Latest post Tue, Aug 14 2012 8:07 PM by Vilem. 13 replies.
Page 1 of 1 (14 items)
  • Thu, Mar 15 2012 11:03 AM
    Arri AMA Plugin Causing an ACCESS_VIOLATION Exception
    I have recently installed the Arri AMA Plugin for MC6 Windows. The name of the file is setup_ALEXA_AMA_MC6.msi.
    After doing this, I get an "ACCESS_VIOLATION excepting" error message whenever I AMA link to any .MOV file. After clicking "OK" the .MOV proceeds to link properly, AFAICT. But this is very annoying, esp. when linking to multiple files.
    When I uninstall the Arri Plugin, the error message no longer happens. This clearly makes me think that the problem is being caused by the Arri Plugin. Also, the Error Log's Exception Report reads as follows:
    ________ Exception Report ________________________
    Exception Code: C0000005 ACCESS_VIOLATION
    Fault Module:   01:0000947A C:\Program Files\Avid\AVX2_Plug-ins\AMA\MVP_MSP_ARRI_MXF(x64).avx
    Fault Address:  0000000047FCA47A Symbol not found
    MC 6.0.3.3, QT 7.7.1, Nvidia driver 310.90 (using at my own risk), Window 7 Professional 64-bit SP1, IE9. Quadro 2000 and 600 videocards (four monitors... [view my complete system specs]
  • Thu, Mar 15 2012 5:55 PM In reply to
    • Kristina
    • Joined on Sun, Nov 28 2010
    • Germany
    • Posts 458
    • Points 5,500
    Re: Arri AMA Plugin Causing an ACCESS_VIOLATION Exception
    Just a shot in the dark, but with win7 I sometimes get problems (with other applications) when not installing or running the programs with administrator rights or don´t have ownership of all folders.
    And did you tried downloading it again, maybe corrupt setup file itself?
    Best regards,
    Kristina
    several z800 and xw8600 Nitris DX, MC v.5.5.3, Win XP Prof SP3, ISIS-5000 16TB with Force 10 Switch 10Gig, several MOG S1010 ingest servers, several EVS... [view my complete system specs]
  • Fri, Mar 16 2012 4:44 AM In reply to
    Hi Kristina,
    Thanks for the ideas. However I am using the Administrator account and permissioned the media drive to full access for everyone.
    Also, uninstalling the Arri the plugin makes the problem go away. And the Error Report mentions "ARRI" in it, even though none of the .MOV files I linked to is from an Alexa.
    I uninstalled, downloaded again and reinstalled. Same problem.
    But thanks for the suggestions!
    P.S. If you get a chance to try this yourself, that would be great. The download is VERY quick. If we can get confirmation on this by other users it helps the bug reporting process. Wink
  • Fri, Mar 16 2012 12:39 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 7,394
    • Points 85,345
    BobbyMurcerFan:
    When is an administrator not an administrator?  When the OS is Windows 7!
    BMF, if you logged in as a user with administrator privileges, you may not have done what you thought you did.  Try reinstalling by right clicking on the installer and selecting "Run as Administrator" from the drop down menu.  In Windows 7 that administrator has full system control, unlike a user with administrator privileges.
    MC 5.5.3.2 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - Windows 7 Ult64 SP1 - nVidia Quadro FX 1800 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way... [view my complete system specs]
  • Fri, Mar 16 2012 1:24 PM In reply to
    • Kristina
    • Germany
    • Posts 458
    • Points 5,500
    jwrl:
    Wink like that sentence and yes, that is exactly my expereince with right click on installer "run as administrator"
    I could try the arri-plugin next week, but as I´m still on MC5.5.3 and WinXP, I´m not sure if my information will be usefull?!
    Best regards,
    Kristina
  • Fri, Mar 16 2012 9:13 PM In reply to
    Thanks for the help guys and girls. The Alexa installer is an .msi file, not an .exe. So right click does not have a Run as Administrator choice. I tried a commandline instruction to run the .msi as an administrator, but the installer asks for a server location. Very odd and I don't want to mess with it.
    But anyway, I am pretty sure that I am THE Administrator and not a user with Administrator privileges. I really think this is an issue with the Arri plugin. As I've not had this issue with any other AMA plugins installed on the machine.
  • Sat, Mar 17 2012 4:33 AM In reply to
    • jwrl
    • Posts 7,394
    • Points 85,345
    BobbyMurcerFan:
    I have an idea which may work.  I can't currently test it because I'm at home and only have Linux available, but you might like to try this.
    Let's assume that your installer is called AlexaAMA.msi.  Open Notepad and type AlexaAMA.msi followed by a carriage return.  Save it as install.bat to the same directory as your msi file, then right click that and run it as administrator.  See if that helps.
    If it bombs out with a syntax error you may have to type exec AlexaAMA.msi instead.
    As I said, I can't currently check this.  Given that you seem to have done all the right things anyway, this may not help either.
  • Sat, Mar 17 2012 8:13 AM In reply to
    Thanks for all the time on this. I've tried using the Windows created "Administrator" account, and still the same behavior. I'm pretty confident that this is a bug. Sad
    P.S.
    However, you and Kristina's suggestions got me to thinking about another issue w/ MC6 concerning "Enabling Video Editing Mode" in the Nvidia Control Panel.
    http://community.avid.com/forums/t/107170.aspx?PageIndex=3
    I tried loging on as Administrator and low and behold, I was able to activate "Enable Video Editing Mode." So THANKS MUCH. Wink
  • Sat, Mar 17 2012 11:08 AM In reply to
    • jwrl
    • Posts 7,394
    • Points 85,345
    At least something came of this!  Not the result you wanted, but a result, I guess.
  • Wed, Apr 11 2012 2:51 PM In reply to
    I can confirm this ARRI AMA plug-in behaviour:
    http://community.avid.com/forums/p/108114/626359.aspx#626359
    Symphony 6.5.2.1 Nitris DX | XW8600 2x X5450 16GB RAM | Quadro FX3700 | Win7Pro64 SP1 | SohoTank 16TB RAID5 | PDW-U1 | Qio MR | Artist Mix & Transport... [view my complete system specs]
    Follow @editorbelga on Twitter
  • Mon, May 7 2012 10:22 PM In reply to
    • Posts 4,730
    • Points 60,295
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Wed, May 9 2012 12:29 PM In reply to
    • Posts 4,730
    • Points 60,295
    Arri is working on this and thee is a workaround posted.  Here is is again for this thread.....
    Quick work around: If, in the dialog box, you select the "Quicktime" AMA plugin instead of "All AMA Plugins", you can successfully import the quicktime file.
  • Tue, Aug 14 2012 5:22 PM In reply to
    • Posts 4,730
    • Points 60,295
    Raj posted that this is fixed so please check out...........
    http://community.avid.com/forums/t/111791.aspx
    Specifically.....
    "   This issue was caused by the ARRI plug in.  Avid engineering got a confirmation from ARRI today that their latest plug-in fixes this issue.  Please test and report that the problem is fixed. "
    www.arri.com/alexa/downloads.
  • Tue, Aug 14 2012 8:07 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 885
    • Points 9,810
    Thanks for the info. Tested, and the error disappeared. Yes
    V.
    AVID MC6.5.2.1- dongle, INTEL Core i7-950,Gigabyte-GA-EX58-UD5, Quadro 4000 - driver 310.90, RAM 12GB - 6 x DDR3 Corsair, command8, MXO2mini - driver 7... [view my complete system specs]
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
