Latest post Fri, Jun 8 2012 2:06 PM by Tom Pearson. 3 replies.
  • Fri, Jun 8 2012 1:45 PM
    • tedtherock
    • Joined on Mon, Apr 23 2012
    • Posts 4
    • Points 60
    Huh? [:^)] Error, Disc is full.
    Hello Everyone, I have been exporting (drag and drop) files from my bin into either the Avid by Sonic DVD burner or Roxio to make DVD's of various projects.  Just recently I have been unable to export anything to my DVD burners.  I keep getting an error message.  Disc is full.  It does not specify where.  I am assuming it is on the C Drive and yet we also have an external 1TB E-drive.  I'm guessing that something keeps getting saved to the C Drive (not sure what that is) and I need to figure out what it is to change the setting to save it to my 1TB E-drive.  We have M.C. 5.5 on a Hewlett Packard computer.  Any and all suggestions would be greatly appreciated.  I'm still pretty new to this.  Thank you.
  • Fri, Jun 8 2012 1:54 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles Ca
    • Posts 1,428
    • Points 15,635
    Re: Error, Disc is full.
    most likely it is saving a copy on your c drive when you drag and drop. as your pgm is on your c drive I assume.. look in a media files  folder in your dvd authoring pgm  them try saving as a qt ref on your media drive and import them in your dvd authoring pgm
    mc 6.0.3 msi mb quad core 2.6 proc 8 gig crucial ram nvidia quadro fx 3500 2- 2 tb wd sata 7200 raid wd 500 gig sata 7200 os drive delta... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Fri, Jun 8 2012 1:58 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 5,969
    • Points 74,975
    • Moderator: MCA PC
    In Avid DVD, under PREFERENCES /  FILE CONTROL, if you have deselected "Delete the temporary files everytime I exit the application" your temp files will be saved each time, and eventually fill up the disc!
    Why would you have deselected this? One reason is that I suggest doing it in one of my tutorials on AvidDVD. I suggest this, as it can save time if you get a crash just at the moment the application has finished creating files and starts the burning process.
    If you do this, you must remember to delete the files at a later time.
    Regards,
    Douglas
    System 1:AMC MojoDX 6.0.3.1 - Windows 7 64 bit Pro SP1 - Nvidia Quadro FX3700, 275.89driver - Quicktime 7.7.1 - 24GB memory, i7 980 3.33GHz CPU - Asus... [view my complete system specs]
    Douglas, Japan - Video Tutorials that mere mortals can understand  http://www.gaijin-eyes.com
  • Fri, Jun 8 2012 2:06 PM In reply to
    • Tom Pearson
    • Los Angeles Ca
    • Posts 1,428
    • Points 15,635
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
