Latest post Wed, Apr 26 2017 6:43 AM by Mondo. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Jul 26 2012 3:40 PM
    AAF edit protocol? on or off?
    Can someone explain what the "AAF Edit Protocol" button does when making an AAF export.
    Should I select it when I am making AAF audio files to be opened in Protools?
    MC 8.5.3 OSX 10.11.6 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Thu, Jul 26 2012 4:49 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 213
    • Points 2,570
    Re: AAF edit protocol? on or off?
    It is my understanding that AAF edit protocol allows you to include AMA media in a Linked AAF. I do not know if there are other functions of the edit protocol.
    Dave/"Nutz"
    Freelance ACSR
    NYC Area
  • Thu, Jul 26 2012 5:11 PM In reply to
    I don't know about AMA (never heard that before, don't think you can even AAF-export AMA sources), but AAF Edit Protocol allows for >2GB file sizes.
    Manual says:
    "AAF Edit Protocol exported files can exceed the 2GB size limit. AAF Edit Protocol compliant files are not compatible with Pro Tools v7.1 and earlier."
    Some more info here.
    Media Composer /w Symphony option | PT-HD | Win7Pro64 HP | OSX MBP | ISIS5000 | Nitris DX | Artist Mix & Transport & Color | Decklink Studio |... [view my complete system specs]
  • Fri, Jul 27 2012 11:16 AM In reply to
    Hi Job,
    I read the same bit in the manual. It just seems that a "protocol" should allow for some extra information to go across but I can't see any difference between the two exports.
    I always have an issue with audio that has EQ/Audiosuite applied. If I send a clip with EQ to protools they get the effect media in the timeline but no actual effect to edit. As far as I can tell there is no automatic way for ProTools to step back to the original media. I usually end up sending a duplicate sequence without the rendered effects so they have that option
    I was hoping that the "edit protocol" may help with this.
    This quote in the document you posted would seem to suggest that it should be more efficient.
    "AAF is founded on the concept that everything necessary to create a finished program can be represented as composition metadata, with references to the media essence. By separating compositional metadata from media essence,"
    Unfortunately, I don't have Protools to be able to run any tests.
  • Fri, Jul 27 2012 3:15 PM In reply to
    My software:
    Pro Maintenance Tools - Tools to keep Avid Media Composer, Final Cut Studio, Final Cut Pro X and Adobe Premiere Pro running smoothly and fix problems when they arise
    Pro Media Tools - Edit QuickTime chapters and metadata, detect gamma shifts, edit markers, watch renders and more
    More tools...
  • Fri, Jul 27 2012 6:49 PM In reply to
    • gumbaedit
    • Richmond, VA/Los Angeles, CA
    • Posts 511
    • Points 6,725
    It works well with AMA in my experience.  Wrapped up a 50 minute Alexa show recently.  After cutting in DNx36, I relinked to the PR4444 files, then exported an AAF for the color correct in Davinci.  Everything went thru perfectly.  They loaded the AAF and it relinked to all of the Quicktimes without a hitch.
    My understanding of AAF protocol is that it allows certain keyframes to go thru on some filters used with audio (and with effects as stated earlier), but don't quote me on that
    6 core Late 2013 MacPro 3.0 gHz, 16 gigs RAM, MC 8.5.2 on OSX 10.11.3, DNxIO, Flanders CM250, BMD Desktop Video version 10.6.2 [view my complete system specs]
  • Fri, Jul 27 2012 7:05 PM In reply to
    Cool, did not know that!
  • Wed, May 7 2014 7:49 PM In reply to
    Does anyone have luck with Audiosuite plugins getting through to ProTools- tried various settings in the AAF dialogue and ProTools editor not seeing the effects so that he could use our settings as a starting point.
    MediaComposer 6.5.4.2 and Pro Tools 10
    MacPro, 10.7.5, MC 6.5.4.2 MacBook Pro, 10.8.5, MC 7.0.2 [view my complete system specs]
  • Fri, Apr 21 2017 7:24 AM In reply to
    • mattess
    • Joined on Wed, Dec 10 2014
    • Posts 10
    • Points 80
    Im also very interested in this issue. Threre are some new developments to hand over the plugin informations to protools?
    Regards,
    Matthias
  • Fri, Apr 21 2017 10:40 AM In reply to
    It would be essential that you tick the box to include effects when exporting from MC, as well as tick the box to include effects when importing in PT.
  • Wed, Apr 26 2017 6:43 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,602
    • Points 18,315
    Job ter Burg:
    Yep - I first found out about he necessity of ticking the AAF edit protocol box for linked media because it was necessary for Pluraleyes.
    John
