Latest post Thu, Aug 28 2014 10:48 AM by morazzano. 15 replies.
  • Wed, Sep 5 2012 1:57 PM
    • MarcusM
    • Joined on Wed, Sep 5 2012
    • Posts 9
    • Points 145
    Media Offline: New computer upgrade new hard drive won't relink
    I have upgraded from Media Composer 4 to 6 along with a computer upgrade. I copied all of the media files from 3 smaller hard drives, (in the same directory structure) into 1 new 3 TB drive.
    Copied the Avid Projects folder over, so the projects and timelines are showing but the media is offline.
    I have tried the re-link all-drives option, but it says, "No clips were relinked"
    I had to do this about 4 years ago. It seems that I recall some type of command to re-scan the drives or something to relink all of the projects to the new media locations. Can someone help me with a way to do this? Thanks!
  • Wed, Sep 5 2012 2:25 PM In reply to
    Re: Media Offline: New computer upgrade new hard drive won't relink
    First exit Media Composer. Then, in each folder inside the Avid MediaFiles folder find the two database files named named msmFMID.pmr and msmMMOB.mdb. Delete them.  When you restart the system will rebuild them and hopefully this will fix your problem.
    ciao,
    Carl
    Media Composer 2018.12.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Wed, Sep 5 2012 4:01 PM In reply to
    • MarcusM
    • Posts 9
    • Points 145
    Hi Carl,
    I deleted the database files, but Avid did not automatically re-scan the drives on startup.  Is there a way/command to tell Avid to re-build/scan the media drive? -- Mark
  • Wed, Sep 5 2012 4:09 PM In reply to
    • Dan
    • Joined on Fri, Aug 12 2011
    • UK
    • Posts 231
    • Points 3,165
    What Carl says should have worked really - but you could also try the 'refresh media directories' option (in the 'file' drop down menu. That will refresh any and all drives  (with Avid media on) connected to the machine, so if there's more than one it can take while and your Avid will be unusable during this time. It often looks like it's frozen or crashed while refreshing, but usually it hasn't and you just need to see it through!
    Symphony 8.5.3 Windows 7 pro 64bit. Intel Core i7 2600k. 16GB RAM. Nvidia Quadro fx5500. [view my complete system specs]
  • Wed, Sep 5 2012 4:14 PM In reply to
    Marcus:
    When you move media around, be sure you are following the Media Folder Management Ground Rules:
    1) The "Avid MediaFiles" folder (for MXF media) and the "OMFI MediaFiles" folder (for OMF media) MUST reside at the root level of the media drive, not inside any other folders or the system will not be able to find the media.
    2) The folder names must always be the factory default names listed above (minus the quotes) or the system will not be able to find the media.
    3) There can be only one of each folder type on any given media drive.
    If you have followed these rules, the database rebuild will work properly. The full procedure is to quit the application, and in each numerical folder inside the MXF folder inside the Avid MediaFiles folder, delete the two files that identify as "msmFMID.pmr" and "msmMMOB.mdb". If you have an OMFI MediaFiles folder, delete the same two files. On re-launch, the system will detect the missing files and build new ones at the "Initializing Media Streams Manager" stage. You will see the system go into scanning and then indexing modes at this point. Depending on how many drives and how much media you have on your system, this can take a while, so good time for a meal break.
  • Wed, Sep 5 2012 5:08 PM In reply to
    • MarcusM
    • Posts 9
    • Points 145
    Larry,
    Thank you for the extra tip.  Moving the folders to the root of the drive was the solution.
    Thanks to everyone that helped.... It worked!  Thanks!
  • Wed, Sep 5 2012 5:17 PM In reply to
    You're quite welcome, Marcus. We're always glad to help out.Yes
  • Wed, Aug 27 2014 10:53 AM In reply to
    • morazzano
    • Joined on Sun, Jul 6 2014
    • Rome, Italy
    • Posts 27
    • Points 335
    Hi guys!
    I'm experiencing a similar problem with my MC 8. I tried to follow the Media Folder Management Ground Rules well exposed by Larry. I put my audio and video files in the "1" folder... but only the audio files were relinked! I'm pretty sure I've done something wrong. Is there anyone who can help me out with this issue. Thanks!
    Mac Book Pro Retina 15-ich (Late 2013), OS Mojave 10.14.1, Avid 2018.10 [view my complete system specs]
    Filed under: ,
  • Wed, Aug 27 2014 1:58 PM In reply to
    Did you trash teh two database files in that 1 folder (msmFMID.pmr msmMMOB.mdb) then launch MC and let them rebuild?
  • Wed, Aug 27 2014 2:04 PM In reply to
    • morazzano
    • Rome, Italy
    • Posts 27
    • Points 335
    Yes Pat! I did it a couple of times :) But as I was saying MC reconnected just the audio files. I can't figure out what is wrong...
  • Wed, Aug 27 2014 2:36 PM In reply to
    Ok next step. create a new empty bin. Then at explorer level drag the msmMMOB.mdb file into your bin.
    That will populate the bin with all the clips that database file has seen. See hat that gives you. Do you get clips with video and audio?
    It's possible you numbered folder doesn't actually have the video files in it.
  • Wed, Aug 27 2014 2:59 PM In reply to
    • morazzano
    • Rome, Italy
    • Posts 27
    • Points 335
    Amazing, I didn't know this possibility! I have audio and video files in the new bin and they are both online!!! Now the problem is that the old clips (audio+video) were synchronized and I have to find a way not to lose my previous job Smile
  • Wed, Aug 27 2014 3:05 PM In reply to
    Avid should just automatically relink them but you can try using the relink dialogue to relink to selected clips in open bins.
  • Thu, Aug 28 2014 10:09 AM In reply to
    • morazzano
    • Rome, Italy
    • Posts 27
    • Points 335
    Pat, Unfortunately it didn't Sad. But, again, I'm pretty sure I've done something wrong since I've been struggling with the relink command forever.
    So now the current situation is that I have two identical bins (just the names differ) that contains DAY 24 of my film. The old one is offline and has already been synchronized with the audio. This means the group clips are offline too.
    Viceversa, the clips of the new bin are online but are not linked whatsoever with the audio and the group clips.
    I tried to relink the old ones but I didn't work... What am I supposed to do now?
    Thanks Smile
  • Thu, Aug 28 2014 10:30 AM In reply to
    Are you sure your new media files structure is correct?
    Has every numbered media files folder had it's media databases deleted and then checked that Avid made new ones on start up? No folders exist anywhere that haven't been updated by MC?
    And you are sure all the media came across ok?
    At this stage I'd suggest finding a local Avid Guru to troubleshoot as they can cover the ground locally far fastetr than the ping pong of a forum.
    My approach would be to take an offline clip and it's new online version and compare all the properties for each clip.
    For MC not to link them something has to be different. Depending whats different will determine whats gone wrong and if possible to fix.
     Not much help at this stage but I'd normally not suggest an upgrade mid job. Big no no!
    Is the old system not still usable in any way.
    It would be better to have done the media management on the old system on the old MC version and check all is ok then move to the new PC and the new MC version (if possible start with the old MC version on the new PC)
