Latest post Wed, Feb 8 2012 1:59 AM by Le Maitre. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Dec 2 2011 7:15 PM
    • Paul Muzzin
    • Joined on Wed, Nov 23 2011
    • Toronto, Canada
    • Posts 17
    • Points 175
    Need Help With Assertion failed: kCGErrorSuccess
    Hi everyone. I am a new user to Avid, migrating from FCP and have been receiving two error messages and can't find any information about them from the Knowledge Base.
    The first error pops up when AMA linking to P2 Content on an external LaCie Firewire800 drive. It doesn't happen all the time.
    The 2nd and more prevalent error message showing up happens after transcoding my AMA linked P2 files to DNXHD 115.
    My system Specs:
    Mac OSX LION
    2x 2.4 GHz Quad-Core Intel Xeon
    8GB 1066 MHZ DDR3
    ATI Radeon HD 5770 1GB GDDR5 memory
    Thanks for all of your help
    - Paul
    2x2.4 GHz Quad-Core Intel Xeon | 32 GB 1066 MHz DDR3 | ATI Radeon HD 5770 1024 MB | Mac OS X Sierra | Media Composer 8.8.5 [view my complete system specs]
  • Fri, Dec 2 2011 10:29 PM In reply to
    Re: Need Help With Assertion failed: kCGErrorSuccess
    Unfortunately, those errors are generic and hard to make sense of.
    Is this happening consistently with particular media, or is it hit and miss?  Once transcoded, does it work without issue?
  • Fri, Dec 2 2011 10:58 PM In reply to
    • Paul Muzzin
    • Toronto, Canada
    • Posts 17
    • Points 175
    Kevin,
    Thanks for responding. The first error happened again while linking via AMA and crashed Media Composer 6. Unfortunately it didn't load the new transcoded media files into the bin and I now have the pleasure of tyring to find them in the Avid MediaFiles folder. You don't happen to know how I would then transfer them into a bin directly from the AMF folder do you?
    The second error happened, but I just hit "continue" and kept working.
    I contacted Avid Customer Success last night, sent them the screen shots, and they just got back to me. Although they are not tech support they recommended:
    - Please delete the Avid Database files (msmFMID.pmr, msmMMOB.mdb)
    - Please test it on a new project.
    - You can transfer the content of the bin on File menu/ open Bin.
    These files seem to be in 2 locations.  1) on my "Media Drive - Avid MediaFiles - MXF - 1 - " 2) on my "System Drive - Avid Media Composer - SupportingFiles - Avid_MediaFiles -"   I'm a little nervous about deleting these files. I don't even know what they do. I suppose I will make copies of them and record their file location first before I do this. I am beginning to wonder if this is a bug that was created when I moved to my trial version of 5.5 to the full install of 6.0 - then again I can't really tell since I wasn't ingesting media with 5.5 but just running tutorials until the full installl discs arrived. - Paul
  • Sat, Dec 3 2011 12:06 AM In reply to
    If the media is imported before the bin is saved, it's still in on your media drive(s).  Just open up the Media Tool, select the proper drive and project, and you can sort by creation date to find the newest clips.
    Then you can drag those clips into the bin from the media tool.
  • Sat, Dec 3 2011 8:31 PM In reply to
    Oh, and the Avid database file can be deleted safely.  The system will rebuild them the next time the program is launched.
    You'll see a "Scanning..." and "Indexing..." message referring the media drive during launch.
  • Fri, Dec 9 2011 4:55 PM In reply to
    • Paul Muzzin
    • Toronto, Canada
    • Posts 17
    • Points 175
    Thanks. that's good to know.
  • Wed, Feb 8 2012 1:59 AM In reply to
    • Le Maitre
    • Joined on Sat, Apr 11 2009
    • England
    • Posts 57
    • Points 665
    The kCGErrorSuccess error happens because your display is going to sleep during the transcode. You can workaround this by telling your display never to go to sleep. Just go to System Preferences in the Apple menu, select Energy Saver and drag the Display sleep arrow to Never. That should stop this error.
    Previous versions of MC didn't do this.
    Intel Core i7-2600K CPU, 8GB RAM, Quadro 4000, Sound Blaster X-Fi XtremeMusic, DeckLink Studio 2, DIGI002 desk, Plextor Bluray writer, Win-7 Ultimate 64... [view my complete system specs]
