Latest post Mon, Dec 28 2015 3:15 PM by Ryder. 16 replies.
  • Mon, Apr 23 2012 4:00 PM
    • SnOwHIO
    • Joined on Tue, Dec 20 2011
    • Posts 10
    • Points 110
    Invalid File Name error upon startup
    Using Avid MC 6.0.1 on an iMac.  Have not had problems before, but now everytime I try to start Avid, it stops when "Initializing Avid Media Access Volume Manager" stays on that for about 25 seconds and then a small dialog box appears that says "Invalid file name" to which I click OK and Avid is closed.
    Any help is much appreciated!
  • Mon, Apr 23 2012 4:05 PM In reply to
    Re: Invalid File Name error upon startup
    In your AMA files, make sure you do not have a "/" in the naming structure somewhere.
  • Mon, Apr 23 2012 9:13 PM In reply to
    • SnOwHIO
    • Posts 10
    • Points 110
    Disconnected a drive that the computer was trying to link to and that solved the problem.
    Thanks!
  • Mon, May 28 2012 4:55 PM In reply to
    • ClemAvid
    • Joined on Mon, May 28 2012
    • Posts 4
    • Points 65
    Hello,
    I meet the same problem at lauching the trial version of avid media composer V6, I get to the "Initializing Avid Media Acces Volume Manager " part and after a while, I get the error message "Invalid File name", I say OK and Avid get closed.
    The AMA file name is : MVP_MSP_Quicktime.avx
    I have an IMac with OS X version 10.7.2, 2,7 GHz Intel Core i5 and AMD Radeon HD 6770M 512 MB.
    Could you help me ?
  • Mon, May 28 2012 5:01 PM In reply to
    What about the name of the folder that file is located in? Is there a "/" in it?
  • Mon, May 28 2012 5:19 PM In reply to
    • ClemAvid
    • Posts 4
    • Points 65
  • Mon, May 28 2012 6:13 PM In reply to
    OK, if it's a quicktime movie file, for video import the file extension should be .mov. See these details on .avx files.
  • Mon, May 28 2012 7:02 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    ClemAvid:
    Larry, I think that this is the name of the ama plugin, more likely is that ClemAvid have an uncorrect media file in the root of one of his drives
    Tomas
  • Mon, May 28 2012 8:12 PM In reply to
    • ClemAvid
    • Posts 4
    • Points 65
    Ok, and how do I get that right ?
  • Mon, May 28 2012 8:18 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Just check your drives if you have any " loose " media files in the root of them , create folders and put those files inside of those folders or move them to wanted folders on other places .
    Tomas
  • Mon, May 28 2012 8:34 PM In reply to
    • ClemAvid
    • Posts 4
    • Points 65
    Ok, I'll try that. Thank you for the answer.
  • Tue, May 29 2012 2:10 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Any "illegal" characters in the file path will cause problems.  "Illegal" means characters that can be used by the OS for file operations.  On the Mac it's a colon ( : ), on Windows it's almost anything that isn't a letter or a number.  If you've got a folder or file named "Xmas Party 12/24/10" you'll have problems while "Xmas Party 12-24-10" will be OK.  When in doubt, remove anything suspicious
  • Thu, Jul 26 2012 10:48 PM In reply to
    Regarding the illegal character issue.  Most of us know not to use them in drive and folder names as is mentioned previously.  Check this out.  I had all my AMA volumes go offline without warning.  Double checked every drive, folder and file name.  All good.  Turns out it was a STORE BOUGHT CD from Rhino records that had a forward slash and a 2 quotes in the name of the disc as it showed on the desktop.  Wasn't playing or anything.  Just having it in the tray spun down was enough to make all AMA volumes offline to the Avid.  Ejected it and boom, everything back online.  For the record, no pun intended, all rhino records "Top rock ' roll hits" CDs have this illegal naming convention.  Example:
    Billboard Top Rock 'N' Roll Hits/ 1974
    Is the name of one of them.  Beware of illegal CDs!  They count as a volume.
  • Thu, Nov 8 2012 3:49 AM In reply to
    Having gotten the above same error -- I started going through all the drives, etc to check on illegal characters... and low and behold... I too had a Rhino Record  - Danny Gatton Anthology --that stopped my Symphony from launching.  Thanks for the help y'all!   I appreciate your time and help!
    Best,
    VQ
    Her main editing system is running AVID Symphony8.5. This system is running on an Intel Pro Mac -12 Core - 32gigs Ram - on a Samsung Pro 850 SSD Card... [view my complete system specs]
  • Tue, Apr 30 2013 11:20 AM In reply to
    • Ken Evans
    • Joined on Tue, Mar 27 2012
    • Kingston Upon Thames
    • Posts 44
    • Points 625
      Avid Certified User
    This thread just bailed me out of this same problem, had forgotten about the dreaded slash issue.
    Isis 5000 32TB Avid MC 6.0.3 Mac Pro, Dual 2.66 6 Core, 12GB RAM, Black Magic Multibridge Pro, Radeon HD 5770 1GB VRAM [view my complete system specs]
