Latest post Fri, Dec 9 2011 9:42 PM by George Loco Angeludis. 22 replies.
Page 1 of 2 (23 items) 1 2 Next >
  • Wed, Dec 7 2011 7:14 PM
    • StephenW1
    • Joined on Sun, Dec 4 2011
    • Posts 28
    • Points 400
    12 hour+ Import times in Avid MC6...
    I've been using MC5.5 on my current computer and everything's been smooth and easy, however upon upgrading to MC6 import times have shot from anywhere between 5 hours to 15 hours.
    I have gone to past projects and tried re-importing footage (to the same project/settings) that once took 10minutes-an hour, now it takes 6 hours+ which is why I've narrowed it down to either MC6 or my Avid settings (which I have also checked thoroughly and everything seems fine).
    I guess my question is what can I try from here? Is anyone else having/had this issue before?
    My PC is above and beyond the necessary hardware required to run Avid MC6, this shouldn't be an issue. Sorry if I'm missing necessary information, it's my first time using these forums. I have found one or two others with this issue around the net on past versions of MC but no answers.
  • Wed, Dec 7 2011 7:19 PM In reply to
    Re: 12 hour+ Import times in Avid MC6...
    Importing what kind of footage (format/frame rate) into what kind of project?
    ciao,
    Carl
    Symphony 6.5.2.1, HP dv9605ea, Windows 7 Pro 64, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Wed, Dec 7 2011 7:39 PM In reply to
    • StephenW1
    • Posts 28
    • Points 400
    Hrm, it seems to just be .mp4 formats since I've been importing them a lot recently, though I was importing the same files fine on MC5.5...
    For example:
    Project:
    Type: 25p PAL, Aspect: 16:9, Colour Space: YCbCr 601, Raster: 720x576
    File: 720x576, 25p, mp4,
    I've tried pretty much all import formats/import res settings.
  • Wed, Dec 7 2011 8:12 PM In reply to
    If they're .mp4, I'd bet they are H.264 and RGB.  That doesn't account for the time you're seeing, but it will affect the look of them after they are imported.
    When you open them with QT player hit CTRL+I and tell us what info it gives you.
  • Wed, Dec 7 2011 8:20 PM In reply to
    What version QT do you have installed?
    ACI Moderator. I'm not employed by Avid or work for them. I just do this in my spare time. Multiple systems: Dual Boot DS10.3.1 - Symphony V6.5.2 MC... [view my complete system specs]
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor, ACSR, Apple Certified Support Professional 10.6
    VET
    Production    Editing     Digital Media    Blu-ray    DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    www.vet.co.uk | Lux Building 2-4 Hoxton Square  London N1 6US
    Avid Media Management for Media Composer VET short course (learn AMA!)
  • Wed, Dec 7 2011 8:42 PM In reply to
    • StephenW1
    • Posts 28
    • Points 400
    Quicktime:
    Version 7.7.1 (1680.42)
    QT says the file is 25fps, 1024x576. Different from its 'properties' tab.
  • Wed, Dec 7 2011 8:45 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 10,412
    • Points 123,355
    What happens if you first ama link them and then transcode them ?
    Mac: 17" Macbook Pro i7 2,66 ghz with 8Gb Ram, 500gb 7200rpm drive___ PC: W 7 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem 8 GB Corsair... [view my complete system specs]
    Tomas
  • Wed, Dec 7 2011 9:16 PM In reply to
    • StephenW1
    • Posts 28
    • Points 400
    The whole program freezes up and runs extremely slowly, I can do other things but MC does nothing for a minute. Then when I try running through the file in Avid it varies from slightly choppy to freezing up.
    So much that I can't transcode them.
    Again, my computer runs Avid fine with other files (including HD).
  • Wed, Dec 7 2011 9:25 PM In reply to
    I have seen that in some .mp4 files downloaded from Internet.
    I convert those files to Avid DV codec using TMPGEnc and they import by fast import then.
    Desktop
    Zalman 600W/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.5/Corsair 16G DDR3/PNY Quadro 2000D(275.89)/WD VelociRaptor 300@10K(OS)/ 2x2TB WD RE4@RAID 0/LG BH10LS30/W7 Pro 64bit/Symphony 6.5.2.1/Matrox MXO2 Mini/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    IMDbLinkedInTwitterYouTubeFB
  • Wed, Dec 7 2011 9:41 PM In reply to
    • StephenW1
    • Posts 28
    • Points 400
    Sounds like it may be what I'm looking for though it doesn't really explain why it worked fine on MC5.5, I've got some stuff to do today but I'll try it out tonight.
    Thank you all very much!
  • Wed, Dec 7 2011 9:52 PM In reply to
    I am seeing this at MC 5.5.3.1 though.
    Desktop
  • Fri, Dec 9 2011 2:44 AM In reply to
    • StephenW1
    • Posts 28
    • Points 400
    I converted to DNxHD using MPeg Streamclip which resulted in a 300gb file (the file is roughly two hours long, original file 3.5gb). I can now use AMA to edit the file but obviously it still takes forever to import. Is this sort of file size normal?
  • Fri, Dec 9 2011 2:49 AM In reply to
    This doesn't sound right at all.
    What is the original source?
    And what the file produced?
    DNxHD but what resolution.
    Desktop
  • Fri, Dec 9 2011 11:20 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 4,089
    • Points 47,725
    StephenW1:
    Hi Stephen, the lines above do not help very much for helping You out, You'd be better off clearly listing Your hardware and software configuration; the fact that Your system ran MC 5.5 well doen't mean that it would run MC 6 as well: the new 64bit code allows for more data to be managed, but this may put an underpowered system on its knees as it will also require more computing power. Sorry for potentially being the bearer of bad news, Luca
    MC 6.5.2.1 MXO2, P9X79 Pro i7-3930K, 32 GB ram, Quadro 600, StarTech PEX1394B3 FW controller, two 2x1TB raid 0 stripes + MC 3 on G4 MacBook 17" [view my complete system specs]
    peace luca
  • Fri, Dec 9 2011 3:01 PM In reply to
    You have a 2 hr long QT file that is only 3.5GB?  I'm really interested to know what codec was used!
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
