Latest post Tue, Nov 20 2012 9:27 PM by Jamie Beedy. 16 replies.
  • Thu, Jun 28 2012 3:02 PM
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    Batch Capture from Sony XDCAM deck
    We're trying  to capture video from a Sony XDCAM XDS-PDW1000 deck via deck control. The deck is controlling fine, we're getting picture but if you try and Batch Capture a selection of clips you get an UNKNOWN  COMMAND ERROR. The deck will digitise on the fly but not in Batch Capture. The Avid / XDCAM pdf suggests you set the deck settings on MC to a HDW1800 or HDWM2000 but this doesn't work. Because we get sports footage from an event on XDCAM and don't necessarily need to digitise all of it it would be really helpful for us to do this. AMA is a real pain and not very accurate when handling such large files. All our other Sony decks (digibeta, hdcam, beta sp) are happy being controlled this way.
    Media Composer 8.3.1 - Mac OSX 10.10.5 - Macbook Pro 2.6 Ghz Intel i7 - 16GB RAM [view my complete system specs]
  • Thu, Jun 28 2012 3:57 PM In reply to
    • udosauer
    • Hamburg, Germany
    • Posts 448
    • Points 5,255
    Re: Batch Capture from Sony XDCAM deck
    If i remember right, only the PDW-1600 can be used for batch capturing, because sony hasn't implement all rs422 commands to the PDW-1000 deck.
    2x HP Z800 with Mojo DX and MC7.0 | 1x HP Z800 with Nitris DX and MC7.0+SYM-Option | 1x Unity MEFC5 [view my complete system specs]
  • Fri, Jun 29 2012 2:40 PM In reply to
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    Well that was £26K well spent then. Thanks Sony.
  • Fri, Jun 29 2012 3:17 PM In reply to
    One of my clients has a PDW-F75 and at one time (pre-AMA) we would capture off of the discs, but we'd use one of the HDV deck presets.  I think it was the HVR-1800 or so?
  • Sat, Jun 30 2012 9:02 AM In reply to
    • SteveK
    • Posts 305
    • Points 3,440
    when ever I have needed material of a PDW machine I have used FAM ( file transfer mode) by Firewire would it be better to ama this way?
    Or do you need to batch capture previously edited material?
    I use a U2 with XDCAM discs, ama and consolidate on Golf without too much problem.
    Sony Browser, also helps pre sorting clips.
    Steve
    Numerous clients mojo to Nitris PC systems 6.5 to 2018.3 with interplay with ISIS/UNITY, EVS transfer/w IP director At Home: new 2017 15" i7 MacbookPro... [view my complete system specs]
  • Mon, Jul 2 2012 8:40 AM In reply to
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    We get sports footage on XDCAM and often need to access small amounts of footage from certain discs. As the clips are 2 hours long it takes an age to flick through using the XDCAM browser to find a specific in/out point - it's not very accurate. It's so much quicker to spin through like a tape. The issue we have is recall when the media has been deleted and we want to redigitise it back into a sequence. We've got several U1's and a U2 so we've been doing it the USB import way for years now, unfortunately the PD1000 doesn't have any Firewire/USB connections.
    Everything else works fine - you can digitise on the fly. Nowhere on the Sony or Avid site does it state that the Batch Capture function is not available which given that it is essentially a VTR is a dumb omission.
  • Tue, Jul 3 2012 2:36 PM In reply to
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    Finally got to the bottom of it - Sony are issuing a new Firmware upgrade very soon to rectify the problem.
    The function was missing from the last two releases. Ooops.
  • Thu, Jul 12 2012 1:33 PM In reply to
    • jibanez80
    • Joined on Thu, Mar 8 2012
    • Posts 6
    • Points 50
    Just ran into this problem as well.  Any word on the Firmware upgrade availability?
  • Fri, Jul 13 2012 2:22 PM In reply to
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    Just got the firmware update today - it didn't work.
    Back to square one - not happy.
  • Tue, Jul 17 2012 8:47 AM In reply to
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    Borrowed a Sony PDWF70 to see if it works - no problem at all, didn't even need to select a deck, it worked on 'Generic'.
    So it's not a general XDCAM problem or a MC problem. It's a Sony problem !
  • Wed, Jul 18 2012 3:29 PM In reply to
    • jibanez80
    • Posts 6
    • Points 50
    Same here.  Patch didn't work on the media stations meanwhile our PDW-F1600 has never had a problem with the batch capture operation.
  • Thu, Aug 9 2012 8:51 AM In reply to
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    I have spoken to a contact at Sony who are going to look into it next week. Will keep you posted.
  • Mon, Oct 29 2012 10:39 AM In reply to
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    After dealing with Sony directly i have just installed version 2.0 of their XDCAM firmware (after previously installing version 1.26 and 1.29) - it still doesn't work.
    To reiterate, an older Sony XDCAM deck was happy to do this - is this an Avid thing or a Sony thing ?
    Is there an up to date device compatibility chart ? The only one i can find is over a year old ?
  • Mon, Nov 19 2012 11:05 AM In reply to
    • cxi2001
    • UK
    • Posts 169
    • Points 1,855
    I have now upgraded to MC 6.5.0.1, AMA V2.0 and have updated the XDS firmware to V2.01 and this still doesn't work despite assurances that from Sony that it would. The XDS firmware update allows it to be controlled from a conventional edit controller which one would assume would allow full control from an Avid ? Any help, as ever, hugely appreciated.
  • Mon, Nov 19 2012 11:22 AM In reply to
    THi isn't an AMA plugin issue (and the AMA plugin is created by Sony anyway) it sounds like a limitation of the deck to respond correctly to RS422 issued deck commands.
    Even if the deck seems to work correctly with an edit controller it doesn't mean it's responding correctly to the commands as issued by Avid during a batch capture.
    This sounds squarely like a Sony generated issue and only Sony can fix it.
