hi guys,
weird problem: a video uploaded to youtube looks very different from the one I actually uploaded. Here is the workflow:
1080 25 project
export to DNXHD36 1080p/25 Color levels: RGB and standard bitrate
Then I export that video in MPEGstreamclip with these settings:
Quicktime h.264
100% quality
5000kbps data rate
Unscaled
no multipass
Deinterlace Video
check the picture to see the difference: left is in MC, bottom is final exported version ready for upload and right is the actual uploaded image.
MC and streamclip look different, but not much. The difference with Youtube is unbelievable!
Any ideas?
the right part falls of my page, i dont know if you see that too...
Is your editing screen reasonably well color balanced?When editing color, did you use the vector scope to ensure you are in range, and did you edit to 16/235 or 0/255I have found that a good color edit, on a color balanced screen, and processed in Sorenson, will hold its color reasonably well after processing on You Tube.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
MAC HOLLANDYORK REGION - ONTARIO
i edited in 0/255 with vector scope keeping it in range...
but how can the exported video differ so much from the uploaded one? what does Youtube change...
If you edit in 0-255 and then preserve RGB, what happens to the image between 0-16 and 235-255. Is that cliped when preserved as RGB
This could be the colour overlay your video card uses to interpet colour, before and after You Tube.
Youtube and/or QT cause all kinds of gamma shifts.
My experience with MPEG Stremclip is that you need to export your QT out of Avid in 709, not RGB.
709 instead of RGB results in the same problem.
ill start from the beginning, exporting the raw footage without color correction and see where it goes wrong...
but nobody has the same issues?
