Latest post Thu, Aug 9 2012 8:01 PM by zacksnygg. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Jul 30 2012 7:01 AM
    • zacksnygg
    • Fort Lee, NJ
    • Posts 84
    • Points 1,090
    Exporting to DVCPRO HD via AVID??? Heeeeelp
    Greetings,
    I have to deliver several projects that are on my computer (they were all shot with a DSLR) and editied at 1080/59.96 DNXHD115.  The client however wishes to have DVCPRO HD 1080/59.96Quicktime files delivered on a hard drive.  I submitted the DNXHD115 files in the past and were told that they were NOT DVCPRO HD.  How do i export to DVCPRO HD as a Quictime option?  AVID only gives me the choice of DVCPRO NTSC?  I know DVCPRO HD is about 10bit and equals a gig a minute.  They seem similar.  What am i doing wrong?  :(
    confused
    Zack
    Pentium 4 CPU 3.6 Ghz Esata Drives 3000 gigs of memory Avid xpress 5.6.3 Avid Media Composer 2.8.1 [view my complete system specs]
  • Mon, Jul 30 2012 10:34 AM In reply to
    • Az Kola
    • Joined on Wed, Nov 16 2011
    • London, UK
    • Posts 275
    • Points 3,260
    Re: Exporting to DVCPRO HD via AVID??? Heeeeelp
    What version of Media Composer are you using to export the QTs?
    http://www.flickr.com/photos/azemkola [view my complete system specs]
  • Mon, Jul 30 2012 12:55 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Austria
    • Posts 651
    • Points 8,100
    AFAIK QT doesn't support DVCPro HD on windows systems. I think you need something like this:
    http://dvfilm.com/raylight/EncoderPro/index.htm
    HP xw8400 - 6GB RAM | W7 64 bit | MC 5.5.2 | Adrenaline with DNxcel Sony Vaio SB1Z1 - 6GB Ram | W7 64 bit | Blackmagic Design Ultra Studio SDI [view my complete system specs]
  • Mon, Jul 30 2012 1:14 PM In reply to
    • Ben Wilson
    • Joined on Thu, Jun 10 2010
    • Columbia, SC
    • Posts 218
    • Points 2,500
    What we have done in the past to get DVCProHD into a Quicktime wrapper from AVID is to transcode the media in AVID to the DVCProHD flavor you need and export Same as Source.
    Several. 1x MC7.0.4 HP z800 dual XEON x5650-2.66GHz 12MB Ram Quadro FX3800 NitrisDX. 4 TB GSPEEDes storage. 2x MC 7.0.4 HP z420 MatroxLE. GSpeedQ 8TB... [view my complete system specs]
  • Mon, Jul 30 2012 1:16 PM In reply to
    • the_dark
    • Joined on Fri, Aug 17 2007
    • Posts 165
    • Points 2,240
    Select the Avid DV100 codec. This codec is DVCProHD compliant.
    Dell Precision T3600 Intel Quad Core Xeon E5-1607 3.06Ghz 8GB Memory (4x2GB) 250GB System Drive 500GB to 1TB Media Drive nVidia Quadro 2000 Dell... [view my complete system specs]
  • Mon, Jul 30 2012 8:46 PM In reply to
    • zacksnygg
    • Fort Lee, NJ
    • Posts 84
    • Points 1,090
    Hmmm the problem is the DV100 functions takes forever to export and I am receiving errors upon export error - 106.  I have 12 60 minute projects that need to be delivered to DVCPRO HD.  I even need to change the frame rate from 1080/24p native to 1080/60i.  Trying to do this in the quickest and most effienct ways.  Has anyone had any luck with the Raylight EncoderPro that was recommended?
    Zack
  • Tue, Jul 31 2012 9:31 AM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    If I were you I'd export a DNxHD codec at same frame rate as your project and then send it out to frame rate converted at  post houses. This will give you accurate convertion.
  • Tue, Jul 31 2012 3:12 PM In reply to
    Try transcoding all your footage to DVCpro HD (or doing a mixdown to that resolution), Then making a Same as Source QT.
    I just tried it and it make a QT that was DVCpro HD.
    (EDIT: oops, just noticed that Ben Wilson mentioned this method earlier.  Have you tried it? It should work)
    Follow me at www.twitter.com/redarrowryan Avid 1- z400 6-Core, with Nitris DX Symphony 6.0.3 Win 7 64 Bit [view my complete system specs]
  • Sat, Aug 4 2012 8:35 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,351
    • Points 96,605
    Try DVCpro 100.  It's the same thing.
    As far as I'm aware, DVCpro HD/DVCpro 100 are 8-bit 4:2:2 codecs, not 10-bit.
    [EDIT] I really should read the whole thread before answering!  You've already been given this advice!  Twice!!
  • Wed, Aug 8 2012 6:36 PM In reply to
    • zacksnygg
    • Fort Lee, NJ
    • Posts 84
    • Points 1,090
    Hmm,
    Ugh, yeah the problem is i own a PC etc.  A Mac would give me that option etc.  I may have to go to someonne that has a AVID mac system etc.  But i still have the same problem with the frame rate conversion etc.  Also it sound GREAT regarding the DV100 conversion, the problem is that i am unable to export the footage (hour long programs) in a timely matter.  AVID also does NOT give me the option to Transcode or mixdown to a DV100 format with the software that i have :(
    Zack
  • Wed, Aug 8 2012 8:07 PM In reply to
    • EditGuy18
    • Minneapolis
    • Posts 202
    • Points 2,535
    Export a quicktime reference file for your original sequence.  Create a 1080i 59.94 project and set your import resolution to DVCProHD.  Import the QT Reference file.  Should create DVCProHD media in the format required.  Then you can export a Same As Source Quicktime movie.
    Avid Media Composer Nitris DX 5.0.3.8 - HP Z800 Workstation - Twin Hex Core Xeon 3.0GHz Processors - 12 Gig Ram - Windows 7 64-bit - NVIDIA QuadroFX 4800... [view my complete system specs]
  • Thu, Aug 9 2012 8:01 PM In reply to
    • zacksnygg
    • Fort Lee, NJ
    • Posts 84
    • Points 1,090
    Great idea, buuut it AVID only gives me the DVCPro HD option import function in 720/24p Native not in the 1080 projects.  Ugh again, i edit on a PC which appears to be the problem.
    Zack
