Latest post Thu, Feb 16 2012 12:37 AM by Glyph. 13 replies.
Page 1 of 1 (14 items)
  • Wed, Dec 14 2011 7:54 AM
    • Glyph
    • Joined on Fri, Aug 12 2011
    • Posts 12
    • Points 130
    Error Message on Startup
    This is an error message I have been getting fairly often on startup:
    Exception: AMPI subsystem error, ErrorMessage: DSM future error from client eDSMError_exception:assertion in "DSM_Transport.cpp", line 118 (err=60),
    D5MMnager::InitializeDSM in DSMManager.cpp: 342,
    AMPIMainComponent Rep::Initialize InitializeDSM Failed in AMPIMain.cpp: 81
    AMPIMainComponent::Initialize mRep->Initialize in AMPIMain.cpp: 159,
    AMPIMainComponent::Initialize in AMPIMain.cpp: 163
    It usually comes up while it says it is initializing Audio Plugins.  Usually I can restart MC and it will eventually open after a few attempts. This has been a consistent problem for the last few days though and I was wondering if there was anything I could do to prevent it.
    Macbook Pro 2.3ghz i5, 4 GB ram, OSX Lion 10.7.3 MC 6.0.1 [view my complete system specs]
    Filed under: ,
  • Wed, Dec 14 2011 10:31 AM In reply to
    • Glyph
    • Posts 12
    • Points 130
    Re: Error Message on Startup
    I've been getting another error also quite often while working which is crashing Avid.
    Exception: std::exception, what:"Segmentation fault" in thread "MainThread", at address 0x0
    I haven't found a common theme for when that one comes up, but really it shouldn't be this unstable, just today it has crashed at least a dozen times.
    Filed under: ,
  • Wed, Dec 14 2011 10:34 AM In reply to
    I'm not a Mac person, but I know these errors come up often enough that if you search google for "avid forum ampi error" or "avid forum segmentation fault" you'll get a lot of results.  Hopefully one of them will point you in the right direction while you're waiting for a response from some other Mac users.
    ciao,
    Carl
  • Wed, Dec 14 2011 4:17 PM In reply to
    It shouldn't be that unstable...
    Do you have any outside audio plugins?  Did you do a clean install when you upgraded to Lion?
  • Thu, Dec 15 2011 6:35 AM In reply to
    • chellecca
    • Burbank, California
    • Posts 1
    • Points 5
      Avid Certified User
    Upon launching MC v6 trail I'm getting the following message:  Alert  "Segmentation fault" in thread "Main Thread", at address 0x0
    Only option is to click on ok which drops me back to the desktop.  I have restarted and trashed the MC State and Site Attributes but still unable to launch the trial.
    Any help on this would be great!
    MacBook Pro
    Processor: 2.3 GHz Intel Core i5
    Memory:  4 GB 1333 MHz DDR3
    Software: Mac OS X Lion 10.7.2
    Tracy D. Smith
    Online Editor, Colorist,
    ACI
  • Thu, Dec 15 2011 8:58 AM In reply to
    • Glyph
    • Posts 12
    • Points 130
    Hey,
    Yep it was a clean install of MC6 onto Lion.  I don't use any plugins for Avid, but I use some instrument samples for Pro Tools, that really shouldn't be a problem though.  Its funny because I haven't really had these problems till just recently.
    As for the other threads, thanks for the tip I'll look for those and see if anything shows up.
    Chellecca, thats the exact same problem I'm having, hopefully we can find a solution in here somewhere.
  • Thu, Dec 15 2011 4:21 PM In reply to
    Can you remove the plugins or put them on your desktop and see if that is the problem?
    Is this an MC/PT co-install?  Did you install the programs in the correct order?  And do you have the version of PT that is supported with MC v6.0?
  • Fri, Dec 16 2011 7:48 AM In reply to
    • Glyph
    • Posts 12
    • Points 130
    I did a clean install of PT 10 soon after it was realeased and then did another clean install of MC6 when it was released about a month later.  Just checked for version updates on PT and I have the latest one so that shouldn't be an issue.
    On a side note, the SegmentFault error happens quite often while applying affects.  Usually, I'll hit apply (from AvidFX) and then it will freeze up and give me the error.
  • Mon, Dec 19 2011 9:03 AM In reply to
    • Glyph
    • Posts 12
    • Points 130
    I can verify again that the SegmentFault happens whenever I apply an effect, and its not anything huge.  Usually I am just adding some titles from AvidFX.  I have looked for other threads but have not found any that are similar to what I am experiencing.
  • Mon, Dec 19 2011 10:15 AM In reply to
    • Glyph
    • Posts 12
    • Points 130
    Oh another bit of info, I've been getting a lot of Audio Underrun errors I believe its because at the moment I'm working off a USB 2.0 drive, would that have an effect on anything else I've been mentioning though?
    UPDATE
    Apparently this problem has been solved for MC6 on windows (http://community.avid.com/forums/p/102722/592302.aspx#592302) I have looked at the KB document and followed the steps for OSX, reinstalled the drivers and ran a permissions repair on my drive (not from the installation disk because none was provided for Lion) but the problem persists.
  • Thu, Dec 22 2011 8:47 AM In reply to
    • Glyph
    • Posts 12
    • Points 130
    Hey guys I really need some input here, these problems have been consistent from the first time I posted and have been preventing me from getting any work done at all.
  • Wed, Feb 15 2012 9:23 PM In reply to
    HOW CAN I FIX THIS...........................................
  • Wed, Feb 15 2012 9:25 PM In reply to
    Have you installed v6.0.1?
  • Thu, Feb 16 2012 12:37 AM In reply to
    • Glyph
    • Posts 12
    • Points 130
    Ok here is what I did, I eventually got things to work but I had to get a firewire external hard drive and run my media off that.  I was running off of a usb 2.0 drive and usb just doesn't cut it.  Its a pain because you have to sink money into it but thats how it worked for me.  I can't guarantee you're particular problem will be fixed by doing that but I hope the idea helps.
