Latest post Tue, May 1 2012 2:50 AM by tidalpost. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Apr 29 2012 11:43 PM
    • tidalpost
    • Joined on Sat, Mar 31 2012
    • Posts 10
    • Points 110
    Please help me with a resize question.
    Hello, all!  Very simple edit here.  I'm flopping a shot of someone whose shoulder is cutoff on the right side.  However, it's a high contrast b&w shot and I can get away with using his left shoulder to fix the problem.  I was imagining I'd crop the flopped show and thus expose the shoulder underneath the video track with the flopped shot (using some resizing effects to line it up properly).  My basica question is how can I expose a video layer or frame that is essentially underneath another video frame?
    MC 6.0.1/10.7.3/2 x 2.66 GHz 6-Core Intel Xeon [view my complete system specs]
  • Mon, Apr 30 2012 1:46 AM In reply to
    Re: Please help me with a resize question.
    You'll need to use the "Animatte" effect in the key group. Use the "poly" tool from the wireframe tool column to draw a cut-out for the shoulder, and do it on V2 with your flopped shot on V1. You'll need to ALT drag a flop effect on top of the Animatte.
  • Mon, Apr 30 2012 4:32 AM In reply to
    • Euchrow
    • Joined on Sat, Apr 15 2006
    • Brussels, Belgium
    • Posts 180
    • Points 2,400
    Cropping a shot using the 3D warp effect, reveals the shot that's underneath.
    Symphony 6.5.0.1 on Mac Pro Westmere 3.33Ghz 6 core, 12Gb Ram, Radeon 5770, Mountain Lion 8.2, Matrox MXO2 Mini. - MC 6.0.3.2 on MacBook Pro Retina 2.6... [view my complete system specs]
  • Mon, Apr 30 2012 5:34 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 5,969
    • Points 74,975
    • Moderator: MCA PC
    Euchrow:
    Although this is correct, I think the point of Larry's suggestion is that the area that will become "transparent" can be shaped to fit the shape of the shoulder.
    The 3D warp is only going to be adjustable horizontally or verically (or both) - but not angled or curved.
    Regards,
    Douglas
    System 1:AMC MojoDX 6.0.3.1 - Windows 7 64 bit Pro SP1 - Nvidia Quadro FX3700, 275.89driver - Quicktime 7.7.1 - 24GB memory, i7 980 3.33GHz CPU - Asus... [view my complete system specs]
    Douglas, Japan - Video Tutorials that mere mortals can understand  http://www.gaijin-eyes.com
  • Mon, Apr 30 2012 6:28 AM In reply to
    • Euchrow
    • Brussels, Belgium
    • Posts 180
    • Points 2,400
    Maybe, but since the OP stated that he doesn't know how to 'expose a video layer that's underneath' it's good for him to know how to do some basic cropping and resizing.
    Problem with the Animatte is that although you can move the Mask, you can't move the cropped imaged from within the Animatte. So he would probably need to put an extra resize or 3D warp nested inside the Animatte to align both shots. Which then again makes the solution maybe more complicated than necessary.
  • Mon, Apr 30 2012 6:45 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 5,969
    • Points 74,975
    • Moderator: MCA PC
    Here is a video tutorial, in which I explain the use of the Animatte in a way that might be useful in this case.
    The object of the Tutorial was to answer a completely different post a few years ago, but it should still be reasonably relevant.
    This tutorial can be viewed at "Full-screen" by clicking on the icon on the toolbar
    I have also a little more about controlling the splines and their anchor points in this Tutorial
    Regards,
    Douglas
  • Tue, May 1 2012 2:50 AM In reply to
    • tidalpost
    • Posts 10
    • Points 110
    Thank you, everyone!  I'm able to use the 3D warp to make this simple fix but I'll be moving onto learning the Animatte effect ASAP.  This was a very helpful experience!
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
