Latest post Wed, Apr 18 2012 11:13 AM by Larry Rubin. 34 replies.
Page 2 of 3 (35 items) < Previous 1 2 3 Next >
  • Mon, Apr 16 2012 8:29 PM In reply to
    • Euchrow
    • Joined on Sat, Apr 15 2006
    • Brussels, Belgium
    • Posts 180
    • Points 2,400
    Re: just announced at NAB: Media Composer 6.1
    George Angeludis:
    MXO2 broken on Mac side?
    Yep, Avid gets unresponsive when Audio Scrub is turned on. Might of course be a Matrox driver issue, but there isn't a lot of activity on their side either. Bypassing the MXO2 and enabling FSP isn't an option because the FSP also is broken. Last time I checked, 6.0 was released 6 months ago... What annoys me is that apparently, Avid really made sure that with V6.0, the newly supported Kona and Decklink cards of the FCP crowd would work without any issues. Which is of course a good thing, but I would 've expected the same level of commitment for the Avid users that invested in a MXO2 workflow that worked quite well since 2010 when V5 was released.
    Anyway as I said, 5.53 works great, but it's frustrating I can't use 6.0 (which for the rest seems really good) because of this.
    Symphony 6.5.0.1 on Mac Pro Westmere 3.33Ghz 6 core, 12Gb Ram, Radeon 5770, Mountain Lion 8.2, Matrox MXO2 Mini. - MC 6.0.3.2 on MacBook Pro Retina 2.6... [view my complete system specs]
  • Mon, Apr 16 2012 8:51 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,130
    • Points 14,765
    Yeah, I can't use my MXO2 fully either, because of the trimming issues when audio scrub is enabled. And it's not an easy rollback to 5.x because of the updates to Lion and BCC 8.x that went along with it. Hoping for a fix sooner than later.
    Chris
    MacPro 2.66Ghz 8 Core (Nehalem, MacPro 4,1), 24Gb RAM, nVidia GeForce GTX 285, Intensity Pro, Tiger 10.7.4, MC 6.0.1.1, QT 7.6.6 [view my complete system specs]
  • Mon, Apr 16 2012 8:52 PM In reply to
    Euchrow:
    AFAIK, all companies have the same access level to the Avid I/O API. It is up to them to make the drivers. Decklink or AJA is not perfect either. The same Audio Scrub issues have been reported on both hardware. I know because I have a Kona 3G at home that often locks up during scrub.
    MC 6.5, Intel i7 920, Windows 7 64 bit SP1, Nvidia GTX 660 Ti - v306.97, 6 GB of RAM, QT 7.7, X-Fi Titanium Professional, MSI X58 SLI Platinum, ASUS 26"... [view my complete system specs]
  • Mon, Apr 16 2012 9:01 PM In reply to
    • Euchrow
    • Brussels, Belgium
    • Posts 180
    • Points 2,400
    conleec:
    Chris
    5.5.3.3 is compatible with Lion 7.3 and Boris can give you a serial for BCC7 if you own BCC8.
  • Mon, Apr 16 2012 9:16 PM In reply to
    • Euchrow
    • Brussels, Belgium
    • Posts 180
    • Points 2,400
    Dom Q. Silverio:
    Jumped to that conclusion after having read some blogs including Walter Biscardi's. He phased out FCP7 in favor of MC6.0 because it works flawlessly with his Kona3 cards.
    Anyway, I'm sure Matrox is partly to blame for this but at least after four months of bitching, they were able to reproduce the issue on March 30th. So I suppose we'll have a solution in the next four months or so. It's a pity that the BM Intensity Pro also has issues. Is it so hard to have a cheap and troublefree HDMI monitoring solution on 6.0 ?
  • Mon, Apr 16 2012 9:31 PM In reply to
    Totally agree.
    I am giving all companies involved some slack... for now. It is absolutely a new feature for Avid and a new API that Matrox, Blackmagic and AJA have to deal with it.
    Hopefully, MC 6.1 and new drivers will involve some bug squashing.
  • Mon, Apr 16 2012 10:37 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,553
    • Points 18,600
    Agree as well.  Since we don't "need" the features of 6, we are sticking with 5.5 for a little while longer.  It will just take a little more time for the manufacturers and Avid to get the new open format working better.  This was honestly expected since MC 6 is a huge change in code since it went to 64-bit and this is most manufacturers first time at interfacing their gear with Avid . . .
    System #1 - Mac Pro 12 Core 2.93, 24 GB RAM, 16 TB ISIS 5000 System #2 - Core i7 2600k, Windows 7, 16 GB RAM, Quadro 4000 System #3 - Dell Precision... [view my complete system specs]
  • Mon, Apr 16 2012 10:42 PM In reply to
    I have to differ as to using Looks or anything 64bit.
    MC6 is a lot but really a lot lot faster when it comes to rendering timelines with heavy compositions
    For example an 8 minute timeline (SD 16:9) with heavy effects on it needs 20 minutes at MC6
    (now with Quadro it does takes lesser).
    At MC5.5 it needs 50 or more.
    Desktop
    Zalman 600W/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.5/Corsair 16G DDR3/PNY Quadro 2000D(275.89)/WD VelociRaptor 300@10K(OS)/ 2x2TB WD RE4@RAID 0/LG BH10LS30/W7 Pro 64bit/Symphony 6.5.2.1/Matrox MXO2 Mini/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    IMDbLinkedInTwitterYouTubeFB
  • Tue, Apr 17 2012 10:27 AM In reply to
    • mark.burton
    • London, UK
    • Posts 776
    • Points 9,600
    Wim Van den Broeck:
    -JPEG2000 support
    This doesn't seem very popular here, but if it works well (color conversion is solid) and relatively fast (JPEG2000 is notoriously slow to encode), then it could offer a very useful temp screening workflow.
    No more HDCAM-SR decks so we can have 5.1, or lugging an Avid to the screening room. Export a DCP direct from a DNxHD offline and take a hard drive to the screening. Although I could be getting ahead of myself; maybe this feature is just the JPEG2000 encode and the DCP creation still has to be done in a 3rd party app?
    I've been looking for something like this for a while. Tried pretty much all the DCP software products, but while some are possible solutions, the good ones come at a hefty price. Looking forward to hearing more about this feature.
    Wim Van den Broeck:
    more later...
    Any more news?!
    MC 6.0.3.2/MacBookPro/2.66GHz Core i7/8GB RAM/SSD/OS 10.8.2 [view my complete system specs]
  • Tue, Apr 17 2012 10:53 AM In reply to
    • Swil
    • Australia
    • Posts 480
    • Points 6,185
    New in Media Composer 6.1!
    -AS-02 support!
    -JPEG2000 support!
    -Shoddy MXO2 support!
    Oh wait, that last one was already in 6.0. Was kinda hoping they'd remove that feature for 6.1...
    Oh well. MC5.5'll do for now (despite the fact I've paid for 6.0...)
  • Tue, Apr 17 2012 6:05 PM In reply to
    • Reanimated
    • Joined on Mon, Jan 16 2006
    • Stockholm, Sweden
    • Posts 229
    • Points 2,550
    any info abour when you can download it.... going to reinstall some computers and if it's only a few days I'll wait or if it's a few weeks I'll instal 6.0.1 first
    henrik
    Win7Pro 64bit, SSD systemdrives - Symphony 6.0.3, Nitris DX, Core i7 3930K (GA-X79-UD7), 16GB Quadro 2000 - Symphony 6.0.3, DeckLink Studio, HP Z400... [view my complete system specs]
  • Tue, Apr 17 2012 6:46 PM In reply to
    Henrik:
    MC 6.1 will still have to undergo moderator testing before it's released, and we have not received any word on that yet. Moderator testing usually takes at least 3 to 5 days, and that's assuming that we do not discover any additional issues that engineering might have missed, which can further delay the release. So, I'd advise you to install 6.0.1 at this time.
  • Wed, Apr 18 2012 1:08 AM In reply to
    • Posts 4,717
    • Points 60,160
    Folks,
    MC 6.1 was not " announced" at NAB.  They were shwoing a technology demo of some new features that are expected in a 6.1 but that hasnt been "baked yet" nor do we have any idea on a date.  The next one is 6.0.1.1 which is soon.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Wed, Apr 18 2012 6:32 AM In reply to
    Just edited the title.
    Symphony 6.5.2.1 Nitris DX | XW8600 2x X5450 16GB RAM | Quadro FX3700 | Win7Pro64 SP1 | SohoTank 16TB RAID5 | PDW-U1 | Qio MR | Artist Mix & Transport... [view my complete system specs]
    Follow @editorbelga on Twitter
  • Wed, Apr 18 2012 6:40 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 10,419
    • Points 123,410
    Re: technology demo at NAB: Media Composer 6.1
    Thats better
    Mac: 17" Macbook Pro i7 2,66 ghz with 8Gb Ram, 500gb 7200rpm drive___ PC: W 7 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem 8 GB Corsair... [view my complete system specs]
    Tomas
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
