Latest post Mon, Nov 30 2015 5:06 PM by Kevin Klimek. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Apr 2 2012 3:37 PM
    • Anthony
    • Joined on Wed, Jul 21 2010
    • Sydney
    • Posts 43
    • Points 580
    Export/Import individual user settings.
    Is it possible to export/import a particular user setting ie. keyboard layout.
    I wish to bring my keyboard layout from my user settting into another editor's already established user profile. It's the only element I wish to import.
    Mac OS 10.6.4 | MacMini: 2.66 GHz Intel Core 2 Duo, 4GB RAM, NIVIDA Gefore 9400 256MB graphics card, 500gb HD | Media Composer 6.0 [view my complete system specs]
    Filed under: , ,
  • Mon, Apr 2 2012 3:43 PM In reply to
    Re: Export/Import individual user settings.
    The easy way I do it is to copy any settings I want into the site settings whilst under the user settings of user1 (site settings are under the special menu.
    The change to user 2 settings and drag the required settings back out of the site settings into users 2s settings. There are otehr ways as well.
  • Mon, Apr 2 2012 3:59 PM In reply to
    The other way Pat refers to is (with the "settings" tab active in the project window), go to File>Open Setting File. Then, navigate to the particular user's folder you want to copy from, open that folder and select the "(user name)settings.avs" file. Another window opens with that user's entire settings profile. Find the setting you want and drag it into the existing user profile open in the project window - add or replace as you desire.
  • Wed, Apr 4 2012 3:02 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,025
      Moderator: MCA Mac
    Larry's method has another advantage: when you drag a setting into the setting window it's checked for compatibility with the version you're running and either adjusts accordingly or tells you it's incompatible.  Better to know this up front rather than finding out later when things appear to go wonky.  (That's a technical term...)
  • Wed, Apr 4 2012 3:11 AM In reply to
    • Anthony
    • Sydney
    • Posts 43
    • Points 580
    Thanx for the feedback! The "load settings" worked perfectly. Knew there was a simple way!
  • Sat, Nov 28 2015 10:46 AM In reply to
    • zb
    • Joined on Thu, Jun 5 2014
    • warsaw, poland
    • Posts 7
    • Points 95
    Is there a way to take my settings to another workstation on a pen drive, specificaly the keyboard layout?
    MC v 7.0.4, Windows 7 Pro, Service Pack 1, HP Z400, 64bit, Intel Xeon, W3670@3.20GHz, 12 GB Ram, NVidia Quadro FX 1800 [view my complete system specs]
  • Mon, Nov 30 2015 5:06 PM In reply to
    Just grab your whole settings file and carry it with you.
    If you do need individual settings, open that setting file (when in Settings, select File > Open Settings) and drag the settings you want to copy to a new user.
