Latest post Sat, Jul 21 2012 12:58 PM by Vilem. 7 replies.
  • Tue, Jul 10 2012 4:08 PM
    • flashcutter
    • Joined on Tue, Mar 21 2006
    • New York
    • Posts 239
    • Points 2,860
    From 5.5 to 3.5 caveats
    I'm looking at a possible jon in which I would be working out of my home and then finalizing at a facility. Here's the glitch...I have MC 5.5 and the facility has 3.5. Besides being sure not to ue advanced effects, would the 3.5 system be able to read the 5.5? (Don't know yet whether the facility is using Mac or PC...I'm using Mac)
    Thanks.
    JM
    MAC PRO OS 10.7.5 Dual 2.28 GHZ DUAL-CORE XEON, 16GB 800 MHZ DDR2-FB-DIMM, MC 7 with Symphony Option, BCC9, Sapphire 7, Magic Bullet, NewBlue Filters... [view my complete system specs]
    Jonathan Moser www.flashcutproductions.com "Nothing's impossible...if you're not the one who has to do it..."
  • Tue, Jul 10 2012 4:18 PM In reply to
    Re: From 5.5 to 3.5 caveats
    Yes it will, with the caveat that any effects present in version 5 that are not in version 3 will be "read only" in version 3 as long as they were fully rendered in version 5 first. Any attempt to change those effects in version 3 will result in media offline for that pre-compute file until returned to version 5 for repair.
  • Tue, Jul 10 2012 4:34 PM In reply to
    • flashcutter
    • New York
    • Posts 239
    • Points 2,860
    Thanks Larry--is this theory or have you seen it actually work?
    JM
  • Tue, Jul 10 2012 4:36 PM In reply to
    I have taken projects from version 5 to version 4 successfully, within the caveat I described. Should work the same for version 3.
  • Tue, Jul 10 2012 5:02 PM In reply to
    • flashcutter
    • New York
    • Posts 239
    • Points 2,860
    Thanks Larry!
  • Tue, Jul 10 2012 5:17 PM In reply to
    You're quite welcome, Jonathan. Good luck!Yes
  • Sat, Jul 21 2012 12:31 PM In reply to
    • flashcutter
    • New York
    • Posts 239
    • Points 2,860
    Larry...a follow up. I did try this situation...cutting a simple sequence with no effects on 5.5 then taking it to a 3.5 system. What occured was a playback of the timeline cut in half (lierally) horizontally...with the picture playing on the top half and digital static on the lower half. I didn't have the time or inclination to troubleshoot past this so I installed 3.5 after deactivating 5.5. Just thought you'd like to know.
    JM
  • Sat, Jul 21 2012 12:58 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,401
    • Points 15,430
    flashcutter:
    JM
    I think it's a problem DNxHD codec.
    If you have access to dowload center more information here.
    http://esd.avid.com/ProductDownload.aspx?id=453
    and here
    http://avid.force.com/pkb/articles/en_US/compatibility/en290337?popup=true
    V.
    AVID MC2018.9 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
