Latest post Fri, Sep 21 2012 8:30 PM by Robert B. 17 replies.
  • Sat, Aug 18 2012 10:29 AM
    • insch
    • Posts 130
    • Points 1,670
    Best form of activation for MC6?
    I have just upgraded to MC 6 and thought I would leave my dongle behind and use online activation. But I find I can't activate MC on my Mac Pro and MacBook Pro at the same time - I switch between each frequently depending on whether I am on the move or not. What is the best way round this? - going back to my dongle (which I'll need to update) or going through the laborious process of activating and deactivating on each Mac every time (I assume that this method doesn't require me to re-install each time?) What do others in this situation do?
    Thank you in advance : )
    Mac Pro, 2 x 2.66 GHz Quad-core, 16GB RAM, external drives - Avastor HDX 1TB (x2), Glyph 500GB,, Western Digital - 500 GB, 1TB and 2 TB, G-drive 2 TB. [view my complete system specs]
  • Sat, Aug 18 2012 10:48 AM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles Ca
    • Posts 1,483
    • Points 16,175
    Re: Best form of activation for MC6?
    Hi It's just a push of a button and its deactivated and a push of a button to re activate easer thn looking around the back of machine for a usb port
    mc 6.0.3 msi mb quad core 2.6 proc 8 gig crucial ram nvidia quadro fx 3500 2- 2 tb wd sata 7200 raid wd 500 gig sata 7200 os drive delta... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Sat, Aug 18 2012 10:57 AM In reply to
    • insch
    • Posts 130
    • Points 1,670
    Thank you. I will just have to remember to do this every time before leaving home! I guess there is no remote option?
  • Sat, Aug 18 2012 2:09 PM In reply to
    • Tom Pearson
    • Los Angeles Ca
    • Posts 1,483
    • Points 16,175
    not yet but it is easy  you will get use  to it
  • Sat, Aug 18 2012 2:21 PM In reply to
    • chepal
    • germany
    • Posts 441
    • Points 5,075
    my opinion: stay with your dongle - you can use all versions of mc, backwards to ve2.
    with software_activation you will be fixed to the current_one.
    i use it (them) +20years.
    che
    mac_mc_6.5/5/4, mac_mc12, scsi, fibre, sata [view my complete system specs]
    peace from germany
  • Sat, Aug 18 2012 8:47 PM In reply to
    • insch
    • Posts 130
    • Points 1,670
    Thanks everyone. I think I'll go for the online activation and see how I get on.
    All the best.
  • Sat, Aug 18 2012 9:02 PM In reply to
    chepal:
    +1
    1x XW8600, 2x 3.0Ghz Quadcore, 12Mb memory, 128Gb SSD, Multiple media drives. MC 5.5.3, AJA i/o Express. At my previous job I used to have: 3x Z400... [view my complete system specs]
    Jeroen van Eekeres
    www.mediaoffline.com
  • Sat, Aug 18 2012 10:25 PM In reply to
    An alternative solution would be to buy two licenses but I think the dongle route is the easiest. I'm a dongle user and I get frustrated with other applications that don't offer one.
    My software:
    Pro Maintenance Tools - Tools to keep Avid Media Composer, Final Cut Studio, Final Cut Pro X and Adobe Premiere Pro running smoothly and fix problems when they arise
    Pro Media Tools - Edit QuickTime chapters and metadata, detect gamma shifts, edit markers, watch renders and more
    More tools...
  • Sat, Aug 18 2012 11:52 PM In reply to
    Consider also that if you wind up in an area that doesn't have Internet connectivity, you will not be able to reactivate a de-activated license. One more advantage to the dongle. As long as you have it on you, you have a license wherever you go. Plug and play.
  • Sun, Aug 19 2012 1:21 AM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,562
    • Points 18,695
    One more fan of the dongle.
    System #1 - Mac Pro 12 Core 2.93, 24 GB RAM, 16 TB ISIS 5000 System #2 - Core i7 2600k, Windows 7, 16 GB RAM, Quadro 4000 System #3 - Dell Precision... [view my complete system specs]
  • Sun, Aug 19 2012 11:03 AM In reply to
    +1 for Dongles.
    "... I guess there is no remote option? ..."
    If you don't mind leaving your system on, you can use TeamViewer to connect to your other system, if you forget to Deactivate.
    Symphony 6.5 w/Matrox MXO2 Rack, HP xw8600, Windows 7 Professional 64-Bit, QT v7.7.x, 2xQC 3.0GHz, 8GB RAM, nVidia Quadro Series FX 1800 & nVidia v275... [view my complete system specs]
    Systems Engineer @ Discovery Studios West
  • Mon, Aug 20 2012 1:05 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 4,588
    • Points 52,935
      Moderator: MCA Mac
    Here's are some of fun facts about Software Licensing:
    1.  You can't use other versions of the software.  No backward installs without getting a different install code from Avid that will invalidate your current license.
    2.  If you deactivate and didn't write down your System ID and Activation Code or didn't register it with Avid you are DOA. You saved that e-mail, right?
    3.  You have to launch Media Composer and have a internet connection to de-activate your account.  Or make a phone call.
    But there's no Dongle to break off when you're sitting on the aisle in a plane and the drink cart comes by and whacks it off.
    Personally, Dongles (and window seats)!
  • Mon, Aug 20 2012 1:39 AM In reply to
    Many of the problems with dongles (e.g. breaking off or having to fumble around the back of the computer) can be solved with a short USB extension cable.
    My software:
    More tools...
  • Mon, Aug 20 2012 4:33 AM In reply to
    Larry Rubin:
    I don't have my Avid workstation connected to the Internet except on rare occasions when I download a driver or software--or to activate/deactivate Avid.   I don't have a dongle--and don't want to pay extra for one--but if I already had one, that's the way I would go.
    System 1: Symphony 6.5.2, Matrox MX02 Mini Max, HP Z800 2x6-Core 3.2Ghz Xeon, 24GB ram, Quadro 4000, 4x2TB 7200rpm hard drives (1 as systems drive, 3 as... [view my complete system specs]
  • Mon, Aug 20 2012 10:02 AM In reply to
    • insch
    • Posts 130
    • Points 1,670
    Certainly a lot of food for thought. Thanks everyone.
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
