Latest post Tue, Mar 6 2018 6:07 PM by thedaniellynn. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Aug 6 2012 4:40 PM
    • jogotron
    • Joined on Fri, Aug 29 2008
    • Los Angeles
    • Posts 51
    • Points 760
    Artist Mix controller EuControl - issues with connection
    Is anyone else using the artist mix controllers or Euphonix boards having trouble getting mac to recognize the board?
    I have several systems connected to artist mix boards, and a couple connected to the euphonix boards running the latest mix firmware.
    I'm connecting the boards to the macs using DHCP in the network settings. I've installed the EuControl software.
    The boards are recognized by mac os, and are assigned ip addresses. EuControl sees them, but then when I want to connect to them, I invariably get an error from euControl, and have to repeat the process.  This happens on all of the macs connected, with all of the boards.
    Is everyone else connecting to these boards the same way, or are you manually setting up IPs?
    We're on MC 5.5.3, 10.7.3
    HOME - MACBOOK PRO - 10.9.5 - 2.3 core i7, 16 GB ram. Media Composer 8, pro tools 11 WORK - Avid Isis 5000, MacPro 5,1 6-core Xeon, 16 GB ram, Avid... [view my complete system specs]
  • Tue, Aug 7 2012 12:05 AM In reply to
    • Posts 9,200
    • Points 205,355
    Re: Artist Mix controller EuControl - issues with connection
    What kind of error are you getting?
    You are using the ethernet crossover cable to connect directly to your Mac or local area network right?
    Have you done all this......
    Set up manual network location:
    1) Go to Network settings. Launch System Preferences (Apple Menu > System Preferences...) and press the Network icon.
    2) Unlock the pane to enable changes (lower left corner of panel - it will ask for your password)
    - if you wish for this to be the permanent default location, then skip to step 7
    3) Under the Location drop down menu, choose "Edit Locations..."
    4) Choose "Automatic"
    5) Click the button with a gear icon and choose "Duplicate Location". Name it "Artist Direct Connect" and click Done.
    6) Under the Location drop down menu, choose "Artist Direct Connect"
    7) Choose "Ethernet" in the list on the left. (If there are multiple Ethernet ports, use Ethernet port #1. This is the default port used for EuCon. The default port setting can be changed in System Preferences > Euphonix)
    8) In the Configure drop down menu, choose "Manually"
    9) In the IP Address field, enter: 169.254.1.2 (example)
    10) In the subnet mask field, enter: 255.255.0.0
    11) Press the Apply button
    12) Go to: System Preferences > Euphonix (v2.5.7 and earlier) or System Preferences > EUCON (v2.6 and later)
    13) Press Stop. Wait a few seconds, then press Start again. This will relaunch all EuCon processes with the new settings.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Aug 9 2012 1:05 AM In reply to
    • jogotron
    • Los Angeles
    • Posts 51
    • Points 760
    Fixed this issue for anyone else that has it.
    The artists mix boards do not connect well when directly connected to the macs. Connecting the boards to a router, and then connecting the router provides a much more stable connection.
    On the mac system prefs side, I left the ethernet connection set to DHCP. Connected the internet to the router. Connected the artists mix to the router. connected the mac. Done and done.
    also, I tried to use a switch, but it did not work. You need a router for plug and play.
  • Mon, Aug 20 2012 1:00 PM In reply to
    • Posts 9,200
    • Points 205,355
    I askd the engineer again for clarification and here is what he responded with:
    We generally do recommend the use of a router when connecting multiple units, via DHCP.  When using a switch, and when connecting the unit directly to the computer, we would recommend setting static IP addresses.
    If they are setting up a static IP address on the Mac, they also need to set one on the Artist unit(s) they are connecting. The instructions on how to do this are in the set up guide for each unit type, making sure the last field of the IP address is incremented for each artist unit connected. Make sure they have their firewall turned off, or that it is allowing the EuControl applications.
    Please see the FAQ’s for more information:  http://euphonix.avid.com/artist/ux/euphonix/artist_faqs.php?detail=8
  • Mon, Aug 20 2012 2:46 PM In reply to
    • Chuck Swan
    • Joined on Sun, Jul 31 2011
    • Chicago / Milwaukee
    • Posts 48
    • Points 665
    Had a similar issue a while back.  My artist surfaces would drop, rather than renew their dhcp ip leases.  Finally set up ip reservations in the router's dhcp config.  Haven't had any "vanishing" surfaces since.
    MC 8.4.4, MacOSX 10.10.5, MacPro 6core 16GB RAM, GTX Titan X GPU, Apple 23", Apple 27", Avid Artist Control, Avid Artist Transport, Blackmagic... [view my complete system specs]
  • Tue, Aug 21 2012 3:22 PM In reply to
    • Posts 9,200
    • Points 205,355
    Here is a KB article on the subject
    http://avid.force.com/pkb/articles/en_US/FAQ/en415251
    marianna
  • Wed, Mar 12 2014 9:06 PM In reply to
    • mecaudio
    • Joined on Wed, Mar 12 2014
    • Posts 1
    • Points 5
    Under System Pref> Network> Click the Gear dropdown at the bottom of the section that shows the available ports. Then click on "Set Service Order" the ethernet port you have connected to the hub that connects your artist series bring that port to the top of the list. Apply all settings reboot and try again. Eucon version 3 and above is very picky about the service order. Hope this fixes your issue.
  • Fri, Mar 20 2015 6:02 PM In reply to
    • cesing
    • Joined on Mon, Sep 22 2014
    • Posts 1
    • Points 15
    Good Day Marianna,
    Can you say what is the technical reason for use of a router when connecting multiple units, via DHCP??
    Thanks in advance,
  • Mon, Mar 23 2015 6:24 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,449
    • Points 63,180
      Moderator: MCA Mac
    You may end up with "unintended consequences" in that the control panel you connect to may not be the one you wanted.  Static addresses won't change unexpectedly when you least expect it.
  • Mon, Mar 23 2015 5:07 PM In reply to
    • Posts 9,200
    • Points 205,355
    Spot on Howard.
    thanks for answering
  • Tue, Mar 6 2018 6:07 PM In reply to
    I am having the same issue with a Mac running 10.10.5 and Eucontrol 3.7 with an old MC mix. It keeps giving me the netowrk configuration error. I have tried static IPs as well as DHCP. I have also tried crossover cable vs regular ethernet cables, and router vs switch. Please help.
