8GB Memory (4x2GB) 250GB System Drive 500GB to 1TB Media Drive nVidia Quadro 2000 Dell... [view my complete system specs]
  • Sun, Nov 4 2012 8:02 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,194
    • Points 61,025
    Charles, did You enlarge the default Windows text/icons size?
    MC 2018.2, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Mon, Nov 5 2012 10:58 PM In reply to
    • the_dark
    • Posts 165
    • Points 2,240
    This is a completely clean install, default windows text and icon sizes.
    I do need to add that I first encountered this issue running NewsCutter 10.5.0.1. Today I had the chance to try Media Composer 6.5.0.1 and while the Composer Setting dialog still has the bottom item cut off the Trim Setting dialog does not.
    So, just to confirm in NewsCutter 10.5.0.1 both the Composer Setting dialog box and Trim Setting dialog box has the bottom items cut off. In Media Comopser 6.5.0.1 only the Composer Setting dialog box has the bottom item cut off.
    An additional bug (in Media Composer at least, haven't tested NewsCutter yet) is that the Title tool cannot be opened. Neither the standard title tool nor the Marquee title tool. There's a brief flash where it looks like it's trying to do something but then nothing. No title tool opens and no error message is displayed.
  • Tue, Nov 13 2012 2:16 AM In reply to
    Same bad behavior here.
    System 1: HP Z400, 3.20G Quad Core, Quadro 4000, 250G SSD system drive,Windows 7 64, MojoDX w/active hib, 6G ram, Cal Digit VR ESATA Raid, Recommended... [view my complete system specs]
  • Wed, Nov 14 2012 12:53 PM In reply to
    • ostreuli
    • Joined on Mon, Oct 11 2010
    • Posts 6
    • Points 80
    Same here, can't open the title tool to edit a title made in 6.5.0.0, I see a progress window for a split second, then its gone, and nothing happens.
  • Tue, Nov 20 2012 1:13 PM In reply to
    • JJ van Rensburg
    • Cape Town South Africa
    • Posts 237
    • Points 3,160
    Yep, my title tool also dissapear. Any solutions except to uninstall the patch?
    Win7 Prof 64bit, Dual Xenon CPU ES-2630, 64 gig RAM, HP Z620 dual proc, 64gig RAM, BluRay Writer, IO Express, Avid Artist control, Avid Artist color, MC... [view my complete system specs]
    Experience cannot be taught or learnt!
  • Tue, Nov 20 2012 1:18 PM In reply to
    For those of you having title tool issues, there is a bad .dll file that needs to be replaced. Contact Marianna or one of the moderators. She or a moderator will send you the new file and instructions for replacement.
  • Wed, Nov 21 2012 3:50 PM In reply to
    • Chris Aust
    • Munich
    • Posts 433
    • Points 4,730
      Avid Certified User
    do you only have the issue with the title tool or also with marquee? If you see the same issue with marquee, then the bad-dll fix possibly won't help.
    thanks and cheers
    -chris
    MC/Symphony 8.7.2 | VMware Workstation 12 virtual Interplay environment | Ubuntu Linux 16.04 | Dell XPS 15 |||| obsolete MacBookPro 17", 2.5GHz Quad... [view my complete system specs]
    Chris Aust
    Munich, Germany
    ACI | Trainer | Workflow Consultant
    Splash!Zone
    German Avid User Forums:
    AVIDFORUM.DE
    facebook.com/groups/avidforum/
  • Thu, Nov 22 2012 6:03 PM In reply to
    • Doug Croden
    • London Ont Canada
    • Posts 93
    • Points 1,070
     I just insalled the 6.5.0.1 patch and now I'm getting this
    EXCEPTION: can't create a directory as one of the folders in the path below has insufficient permission path :C:\programe files\AVID\AVX-Plug-ins\ I have checked the permission on the folders what am I missing
    Doug
    MC 5 HPZ400 Nvida Quadro 3800 6 gig ram 6TB drives Avid Production Suite MC 5 HPwx8400 Nvidia Quadro FX 4500 4 gig ram 4TB drives Avid Production... [view my complete system specs]
  • Thu, Nov 22 2012 6:36 PM In reply to
    • Doug Croden
    • London Ont Canada
    • Posts 93
    • Points 1,070
    I think AVID needs to have a closer look at this patch I would not recomand it I'm back to6.5.0
  • Thu, Dec 6 2012 8:47 AM In reply to
    • Peter Benner
    • Joined on Wed, May 12 2010
    • Wellington - New Zealand
    • Posts 39
    • Points 520
    Hi There I just posted a request for advice in regards to this exact problem myself tonight and have just discovered your thread....
    What process did you take to unpatch the 6.5.01
    Pete
    Intel i7 930 @ 2.80GHZ; Asus P6T Deluxe Version 2; 24Gb Ram; 1 System Drive 2TB 3 partitions;1 Aux Drive 6TB; Video Raid0 Drive 4TB; NVida Quadro FX3800;... [view my complete system specs]
  • Thu, Dec 6 2012 8:56 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,344
    • Points 159,265
    Peter Benner:
    Pete
    I was in your other thread trying to assist Pete, nice that you found this thread and a user with similar problems.
    To uninstall the 6,50,1 patch just checkmark " show patches " in the application uninstall window and the patch should be visible and possible to uninstall.
    Tomas
