Latest post Tue, Mar 27 2012 6:36 PM by EditGuy18. 7 replies.
  • Sat, Mar 24 2012 12:15 PM
    • slicker
    • Bucharest, RO
    • Posts 182
    • Points 2,580
    Can you consolidate more than one bin at a time when all the material is AMA, like select all bins and consolidate ?
    Laurentiu
    Avid DS v10_2_1, Avid ISIS 5000 32 TB, 2 Symphony Nitris DX , 4 MC SW, , Avid VideoRaid SR 16TB [view my complete system specs]
    Laurentiu Rusescu.Bucharest.RO
  • Sat, Mar 24 2012 1:08 PM In reply to
    Re: ama
    It would be easy if you could consolidate from the bin.
    But you can't. You have to select files as with transcoding.
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.5 with Symphony Option/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Sat, Mar 24 2012 1:11 PM In reply to
    • slicker
    • Bucharest, RO
    • Posts 182
    • Points 2,580
    Re: ama
    sa the answer is no .
  • Sat, Mar 24 2012 1:16 PM In reply to
    Re: ama
    I can't see a way to do it so it is no.
    Desktop
  • Sat, Mar 24 2012 2:39 PM In reply to
    • EditGuy18
    • Minneapolis
    • Posts 202
    • Points 2,535
    Re: ama
    What I have done in the past is create a "Consolidate" bin.  Then Alt-Drag (copy) the master clips from each of my AMA bins into this bin.  Then consolidate all the master clips in the "Consolidate" bin to my media drives selecting "Relink to Target" when the window comes up.  When finished the Master clips in both the "Consolidate" bin and all the original bins are linked to the local media folder. (I'm also running in an Interplay environment which may, or may not affect the results)
    This has worked pretty well for me when consolidating a dozen or so P2 cards organized into different bins.  The computer does all the work while I go home and sleep.  Big Smile
    Avid Media Composer Nitris DX 5.0.3.8 - HP Z800 Workstation - Twin Hex Core Xeon 3.0GHz Processors - 12 Gig Ram - Windows 7 64-bit - NVIDIA QuadroFX 4800... [view my complete system specs]
  • Sat, Mar 24 2012 2:56 PM In reply to
    Re: ama
    I can confirm that you cannot select all bins and consolidate. If fact, there is no "select all bins" for any function. The closest you come to it is when the media tool populates it's bin.
  • Mon, Mar 26 2012 10:11 PM In reply to
    • slicker
    • Bucharest, RO
    • Posts 182
    • Points 2,580
    Re: ama
    Hi EditGuy18 ,
    I used your tip and it worked !
    Thanks!
    Laurentiu
  • Tue, Mar 27 2012 6:36 PM In reply to
    • EditGuy18
    • Minneapolis
    • Posts 202
    • Points 2,535
    Re: ama
    Excellent. . . .  Glad I could help!
