Latest post Thu, Sep 27 2012 8:25 PM by Jim. 3 replies.
  • Tue, Sep 25 2012 3:41 PM
    • Jim
    • Joined on Sun, Jun 3 2012
    • Bloomington, IN
    • Posts 11
    • Points 125
    Canon EOS/5D clips appear black when AMA linked or imported
    I've shot some clips with a Canon 5D Mkiii (29.97 fps H.264 1920x1080 all i-frame / highest quality). They look great in Quicktime player but appear black in Avid Media Composer (6.0.3)
    Regardless of whether I link via AMA or import/convert to Avid codec, the result is the same: a black movie with audio.
    I can convert with Adobe Media Encoder or Compressor, but would like to avoid this step if possible.
    Can anyone offer any suggestions to fix this?
    Many thanks
    - Jim
    Media Composer 6.0.3, MacPro(4,1), 2 x 2.26 Quad-Core Intel Xeon, 16GB RAM, OS 10.8.2, NVIDIA GeForce GT 120 [view my complete system specs]
    Filed under: , , ,
  • Tue, Sep 25 2012 8:55 PM In reply to
    • pierreh
    • Paris, London
    • Posts 878
    • Points 10,820
    Re: Canon EOS/5D clips appear black when AMA linked or imported
    Have you got "Perian" or "Flip4Mac" installed on your Macintosh? If so, try deinstalling both.
    Personal system: MacBookPro 2.66Ghz i7, 4Gig Mem and SSD - Work system: MacPro Nehalem, 3 monitors, internal Raid setup and Matrox Mini [view my complete system specs]
  • Wed, Sep 26 2012 12:57 AM In reply to
    • Jim
    • Bloomington, IN
    • Posts 11
    • Points 125
    I did have Flip4Mac installed. I deleted its prefs, uninstalled it, restarted but still no luck.
    DOH!
    I wonder if anyone else is having similar issues or has found a workaround.
    - J
  • Thu, Sep 27 2012 8:25 PM In reply to
    • Jim
    • Bloomington, IN
    • Posts 11
    • Points 125
    Problem Solved - thanks Pierreh!
    It turned out that I did have Perian installed in the Quicktime components. Once this was removed the clips were no longer black.
    For some reason search didn't turn it up. Fortunately Mackeeper did.
    Thanks Pierreh!
    - Jim
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
