Latest post Thu, Feb 7 2019 1:17 PM by Leo. 7 replies.
  • Mon, Feb 20 2006 6:57 PM
    • riojapj
    • London, UK
    • Posts 137
    • Points 1,450
    Loop Selected Clips
    Some odd behaviour here. When I go to the bin menu command 'loop selected clips', the first clip loads into the source monitor and begins to play as you'd expect. But it's when I hit 'tab' that the system goes bananas. Instead of skipping to the start of the next selected clip and playing from that point, 'tab' sparks off an endless and uninterruptable cycle through all selected clips. It's like some demented, disjointed flick-book. Surely I'm doing something wrong here? I've used this laptop for AXP for almost 2 years without a single issue (lucky me) so I'm sure I'm missing something desperately obvious. Any ideas guys?
    Peej
    MC 8.10.0 Mac Pro (late 2013) CPU - 3 GHz 8-Core Intel Xeon E5 RAM - 64GB DDR3 GFX - AMD FirePro D700 6GB (x2) [view my complete system specs]
    Paul
  • Tue, Feb 21 2006 7:15 PM In reply to
    • riojapj
    • London, UK
    • Posts 137
    • Points 1,450
    Re: Loop Selected Clips
    Bumpity bump.
    Paul
  • Tue, Feb 21 2006 7:30 PM In reply to
    • Eric Alkire
    • R2TV Richland Co., SC
    • Posts 132
    • Points 1,665
    This may sound silly, but could your tab button be sticking? My spacebar is wearing out, so play/stop can be an adventure. I've also had intermittent problems with my shift key.
    Blow some comressed air in the keyboard and see if that doesn't fix it? Otherwise, I'm at a loss software-wise.
    Currently using Avid Pinnacle 6 and 7.1 on a Dell XPS, along with Adobe Production Suite. I have much more experience with Avid XPress Pro HD 5.x, LANShare... [view my complete system specs]
    ACSR-Windows
  • Tue, Feb 21 2006 8:14 PM In reply to
    • riojapj
    • London, UK
    • Posts 137
    • Points 1,450
    Nope, no sticky keys, but thanks for the suggestion! There's no keyboard mapping that could be interfering. I'm using 4.6 as well, arguably the most stable 4.x version. Hmm...
    If nobody on these forums have experienced this before, then it can only be something to do with my particular system configuration. Strange though, this laptop setup is precisely the same one Computer Video Editing mag (UK) used to test the initial AXP release.
    It's not the end of the world, it would just be a handy feature to have work properly.
    Peej
    Paul
  • Sat, Oct 15 2011 11:21 AM In reply to
    riojapj:
    Hi, I have the same problem in Media Composer 5.0.3. I've never used the function before so I couldn't say if it worked.
    Does anybody have the same problem? Any ideas how to solve it? It isn't so important function, but looks very handy. Smile
    Media Composer 8.3, Avid FX 6, BCC 6, Baselight for Avid, Windows7 64-bit [view my complete system specs]
  • Mon, Oct 17 2011 6:41 PM In reply to
    • R&B
    • Metro Atlanta
    • Posts 205
    • Points 2,465
    It sure sounds like a sticky key.  But you say it isn't.
    Have you tried using the tab key in other applications (like Word) just to confirm that it's not a sticky key?
    iMacs, both running OS X 10.7.x Lion. Both have 3.06 GHz Intel Core 2 processor w/ 4 GB RAM. Also a 17" MacBook Pro. All these machines are from 2008... [view my complete system specs]
    Randy Brown
    President
    Brown Media, Inc.
    www.brownmedia.net
    "Voice Imaging for Radio and TV"
  • Tue, Oct 18 2011 3:22 PM In reply to
    Yes, sure, it isn't a sticky key. Tab key works perfectly for Edit review and for jumping between takes in a script.
    But thanks for an idea.
  • Thu, Feb 7 2019 1:17 PM In reply to
    • Leo
    • Joined on Mon, Feb 14 2011
    • Berlin
    • Posts 38
    • Points 360
    after 8 years of your system being stuck... haha.
    i found out that you have to set the play function on the tab key, like in the standart setting. i had it set to switch from timeline to sourcemonitor view and it had the same behaviour you describe.
    im sure you have found the solution meanwhile, but just for other stumbling over this post....
    all the best.
    leo
    2017 iMac i7 24GB RAM 8GB Radeon 580. OSX Mojave. 2011 MBP i7 16GB RAM AMD HD 6750M 1GB Video. OSX 10.11.5 Avid MC 8.8.0 [view my complete system specs]
