Latest post Wed, Dec 28 2011 4:04 PM by Bokes. 2 replies.
  • Wed, Dec 28 2011 1:10 AM
    • Bokes
    • Posts 219
    • Points 3,205
    1080p 29.97- unable to set video format?
    I set up a new project as 1080p 29.97
    When i go to open the project i get a error box that Avid is unable to set this video format(?)
    All other format settings seem to work fine.
    Is this a known bug or something else?
  • Wed, Dec 28 2011 3:00 PM In reply to
    Re: 1080p 29.97- unable to set video format?
    Some output cards do not support this format.  That is a limitation of the card, not the Avid software.  You should be able to create/open 1080p/29.97 projects in either as software-only or with a DX box attached.
    What 3rd party hardware are you using?
  • Wed, Dec 28 2011 4:04 PM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    Blackmagic HD extreme.
    I see what you mean- my laptop (no external card)  does not have this limitation.
    What is the work around on the Macpro with this card?
    This might be a silly question but- Is there a way to "switch" the card on and off between projects?
