Latest post Sat, Apr 28 2012 1:00 PM by Aniki56. 7 replies.
  • Fri, Apr 27 2012 4:11 PM
    • Aniki56
    • Joined on Mon, Apr 9 2012
    • Posts 12
    • Points 150
    Video on Youtube appears too crushed and saturated
    hi guys,
    weird problem: a video uploaded to youtube looks very different from the one I actually uploaded. Here is the workflow:
    1080 25 project
    export to DNXHD36 1080p/25 Color levels: RGB and standard bitrate
    Then I export that video in MPEGstreamclip with these settings:
    Quicktime h.264
    100% quality
    5000kbps data rate
    Unscaled
    no multipass
    Deinterlace Video
    check the picture to see the difference: left is in MC, bottom is final exported version ready for upload and right is the actual uploaded image.
    MC and streamclip look different, but not much. The difference with Youtube is unbelievable!
    Any ideas?
    comparison
  • Fri, Apr 27 2012 4:13 PM In reply to
    • Aniki56
    • Posts 12
    • Points 150
    Re: Video on Youtube appears too crushed and saturated
    the right part falls of my page, i dont know if you see that too...
  • Fri, Apr 27 2012 5:54 PM In reply to
    • MAC HOLLAND
    • Joined on Fri, Jun 9 2006
    • Holland Landing Ontario
    • Posts 740
    • Points 9,305
    Is your editing screen reasonably well color balanced?
    When editing color, did you use the vector scope to ensure you are in range, and did you edit to 16/235 or 0/255
    I have found that a good color edit, on a color balanced screen, and processed in Sorenson, will hold its color reasonably well after processing on You Tube.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    AVID MEDIA COMPOSER 4.08 Asus P6T6 WS Revolution Intel X58 LGA1366 Motherboard Intel Core i7 920 Processor BX80601920 - 2.66GHz, LGA 1366, 4.8GT/s QPI... [view my complete system specs]
    MAC HOLLAND
    YORK REGION - ONTARIO
  • Fri, Apr 27 2012 6:03 PM In reply to
    • Aniki56
    • Posts 12
    • Points 150
    i edited in 0/255 with vector scope keeping it in range...
    but how can the exported video differ so much from the uploaded one? what does Youtube change...
  • Fri, Apr 27 2012 6:14 PM In reply to
    • MAC HOLLAND
    • Posts 740
    • Points 9,305
    If you edit in 0-255 and then preserve RGB, what happens to the image between 0-16 and 235-255. Is that cliped when preserved as RGB
    This could be the colour overlay your video card uses to interpet colour, before and after You Tube.
    MAC HOLLAND
  • Fri, Apr 27 2012 6:31 PM In reply to
    Youtube and/or QT cause all kinds of gamma shifts.
  • Fri, Apr 27 2012 8:46 PM In reply to
    My experience with MPEG Stremclip is that you need to export your QT out of Avid in 709, not RGB.
  • Sat, Apr 28 2012 1:00 PM In reply to
    • Aniki56
    • Posts 12
    • Points 150
    709 instead of RGB results in the same problem.
    ill start from the beginning, exporting the raw footage without color correction and see where it goes wrong...
    but nobody has the same issues?
