Latest post Wed, Mar 14 2012 8:44 PM by gailledrat fabien. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Nov 17 2011 7:52 PM
    • addinski
    • Erfurt, Germany
    • Posts 188
    • Points 2,275
    AVID MC6 German Keyboard Layout
    anyone figured out a way to set German or any other keyboard language layout other than US? I tried new settings etc, but keyboard settings are messed up now. Tried to change OSX language settings. No luck. This has never been an issue before. Going back to 5.5. :(
    MAC OS X 10.11.6 AVID MC 2018.3 + Avid Mbox Pro 3 MACBOOKPRO 15" Retina, i7 2.66 GHz Quadcore, 16GB Ram Dell UltraSharp U2711 Sony FS5 & Alpha... [view my complete system specs]
    Honestly I hate editing.
  • Thu, Nov 17 2011 8:00 PM In reply to
    • Florian
    • Germany
    • Posts 334
    • Points 4,190
    Re: AVID MC6 German Keyboard Layout
    This is indeed a problem. Some Keyfunctions are unmappable (don´t know if this is an exiting word Smile)
    Maybe one who knows a little more could chime in here…
    On the other hand MC 6 roars like a lion, thank you Avid
    MacBook Pro Retina 15", 2.5Ghz QuadCore i7, OS Catalina 15.1, Avid MC 2018.5, 16GB Ram, AMD Radeon R9 M370X [view my complete system specs]
  • Sun, Nov 20 2011 1:54 PM In reply to
    • Kaiser
    • Berlin
    • Posts 87
    • Points 1,265
    "Glad", I'm not the only one with this issue; Examples:
    F1-Key launches 'Help' (Standard-PC-Key). I recall this issue more than a decade ago.
    'Slip 10frames right' marks Audio-Track3 ...
    Don't they do international beta-testing? Obviosly not!
    FSD:
    yeah - it roars loud, but maybe it should have stayed a little longer in kittens basket. Premature release - INMHO.
    MC 2018 on MacBookPro 2013 2.6 Intel Core I7, Mojave [view my complete system specs]
  • Mon, Nov 21 2011 9:44 AM In reply to
    • Florian
    • Germany
    • Posts 334
    • Points 4,190
    Lift isn´t lift anymore, instead of lifting it now is slipping 1 frame.
    Trim mode opens up the quick transition window...
    Creating new user settings twice, doesn´t help
    ReMapping from the Command Palette won´t do it
    Even the default user setting is messed up.
    and have a look here
    same Problems on the PC side
    http://community.avid.com/forums/p/102785/592651.aspx
  • Wed, Nov 23 2011 3:18 PM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 188
    • Points 2,275
    Oh boy. I did some more testing and found at least a "sort of" workaround, that does the deal for me. In OSX you can show the input source language as a flag on the menu bar. You can switch it there to the US keyboard and so you can at least assign the tools you need to your keyboard settings. I started from scratch with the settings file in the avid utilities folder called XpressKeyboardSettings. So I can at least cut the way I want in Avid using the US keyboard layout and switch back to German, when I quit Avid. Only downside are systemwide shortcuts like command Z, which becomes command Y for us, etc. etc.
    I know it´s not perfect, but might help to get you cutting.
    André.
  • Thu, Dec 15 2011 6:50 AM In reply to
    • Florian
    • Germany
    • Posts 334
    • Points 4,190
    addinski:
    So, are there any news about the messed up keyboard settings Huh?
    regards
  • Thu, Dec 15 2011 1:16 PM In reply to
    Avid is aware and is working on a fix.  No news about when the fix will be released.
    (Sorry this info wasn't posted here.  It was posted on the other keyboard threads, but I hadn't seen this one.)
    Media Composer 2019.12 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Thu, Dec 15 2011 1:17 PM In reply to
    • Florian
    • Germany
    • Posts 334
    • Points 4,190
    thanks for updating Carl,
    i´m working with 5.5.3 so far
  • Wed, Jan 4 2012 1:43 PM In reply to
    Oh THANK you  André. !!!!
    3 GHz 8 core Intel Xeon E5 MacProlate 2013/ 64 GB / 10.12.6 / MC18.12.3 / AMD FirePro D300 2048 MB [view my complete system specs]
  • Sun, Feb 5 2012 9:47 PM In reply to
    • kintscher
    • Joined on Sun, Feb 5 2012
    • Posts 1
    • Points 15
    Hi
    I had the same Issue on Windows 7. I changed the Systems layout, so the keyboard layout Windows is using (probably working on OSX too). It is kind of a workaround in the way of "minus times minus is plus", but at least the key positions are right now.
    Hope it works for you too
  • Wed, Mar 14 2012 8:44 PM In reply to
    Hi there, same problem with french keyboard, have to switch to english keyboard in language bar to have my mapped key doing the right function. Obviously ctrl+a (sellect all) becomes ctrl+q (quit application) and so on... very annoying
