I am new to Avid and am having trouble exporting a QT from my sequence. Every time I export a QT movie using Same as Source my audio is about 5 - 7 frames ahead of the video (this is not an issue in the timeline).
The video contains multiple tracks of GFX made in Title Tool (only) and after recently restarting my system the following message appeared about updates to my sequence: "Effects to advanced key frame effects."
Please let me know if you need more info on my sequence to offer any help!
What version of what Avid product are you using?
MC 5
Are you running QT X?
Version Matrix: http://avid.force.com/pkb/LegacySearch?DocId=267087
QT Version 10.0
After playing with a few export settings (changing audio from 48 kHz t0 44.1 kHz for example) it seems that the video is the issue. I'm not sure if this is an issue with my computer playing back the QT, but that doesn't make sense since the video in the sequence plays back fine. Again, this is Media Composer 5 with Quicktime 10.0.
Kynrois:After playing with a few export settings (changing audio from 48 kHz t0 44.1 kHz for example) it seems that the video is the issue.
It'd help if you explained what happened when you changed audio settings that lead you to believe the video is the issue.
It turns out the issue was with my computer. I compressed the exported file it in iTunes and the video matched up. Thanks for offering your help!
Great! Glad you got it figured out!
