Latest post Tue, Apr 3 2012 2:53 AM by jef. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Apr 2 2012 2:48 PM
    • tdunlop
    • Joined on Sun, May 29 2011
    • Los Angeles, CA
    • Posts 8
    • Points 100
    HELP! ndf, df question
    I'm an FCP guy with some Avid experience and I need help doing something I think is probably pretty easy.
    One of our field cameras recorded DF and NDF footage. We're grouping it all together, and the DF stuff I need to transcode or modify into NDF. Also I think I imported the audio at DF but need to modify it to non drop as well - how is this done?
    3.5GHz Intel Core i7 Memory 16GB 1600 MHzDDR3 Avid Media Composer 6.5.4.7 [view my complete system specs]
  • Mon, Apr 2 2012 3:11 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 963
    • Points 12,210
    Re: HELP! ndf, df question
    There isn't anything physical about the footage itself that makes it DF or NDF - it's simply a way the frames are counted and layed down on the timecode track.  What's important, if you need to make the distinction, is whether your sequence is DF or NDF.
    Media Composer v8.9.2 | Windows 10 Professional 64-Bit | Supermicro X10DAi | Intel Xeon E5-2620 v4 Broadwell (x2) | Noctua NH-D9DX i4 (x2) | PNY GeForce... [view my complete system specs]
  • Mon, Apr 2 2012 4:27 PM In reply to
    • tdunlop
    • Los Angeles, CA
    • Posts 8
    • Points 100
    But the mixture of df and ndf won't group together properly. The timecode check before subclipping doesn't add up. I think I need to transcode the df - is there a way to do that or do I need to retranscode from the original P2?
  • Mon, Apr 2 2012 4:42 PM In reply to
    Philip/Pheral's explanation was correct.  You don't have to do anything to the footage at all; just make sure your sequence timecode is DF or NDF (whichever you require).
    As for the footage, capture it and use it like you would any other footage.
    tdunlop:
    Mark common inpoints and try it; it'll work fine.
    Media Composer 2018.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Mon, Apr 2 2012 9:37 PM In reply to
    • EditGuy18
    • Minneapolis
    • Posts 202
    • Points 2,535
    You'll need to modify the clip to make it drop frame.  With P2 however, you may need to go in and assign it a tape name in order to change from drop-frame to non-drop.
    Right Click on the clip, select modify, then Set Source.  Give it a name, doesn't really matter.
    Then you should be able to go in and modify the drop/non-drop settings.
    Good Luck.
    Avid Media Composer Nitris DX 5.0.3.8 - HP Z800 Workstation - Twin Hex Core Xeon 3.0GHz Processors - 12 Gig Ram - Windows 7 64-bit - NVIDIA QuadroFX 4800... [view my complete system specs]
  • Mon, Apr 2 2012 9:42 PM In reply to
    • tdunlop
    • Los Angeles, CA
    • Posts 8
    • Points 100
    So if I have this straight -  Bring up the P2 volume in AMA, Modify > set source, give it a new tape name,  Then go one by one in the bin altering the colon to a semi-colon? Thanks for your help, this is driving us crazy!
  • Mon, Apr 2 2012 9:51 PM In reply to
    • EditGuy18
    • Minneapolis
    • Posts 202
    • Points 2,535
    Under the very same menu that you use to set the source, you can also change the clip from drop frame to non-drop.  At the very top is "Set Timecode Drop/Non-Drop."
  • Mon, Apr 2 2012 10:34 PM In reply to
    • tdunlop
    • Los Angeles, CA
    • Posts 8
    • Points 100
    I tried this, but no change in the timecode - it's still DF, still that colon there in the start timecode.
    I selected all the clips in the bin (having brought them up using AMA)
    Right Click, Modify, Set Source, named them TEST,
    Switched TC from the Drop Frame to the Non Drop Frame button
    OK
    Start timecode is still in DF.
    Any idea why this method isn't working?
    I appreciate all the help by the way!
  • Tue, Apr 3 2012 12:20 AM In reply to
    • tdunlop
    • Los Angeles, CA
    • Posts 8
    • Points 100
    Okay - SOLUTION.
    FIRST: I had it wrong, what I thought was drop-frame footage was in fact NON-drop frame footage.
    Drop frame footage has a semi-colon.
    The modify feature changes drop-frame to non-drop-frame very consistently, if you give the footage a new source name first.
    I didn't think it was working because I expected a semi-colon. Basically, I'm a moron.
  • Tue, Apr 3 2012 2:53 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,201
    • Points 38,855
    Well you have learned some things, but I agree with others in this thread.  You did not need to do this.  And now you have made possibly made life harder for yourself if you need to go back to the original, unmodified footage for some reason.
    Grouping can be done by several methods.  When TC does not match, you just find common sync points (a clapper board fro example visible to all cameras), mark that with an In point or Out point and then select the appropriate sync method in the Group tool.  I do this often.
    Now, one thing to know about your modifying.  If you do this for media captured from tape (and I assume for P2 treated like tape), all you are doing is making a modification to Avid's database information about this media.  And the only place that this is valid is on a system which has the bin you did the modifying in.  Another way to say this is that you did NOT actually change the real MEDIA.  You just put a Post It note of sorts telling Avid to ignore the REAL tc on that media and use this other new one.
    If you REALLY want to burn that into the media, you need to Consolidate that modified clip.  This will write both a new Master Clip (metadata) and Media (the real picture & sound) with the modified data integrated into the media.
    This knowledge can sometimes be a lifesaver.
    Good luck,
    Jef
    Avid DS 11.0.2 R.I.P | MC 8.5.3 / 8.9.4 | OS 10.11.x - various MacPro Towers - home system MacPro Dual 2.8 8core GTX680 "Harpertown" QT 10.0... [view my complete system specs]
    Jef Huey
