Latest post Mon, Nov 12 2012 8:37 PM by Per-Erik Österlund. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Sep 10 2012 10:43 AM
    • mrtrees
    • Joined on Tue, Aug 8 2006
    • Posts 308
    • Points 4,165
    ISIS 5000 very very very slow to list files, move files, copy files
    Hi
    When i mount an ISIS 5000 workspace on my Max, wether it be on snow leopard to lion, listing the contents of that workspace can take up to 15 minutes, sometimes even longer depending on the amount of files the workspace has.
    Also simply deleting the database file or moving MXF files between folders can take an age.
    Is this common behavior for ISIS, if so it is ridiculous, 15 minutes to display a few thousand files and in excess of five minutes to delete a databse file.
    Does anybody else suffer from this?
    MC 2018.7.1/OSX 10.13.5/AJA IO4K/Nexis Client 7.10/ISIS server 4.7.11 Mac Pro 3GHZ 8 Core Intel Xon E5/32GB ISIS 5000 sys director/ 2 x 32 TB expansion... [view my complete system specs]
  • Mon, Sep 10 2012 12:13 PM In reply to
    Re: ISIS 5000 very very very slow to list files, move files, copy files
    No, that's not normal, nor have I seen it.  The first thing I'd do, is go through "everything" and check for proper revs, settings, etc.
    Are your System Specs up to date in your Forum listing?  Looks like Unity not ISIS.
    (wwld)
  • Mon, Sep 10 2012 12:26 PM In reply to
    • mrtrees
    • Posts 308
    • Points 4,165
    Thanks fr your reply, i have updated my settings. Incase they dont refresh instantly they are
    MC 5.5.3/OSX 10.6.8/ISIS 5000 server 3.2.0.355/ISIS client Manager 3.5.0.445
    About two minths ago an Avid tech dialled in to our ISIS and had a poke around as i was sure things wernt correct, i can only assume all settigns are correct.
  • Mon, Nov 12 2012 12:32 PM In reply to
    Hey guys, I've noticed this on mac systems. As a result I do all my large volume file copying on my pc systems. I think it's an issue with spotlight indexing the drive before use and creating it's dreaded '._' files.
    This behaviour is not limited to isis. Also present on external FW800 drives etc.
    I've tried switching off spotlight's indexing of my media drives but got fed up messing with it in the end. Any joy let us know!
    Jonny
  • Mon, Nov 12 2012 8:25 PM In reply to
    Hi
    We have 5 Mac based systems in both our Unity 5.1.3 and ISIS 5000 network and I have tried this trick and it has worked fine for us: http://support.apple.com/kb/HT1629
    Perra from Sweden
    1 x ISIS 5000 64TB, 1 x ISIS 5000 32TB, 1 x MediaEngine Unity 32TB 1 x Symphony Nitris on HP Z800, 29 x Media Composer on HP Z400 (5.0.4 to 5.5.3.2 -... [view my complete system specs]
  • Mon, Nov 12 2012 8:37 PM In reply to
    You can try this from BlueHarvest and/or this CleanSMB
    It's a bit anoying when open a project folder and some of the projects all of a sudden is named ._ProjectName (in a shared Unity/ISIS enviroment)
